probleme camera onvif
steph5764
Post by steph5764 »
bonjour,
je suis débutant avec zoneminder et je voudrais connecter deux camera ip onvif mais rien ne s'affiche .
j'ai testé les flux avec vlc et cela fonctionne je ne trouve pas quel parametre modifier .
zoneminder est installé sur raspberry pi3 .
voici un bout du log:
2019-07-28 18:54:19.800644 zmc_m5[12990].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-07-28 18:54:19.793703 zmc_m5[12990].ERR-zm_ffmpeg_camera.cpp/528 [Unable to open codec for video stream from rtsp://admin:Ludmilla1608@192.168.1.41:554/user=admin_password=qhjoP54u_channel=1_stream=0.sdp?real_stream]
2019-07-28 18:54:17.413860 zmc_m5[12990].INF-zm_ffmpeg_camera.cpp/378 [Stream open rtsp://admin:Ludmilla1608@192.168.1.41:554/user=admin_password=qhjoP54u_channel=1_stream=0.sdp?real_stream, parsing streams...]
2019-07-28 18:54:17.253436 zmc_m5[12990].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://admin:Ludmilla1608@192.168.1.41:554/user=admin_password=qhjoP54u_channel=1_stream=0.sdp?real_stream]
2019-07-28 18:54:17.017061 zmc_m5[12990].INF-zmc.cpp/223 [Starting Capture version 1.32.3]
2019-07-28 18:54:16.292720 zmdc[704].INF-zmdc.pl ['zmc -m 5' starting at 19/07/28 18:54:16, pid = 12990]
2019-07-28 18:54:16.289660 zmdc[12990].INF-zmdc.pl ['zmc -m 5' started at 19/07/28 18:54:16]
2019-07-28 18:54:16.266440 zmdc[704].INF-zmdc.pl [Starting pending process, zmc -m 5]
2019-07-28 18:54:11.253140 zmdc[704].INF-zmdc.pl ['zmc -m 5' exited normally]
2019-07-28 18:54:11.044365 zmc_m5[12983].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-28 18:54:11.036920 zmdc[704].INF-zmdc.pl ['zmc -m 5' sending stop to pid 12983 at 19/07/28 18:54:11]
2019-07-28 18:54:10.515960 zmwatch[747].INF-zmwatch.pl [Restarting capture daemon for test, no image since startup. Startup time was 1564332842 - now 1564332850 > 5]
2019-07-28 18:54:05.146807 zmc_m5[12983].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
merci de votre aide
kitkat
Re: probleme camera onvif
Post by kitkat »
Bonjour - Je ne parle pas français - C'est par Google Translate.
steph5764 wrote: Sun Jul 28, 2019 4:59 pm 2019-07-28 18:54:19.793703 zmc_m5[12990].ERR-zm_ffmpeg_camera.cpp/528 [Unable to open codec for video stream from rtsp://admin:Ludmilla1608@192.168.1.41:554/user=admin_password=qhjoP54u_channel=1_stream=0.sdp?real_stream]
Le mot de passe devrait-il être le même aux deux endroits? (admin:Ludmilla1608 / user=admin_password=qhjoP54u)
Qu'avez-vous défini pour 'Type de source' et 'Méthode'?
Quel est le format du flux vidéo de la caméra (H.264, RealVideo, mjpeg)?
Il peut être plus simple de publier des captures d'écran des pages de paramètres :)
English:
Should the password be the same in both places? (admin:Ludmilla1608 / user=admin_password=qhjoP54u)
What do you have set for 'Source Type' and 'Method'?
What format is the camera's video stream (H.264, RealVideo, mjpeg)?
It may be easiest to post screenshots of the settings pages :)
steph5764
Post by steph5764 »
bonjour,
merci de prendre du temps pour mon problème
pour l'encodage de la camera je trouve h.265x
pour le mots de passe dans le lien si je le change le lien ne fonctionne plus (test avec vlc)
pour le type de source ffmpeg
pour la methode j'ai testé tcp et udp mais rien n'y fait
thank you for taking time for my problem
for the encoding of the camera I find h.265x
for the passwords in the link if I change the link does not work anymore (test with vlc)
for the source type ffmpeg
for the method i tested tcp and udp but nothing helps
