zmfilter.pl error
DerGraf
zmfilter.pl error
Post by DerGraf »
I have a strange problem with ZM 1.33.14
zmfilter won´t work. The log give me the reason but why?
ZM was installed on fresh Debian Buster Minimal from zmrepo.
On console i got an error also:
MariaDB [zm]> SELECT * FROM `Filters` WHERE `Id` = ? AND( `AutoArchive` = 1 or `AutoVideo` = 1 or `AutoUpload` = 1 or `AutoEmail` = 1 or `AutoMessage` = 1 or `AutoExecute` = 1 or `AutoDelete` = 1 or `UpdateDiskSpace` = 1 or `AutoMove` = 1 or `AutoCopy` = 1 ) ORDER BY `Name`;
ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '? AND( `AutoArchive` = 1 or `AutoVideo` = 1 or `AutoUpload` = 1 or `AutoEmail` =' at line 1
MariaDB [zm]>
By removing "id = ?" it works:
MariaDB [zm]> SELECT * FROM `Filters` WHERE ( `AutoArchive` = 1 or `AutoVideo` = 1 or `AutoUpload` = 1 or `AutoEmail` = 1 or `AutoMessage` = 1 or `AutoExecute` = 1 or `AutoDelete` = 1 or `UpdateDiskSpace` = 1 or `AutoMove` = 1 or `AutoCopy` = 1 ) ORDER BY `Name`;
| Id | Name             | Query        | AutoArchive | AutoVideo | AutoUpload | AutoEmail | AutoMessage | AutoExecute | AutoExecuteCmd | AutoDelete | AutoMove | AutoMoveTo | AutoCopy | AutoCopyTo | UpdateDiskSpace | Background | Concurrent |
|  1 | PurgeWhenFull    | {"sort_field":"Id","terms":[{"val":0,"attr":"Archived","op":"="},{"cnj":"and","val":95,"attr":"DiskPercent","op":">="}],"limit":100,"sort_asc":1} |           0 |         0 |          0 |         0 |           0 |           0 |                |          1 |        0 |          0 |        0 |          0 |               0 |          1 |          0 |
|  2 | Update DiskSpace | {"terms":[{"attr":"DiskSpace","op":"IS","val":"NULL"}]}        |           0 |         0 |          0 |         0 |           0 |           0 |                |          0 |        0 |          0 |        0 |          0 |               1 |          1 |          0 |
2 rows in set (0.000 sec)
Error by execute /usr/bin/zmfilter.pl as well
root@zm:~# zmfilter.pl
11/15/19 21:43:59.084465 zmfilter[25816].INF [main:185] [Scanning for events using all filters]
11/15/19 21:44:04.086320 zmfilter[25816].WAR [ZoneMinder::Filter:137] [No query in Filter!]
11/15/19 21:44:04.089508 zmfilter[25816].ERR [main:260] [Error parsing Sql. skipping filter 'PurgeWhenFull']
11/15/19 21:44:04.090003 zmfilter[25816].WAR [ZoneMinder::Filter:137] [No query in Filter!]
11/15/19 21:44:04.091132 zmfilter[25816].ERR [main:260] [Error parsing Sql. skipping filter 'Update DiskSpace']
11/15/19 21:44:04.091573 zmfilter[25816].WAR [main:267] [No filter found for SELECT * FROM `Filters` WHERE `Background` = 1 AND( `AutoArchive` = 1
    or `AutoVideo` = 1
    or `AutoUpload` = 1
    or `AutoEmail` = 1
    or `AutoDelete` = 1
    or `AutoMove` = 1
    or `AutoCopy` = 1
    ) ORDER BY `Name` with values()]
But in Mysql-Console it works:
MariaDB [zm]> SELECT * FROM `Filters` WHERE `Background` = 1 AND( `AutoArchive` = 1     or `AutoVideo` = 1     or `AutoUpload` = 1     or `AutoEmail` = 1     or `AutoMessage` = 1     or `AutoExecute` = 1     or `AutoDelete` = 1     or `UpdateDiskSpace` = 1     or `AutoMove` = 1     or `AutoCopy` = 1     ) ORDER BY `Name`;
Thanks for helping.
Re: zmfilter.pl error
Somehow the most recent db update didn't get applied, so you will need to manually apply it.
mysql -u zmuser -p zm < /usr/share/zoneminder/db/zm_update-1.33.14.sql
DerGraf
Post by DerGraf »
That did it. Thank you.
