Hello everyone!
I have a link to view camera from DVR and I would like configure Zoneminder with this link:
rtsp://192.168.1.6/user=admin_password=tlJwpbo6_channel=1_stream=0.sdp
I've tried some configurations but still doesn't works.
Is there enybody can help me?
Configuration
Re: Configuration
If that stream works in VLC it will work in Zoneminder with ffmpeg. Just get the resolution from VLC and use that in ZM.
Re: Configuration
Thanks for you reply, I've tried but still doesn't works!
I don't understand what I'm wrong.
Attached some screenshots.
- Schermata da 2019-08-18 20-05-39.png (29.11 KiB) Viewed 3131 times
- Schermata da 2019-08-18 20-05-16.png (35.89 KiB) Viewed 3131 times
- Schermata da 2019-08-18 20-04-41.png (36.3 KiB) Viewed 3131 times
Re: Configuration
I've used Turnkey VM with Zoneminder 1.30 for testing but doesn't work in every ways.
Now I'm trying a docker image (andornaut/zoneminder, Zoneminder 1.32.3) with FFMPEG source and works fine!
Then the problem is the Turnkey VM.
Thanks everyone for all!
