2 equal cams
Heimo
2 equal cams
Post by Heimo »
Good afternoon everybody,
perhaps somebody can help me.
I changed to Raspberry pi 4 with raspbian and zoneminder 1.32 and got a Problem I never had.
I am working with 2 equal cams (Foscam FI 9826W), but only 1 cam is working. They are ok, because I get an image from both in another tool. Sometime the first is working, sometimes the other.
I tried VLans, Groups, different ports, it does not work.
Has anybody an idea?
Thanks a lot.
Kind regards.
Heimo
Re: 2 equal cams
You are out of space in /dev/shm. Reduce buffers or resolution.
