How to add Pi Camera Module?
bugmenot
Post by bugmenot »
What settings work with Pi Camera Module 1.2? I can't get this camera to show any video. I have tried all different settings.
What is correct Source Type?
I think Capture Method should be Video For Linux version 2.
Now i have Save JPEGs Disabled and Video Writer X264 Encode - Not compatible on Arm, it don't allow choose H264.
Probe don't find a thing and ONVIF detects IP-camera @ 192.168.1.2 using version 1.2 and if i choose that, in next screen, Detected Profiles is empty so i cannot click save.
Re: How to add Pi Camera Module?
Source type should be Local
Device Path /dev/video0
Device Format try PAL or PAL B
Try various resolutions such as 640x480 or look up the camera specs.
Use .jpeg only. Video does not work on a Pi
bugmenot
Post by bugmenot »
Now Console says Capturing and has big red ball for PiCam and Vision cam is Capturing with green ball.
What does red/green balls mean?
Storage Path is just /pi/Desktop/ZM
Now i got 2nd camera “Vision”, It still dont show video anywhere but if i click open camera in Console, it shows new event secs 25 frames 6/1 score 4/4 and if i click that event open, it shows just white where video should be and also "0B on Desktop" and both Storage Locations default and Desktop are empty.
If i click Vision camera open it some times shows video for few seconds then disappears.
Is it possible that two cameras have both same Device Path: /dev/video0?
If i click camera open, "State: Idle - 0 fps" and where video should be is just white and log:
2019-07-20 15:19:10.029150 zmdc[3072].INF-zmdc.pl ['zmfilter.pl --filter_id=2 --daemon' started at 19/07/20 15:19:10]
2019-07-20 15:19:10.028350 zmdc[863].INF-zmdc.pl ['zmfilter.pl --filter_id=2 --daemon' starting at 19/07/20 15:19:10, pid = 3072]
2019-07-20 15:19:09.098790 zmdc[863].INF-zmdc.pl [Starting pending process, zmfilter.pl --filter_id=2 --daemon]
2019-07-20 15:18:58.654360 zmdc[3070].INF-zmdc.pl ['zma -m 2' started at 19/07/20 15:18:58]
2019-07-20 15:18:58.653400 zmdc[863].INF-zmdc.pl ['zma -m 2' starting at 19/07/20 15:18:58, pid = 3070]
2019-07-20 15:18:57.953780 zmdc[863].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2019-07-20 15:18:57.939420 zmdc[863].INF-zmdc.pl [Command 'zmc -d /dev/video0' removed from pending list at 19/07/20 15:18:57]
2019-07-20 15:18:57.366620 zmdc[863].ERR-zmdc.pl ['zmc -d /dev/video0' exited abnormally, exit status 11]
2019-07-20 15:18:57.350180 zmdc[863].INF-zmdc.pl ['zma -m 2' sending stop to pid 3048 at 19/07/20 15:18:57]
2019-07-20 15:18:56.995827 zma_m1[3061].INF-zm_monitor.cpp/890 [Analysis fps (10.00) is lower than capturing fps (inf), disabling adaptive skip feature]
2019-07-20 15:18:56.981093 zma_m1[3061].INF-zma.cpp/134 [In mode 4/1, warming up]
2019-07-20 15:18:56.607550 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for PiCam, no image since startup. Startup time was 1563625129 - now 1563625136 > 5]
2019-07-20 15:18:56.595460 zmdc[863].ERR-zmdc.pl ['zmaudit.pl -c' exited abnormally, exit status 255]
2019-07-20 15:18:56.502320 zmdc[3061].INF-zmdc.pl ['zma -m 1' started at 19/07/20 15:18:56]
2019-07-20 15:18:56.494050 zmdc[863].INF-zmdc.pl ['zma -m 1' starting at 19/07/20 15:18:56, pid = 3061]
2019-07-20 15:18:56.134365 zmc_dvideo0[3049].ERR-zm_signal.cpp/50 [Got signal 11 (Segmentation fault), crashing]
2019-07-20 15:18:54.470970 zmaudit[3056].FAT-zmaudit.pl [zmaudit.pl appears to already be running at pid 966. If not, please delete /var/run/zm/zmaudit.pid or use the --force command line option.]
2019-07-20 15:18:51.159412 zmc_dvideo0[3049].INF-zm_monitor.cpp/2477 [LogitechVisionPro: images:1 - Capturing at 50.00 fps, capturing bandwidth 38400bytes/sec]
2019-07-20 15:18:49.851780 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 3049 at 19/07/20 15:18:49]
2019-07-20 15:18:49.411584 zmc_dvideo0[3049].WAR-zm_local_camera.cpp/1793 [Hue control is not supported]
2019-07-20 15:18:49.367996 zmc_dvideo0[3049].INF-zmc.cpp/223 [Starting Capture version 1.32.3]
2019-07-20 15:18:49.349167 zmc_dvideo0[3049].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
2019-07-20 15:18:49.337499 zmc_dvideo0[3049].WAR-zm_local_camera.cpp/403 [Different capture sizes defined for monitors sharing same device, results may be unpredictable or completely wrong]
2019-07-20 15:18:49.327524 zmc_dvideo0[3049].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:18:49.283770 zmdc[863].INF-zmdc.pl ['zma -m 1' exited, signal 14]
2019-07-20 15:18:49.270460 zmdc[3056].INF-zmdc.pl ['zmaudit.pl -c' started at 19/07/20 15:18:49]
2019-07-20 15:18:49.261700 zmdc[863].INF-zmdc.pl ['zmaudit.pl -c' starting at 19/07/20 15:18:49, pid = 3056]
2019-07-20 15:18:49.216680 zmdc[863].INF-zmdc.pl [Starting pending process, zmaudit.pl -c]
2019-07-20 15:18:48.787577 zmc_dvideo0[3049].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
2019-07-20 15:18:47.027324 zmc_dvideo0[3049].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:18:45.170970 zmdc[863].INF-zmdc.pl ['zma -m 1' sending stop to pid 3038 at 19/07/20 15:18:45]
2019-07-20 15:18:44.391190 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for LogitechVisionPro, no image since startup. Startup time was 0 - now 1563625124 > 5]
2019-07-20 15:18:42.710350 zmdc[863].ERR-zmdc.pl ['zmfilter.pl --filter_id=1 --daemon' exited abnormally, exit status 2]
2019-07-20 15:18:36.508430 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' starting at 19/07/20 15:18:36, pid = 3049]
2019-07-20 15:18:36.499350 zmdc[3049].INF-zmdc.pl ['zmc -d /dev/video0' started at 19/07/20 15:18:36]
2019-07-20 15:18:32.653630 zmdc[863].INF-zmdc.pl [Starting pending process, zmc -d /dev/video0]
2019-07-20 15:18:31.480180 zmdc[3048].INF-zmdc.pl ['zma -m 2' started at 19/07/20 15:18:31]
2019-07-20 15:18:31.479180 zmdc[863].INF-zmdc.pl ['zma -m 2' starting at 19/07/20 15:18:31, pid = 3048]
2019-07-20 15:18:30.903560 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' exited, signal 14]
2019-07-20 15:18:30.854802 zmc_dvideo0[3035].INF-zmc.cpp/223 [Starting Capture version 1.32.3]
2019-07-20 15:18:30.842090 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 3035 at 19/07/20 15:18:30]
2019-07-20 15:18:29.136845 zmc_dvideo0[3035].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
2019-07-20 15:18:26.895250 zmdc[863].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2019-07-20 15:18:22.914190 zmdc[863].INF-zmdc.pl ['zma -m 2' sending stop to pid 3010 at 19/07/20 15:18:22]
2019-07-20 15:18:22.912890 zmc_dvideo0[3035].WAR-zm_local_camera.cpp/403 [Different capture sizes defined for monitors sharing same device, results may be unpredictable or completely wrong]
2019-07-20 15:18:21.861990 zmdc[3040].INF-zmdc.pl ['zmfilter.pl --filter_id=1 --daemon' started at 19/07/20 15:18:21]
2019-07-20 15:18:21.853780 zmdc[863].INF-zmdc.pl ['zmfilter.pl --filter_id=1 --daemon' starting at 19/07/20 15:18:21, pid = 3040]
2019-07-20 15:18:21.844391 zmc_dvideo0[3035].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:18:19.715630 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for PiCam, no image since startup. Startup time was 1563625071 - now 1563625099 > 5]
2019-07-20 15:18:19.697230 zmdc[863].INF-zmdc.pl [Starting pending process, zmfilter.pl --filter_id=1 --daemon]
2019-07-20 15:18:18.988267 zmc_dvideo0[3035].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
2019-07-20 15:18:18.513740 zmdc[3038].INF-zmdc.pl ['zma -m 1' started at 19/07/20 15:18:18]
2019-07-20 15:18:18.508450 zmdc[863].INF-zmdc.pl ['zma -m 1' starting at 19/07/20 15:18:18, pid = 3038]
2019-07-20 15:18:18.267403 zmc_dvideo0[3035].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:18:16.361670 zmdc[3035].INF-zmdc.pl ['zmc -d /dev/video0' started at 19/07/20 15:18:16]
2019-07-20 15:18:16.361630 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' starting at 19/07/20 15:18:16, pid = 3035]
2019-07-20 15:18:13.431290 zmdc[863].WAR-zmdc.pl [Can't find process with command of 'zmc -d /dev/video0']
2019-07-20 15:18:09.788960 zmdc[863].INF-zmdc.pl ['zma -m 1' exited, signal 14]
2019-07-20 15:18:07.938120 zmdc[863].INF-zmdc.pl ['zma -m 1' sending stop to pid 2988 at 19/07/20 15:18:07]
2019-07-20 15:18:06.069210 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for LogitechVisionPro, no image since startup. Startup time was 1563625071 - now 1563625086 > 5]
2019-07-20 15:18:02.276142 zma_m2[3010].ERR-zm_local_camera.cpp/380 [Automatic format selection failed. Falling back to YUYV]
2019-07-20 15:17:56.386775 zma_m2[3010].ERR-zm_local_camera.cpp/1194 [Automatic format selection failed to open video device /dev/video0: No such file or directory]
2019-07-20 15:17:52.668230 zmdc[3010].INF-zmdc.pl ['zma -m 2' started at 19/07/20 15:17:52]
2019-07-20 15:17:52.668200 zmdc[863].INF-zmdc.pl ['zma -m 2' starting at 19/07/20 15:17:52, pid = 3010]
2019-07-20 15:17:52.015150 zmdc[863].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2019-07-20 15:17:52.002760 zmdc[863].INF-zmdc.pl [Command 'zmc -d /dev/video0' removed from pending list at 19/07/20 15:17:52]
2019-07-20 15:17:51.269400 zmdc[863].ERR-zmdc.pl ['zmc -d /dev/video0' exited abnormally, exit status 255]
2019-07-20 15:17:51.245990 zmdc[863].INF-zmdc.pl ['zma -m 2' sending stop to pid 2972 at 19/07/20 15:17:51]
2019-07-20 15:17:51.108643 zmc_dvideo0[2989].FAT-zm_local_camera.cpp/714 [Failed to open video device /dev/video0: No such file or directory]
2019-07-20 15:17:51.083358 zmc_dvideo0[2989].INF-zmc.cpp/223 [Starting Capture version 1.32.3]
2019-07-20 15:17:51.053035 zmc_dvideo0[2989].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
2019-07-20 15:17:51.040854 zmc_dvideo0[2989].WAR-zm_local_camera.cpp/403 [Different capture sizes defined for monitors sharing same device, results may be unpredictable or completely wrong]
2019-07-20 15:17:51.029106 zmc_dvideo0[2989].ERR-zm_local_camera.cpp/380 [Automatic format selection failed. Falling back to YUYV]
2019-07-20 15:17:51.013901 zmc_dvideo0[2989].ERR-zm_local_camera.cpp/1194 [Automatic format selection failed to open video device /dev/video0: No such file or directory]
2019-07-20 15:17:50.982812 zmc_dvideo0[2989].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
2019-07-20 15:17:50.972194 zma_m1[2988].ERR-zm_local_camera.cpp/380 [Automatic format selection failed. Falling back to YUYV]
2019-07-20 15:17:50.961212 zmc_dvideo0[2989].ERR-zm_local_camera.cpp/380 [Automatic format selection failed. Falling back to YUYV]
2019-07-20 15:17:50.948231 zmc_dvideo0[2989].ERR-zm_local_camera.cpp/1194 [Automatic format selection failed to open video device /dev/video0: Device or resource busy]
2019-07-20 15:17:50.947674 zma_m1[2988].ERR-zm_local_camera.cpp/1194 [Automatic format selection failed to open video device /dev/video0: Device or resource busy]
2019-07-20 15:17:50.235910 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for PiCam, no image since startup. Startup time was 1563624994 - now 1563625070 > 5]
2019-07-20 15:17:50.200210 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' starting at 19/07/20 15:17:50, pid = 2989]
2019-07-20 15:17:50.196780 zmdc[2989].INF-zmdc.pl ['zmc -d /dev/video0' started at 19/07/20 15:17:50]
2019-07-20 15:17:50.146010 zmdc[863].INF-zmdc.pl [Starting pending process, zmc -d /dev/video0]
2019-07-20 15:17:50.136750 zmdc[2988].INF-zmdc.pl ['zma -m 1' started at 19/07/20 15:17:50]
2019-07-20 15:17:50.122950 zmdc[863].INF-zmdc.pl ['zma -m 1' starting at 19/07/20 15:17:50, pid = 2988]
2019-07-20 15:17:49.869780 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' crashed, signal 8]
2019-07-20 15:17:46.560350 zmdc[863].WAR-zmdc.pl ['zmc -d /dev/video0' has not stopped at 19/07/20 15:17:46 after 60 seconds. Sending KILL to pid 2915]
2019-07-20 15:17:45.839280 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2915 at 19/07/20 15:17:45]
2019-07-20 15:17:44.129680 zmdc[863].INF-zmdc.pl ['zma -m 1' exited, signal 14]
2019-07-20 15:17:37.706820 zmdc[863].WAR-zmdc.pl ['zmc -d /dev/video0' has not stopped at 19/07/20 15:17:37 after 60 seconds. Sending KILL to pid 2915]
2019-07-20 15:17:31.031790 zmdc[863].INF-zmdc.pl ['zma -m 1' sending stop to pid 2964 at 19/07/20 15:17:31]
2019-07-20 15:17:30.379040 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for LogitechVisionPro, no image since startup. Startup time was 1563624994 - now 1563625050 > 5]
2019-07-20 15:17:18.110350 zmdc[863].INF-zmdc.pl ['zma -m 2' starting at 19/07/20 15:17:18, pid = 2972]
2019-07-20 15:17:18.109780 zmdc[2972].INF-zmdc.pl ['zma -m 2' started at 19/07/20 15:17:18]
2019-07-20 15:17:17.494957 zmc_dvideo0[2915].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:17:14.123540 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2915 at 19/07/20 15:17:14]
2019-07-20 15:17:13.156660 zmdc[863].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2019-07-20 15:17:11.033350 zmdc[863].INF-zmdc.pl ['zma -m 2' sending stop to pid 2937 at 19/07/20 15:17:11]
2019-07-20 15:17:06.845440 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for PiCam, no image since startup. Startup time was 1563624994 - now 1563625026 > 5]
2019-07-20 15:17:04.765410 zmdc[2964].INF-zmdc.pl ['zma -m 1' started at 19/07/20 15:17:04]
2019-07-20 15:17:04.757200 zmdc[863].INF-zmdc.pl ['zma -m 1' starting at 19/07/20 15:17:04, pid = 2964]
2019-07-20 15:17:04.042281 zmc_dvideo0[2915].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:17:04.029590 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2915 at 19/07/20 15:17:04]
2019-07-20 15:17:03.330590 zmdc[863].INF-zmdc.pl ['zma -m 1' exited, signal 14]
2019-07-20 15:17:03.311190 zmdc[863].INF-zmdc.pl ['zma -m 1' sending stop to pid 2930 at 19/07/20 15:17:03]
2019-07-20 15:17:02.632850 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for LogitechVisionPro, no image since startup. Startup time was 1563624994 - now 1563625022 > 5]
2019-07-20 15:16:50.704970 zmdc[2937].INF-zmdc.pl ['zma -m 2' started at 19/07/20 15:16:50]
2019-07-20 15:16:50.699040 zmdc[863].INF-zmdc.pl ['zma -m 2' starting at 19/07/20 15:16:50, pid = 2937]
2019-07-20 15:16:49.941889 zmc_dvideo0[2915].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:16:49.023450 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2915 at 19/07/20 15:16:49]
2019-07-20 15:16:47.104300 zmdc[863].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2019-07-20 15:16:46.127180 zmdc[863].INF-zmdc.pl ['zma -m 2' sending stop to pid 2914 at 19/07/20 15:16:46]
2019-07-20 15:16:43.640630 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for PiCam, no image since startup. Startup time was 1563624994 - now 1563625003 > 5]
2019-07-20 15:16:37.774670 zmdc[2930].INF-zmdc.pl ['zma -m 1' started at 19/07/20 15:16:37]
2019-07-20 15:16:37.773620 zmdc[863].INF-zmdc.pl ['zma -m 1' starting at 19/07/20 15:16:37, pid = 2930]
2019-07-20 15:16:34.943228 zmc_dvideo0[2915].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:16:34.910540 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2915 at 19/07/20 15:16:34]
2019-07-20 15:16:34.301808 zmc_dvideo0[2915].WAR-zm_local_camera.cpp/1793 [Hue control is not supported]
2019-07-20 15:16:34.260928 zmc_dvideo0[2915].INF-zmc.cpp/223 [Starting Capture version 1.32.3]
2019-07-20 15:16:34.242486 zmc_dvideo0[2915].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
2019-07-20 15:16:34.228102 zmc_dvideo0[2915].WAR-zm_local_camera.cpp/403 [Different capture sizes defined for monitors sharing same device, results may be unpredictable or completely wrong]
2019-07-20 15:16:34.207684 zmc_dvideo0[2915].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:16:34.098480 zmdc[863].INF-zmdc.pl ['zma -m 1' exited, signal 14]
2019-07-20 15:16:32.741484 zmc_dvideo0[2915].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
2019-07-20 15:16:31.186760 zmdc[863].INF-zmdc.pl ['zma -m 1' sending stop to pid 2901 at 19/07/20 15:16:31]
2019-07-20 15:16:30.857440 zmc_dvideo0[2915].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:16:28.396650 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for LogitechVisionPro, no image since startup. Startup time was 1563624909 - now 1563624988 > 5]
2019-07-20 15:16:28.221350 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' starting at 19/07/20 15:16:28, pid = 2915]
2019-07-20 15:16:28.218480 zmdc[2915].INF-zmdc.pl ['zmc -d /dev/video0' started at 19/07/20 15:16:28]
2019-07-20 15:16:26.917120 zmdc[863].INF-zmdc.pl [Starting pending process, zmc -d /dev/video0]
2019-07-20 15:16:18.424290 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' crashed, signal 8]
2019-07-20 15:16:15.332820 zmdc[863].WAR-zmdc.pl ['zmc -d /dev/video0' has not stopped at 19/07/20 15:16:15 after 60 seconds. Sending KILL to pid 2863]
2019-07-20 15:16:13.429610 zmdc[2914].INF-zmdc.pl ['zma -m 2' started at 19/07/20 15:16:13]
2019-07-20 15:16:13.426180 zmdc[863].INF-zmdc.pl ['zma -m 2' starting at 19/07/20 15:16:13, pid = 2914]
2019-07-20 15:16:12.661744 zmc_dvideo0[2863].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:16:11.133990 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2863 at 19/07/20 15:16:11]
2019-07-20 15:16:08.284040 zmdc[863].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2019-07-20 15:16:05.320340 zmdc[863].INF-zmdc.pl ['zma -m 2' sending stop to pid 2890 at 19/07/20 15:16:05]
2019-07-20 15:16:04.666910 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for PiCam, no image since startup. Startup time was 1563624909 - now 1563624964 > 5]
2019-07-20 15:16:02.519240 zmdc[2901].INF-zmdc.pl ['zma -m 1' started at 19/07/20 15:16:02]
2019-07-20 15:16:02.514980 zmdc[863].INF-zmdc.pl ['zma -m 1' starting at 19/07/20 15:16:02, pid = 2901]
2019-07-20 15:16:01.422728 zmc_dvideo0[2863].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:15:59.889350 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2863 at 19/07/20 15:15:59]
2019-07-20 15:15:57.765920 zmdc[863].INF-zmdc.pl ['zma -m 1' exited, signal 14]
2019-07-20 15:15:57.744820 zmdc[863].INF-zmdc.pl ['zma -m 1' sending stop to pid 2883 at 19/07/20 15:15:57]
2019-07-20 15:15:57.036930 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for LogitechVisionPro, no image since startup. Startup time was 1563624909 - now 1563624957 > 5]
2019-07-20 15:15:44.373690 zmdc[2890].INF-zmdc.pl ['zma -m 2' started at 19/07/20 15:15:44]
2019-07-20 15:15:44.373130 zmdc[863].INF-zmdc.pl ['zma -m 2' starting at 19/07/20 15:15:44, pid = 2890]
2019-07-20 15:15:43.784722 zmc_dvideo0[2863].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:15:42.350130 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2863 at 19/07/20 15:15:42]
2019-07-20 15:15:39.962010 zmdc[863].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2019-07-20 15:15:37.588800 zmdc[863].INF-zmdc.pl ['zma -m 2' sending stop to pid 2875 at 19/07/20 15:15:37]
2019-07-20 15:15:36.978900 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for PiCam, no image since startup. Startup time was 1563624909 - now 1563624936 > 5]
2019-07-20 15:15:35.989780 zmdc[2883].INF-zmdc.pl ['zma -m 1' started at 19/07/20 15:15:35]
2019-07-20 15:15:35.987940 zmdc[863].INF-zmdc.pl ['zma -m 1' starting at 19/07/20 15:15:35, pid = 2883]
2019-07-20 15:15:35.343460 zmc_dvideo0[2863].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:15:33.802000 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2863 at 19/07/20 15:15:33]
2019-07-20 15:15:30.806920 zmdc[863].INF-zmdc.pl ['zma -m 1' exited, signal 14]
2019-07-20 15:15:28.596800 zmdc[863].INF-zmdc.pl ['zma -m 1' sending stop to pid 2867 at 19/07/20 15:15:28]
2019-07-20 15:15:27.965020 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for LogitechVisionPro, no image since startup. Startup time was 1563624909 - now 1563624927 > 5]
2019-07-20 15:15:15.286040 zmdc[2875].INF-zmdc.pl ['zma -m 2' started at 19/07/20 15:15:15]
2019-07-20 15:15:15.282620 zmdc[863].INF-zmdc.pl ['zma -m 2' starting at 19/07/20 15:15:15, pid = 2875]
2019-07-20 15:15:14.583540 zmc_dvideo0[2863].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:15:14.566650 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2863 at 19/07/20 15:15:14]
2019-07-20 15:15:13.261490 zmdc[863].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2019-07-20 15:15:10.013470 zmdc[863].INF-zmdc.pl ['zma -m 2' sending stop to pid 2844 at 19/07/20 15:15:10]
2019-07-20 15:15:09.504935 zmc_dvideo0[2863].WAR-zm_local_camera.cpp/1793 [Hue control is not supported]
2019-07-20 15:15:09.455686 zmc_dvideo0[2863].INF-zmc.cpp/223 [Starting Capture version 1.32.3]
2019-07-20 15:15:09.434444 zmc_dvideo0[2863].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
2019-07-20 15:15:09.407451 zmc_dvideo0[2863].WAR-zm_local_camera.cpp/403 [Different capture sizes defined for monitors sharing same device, results may be unpredictable or completely wrong]
2019-07-20 15:15:09.387484 zmc_dvideo0[2863].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:15:09.298230 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for PiCam, no image since startup. Startup time was 1563624776 - now 1563624909 > 5]
2019-07-20 15:15:08.584970 zmc_dvideo0[2863].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
2019-07-20 15:15:04.600470 zmdc[863].INF-zmdc.pl ['zma -m 1' starting at 19/07/20 15:15:04, pid = 2867]
2019-07-20 15:15:04.597640 zmdc[2867].INF-zmdc.pl ['zma -m 1' started at 19/07/20 15:15:04]
2019-07-20 15:15:04.417345 zmc_dvideo0[2863].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:15:02.389950 zmdc[2863].INF-zmdc.pl ['zmc -d /dev/video0' started at 19/07/20 15:15:02]
2019-07-20 15:15:02.385180 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' starting at 19/07/20 15:15:02, pid = 2863]
2019-07-20 15:14:59.199350 zmdc[863].WAR-zmdc.pl [Can't find process with command of 'zmc -d /dev/video0']
2019-07-20 15:14:58.581310 zmdc[863].INF-zmdc.pl ['zma -m 1' exited, signal 14]
2019-07-20 15:14:58.213040 zmdc[863].INF-zmdc.pl ['zma -m 1' sending stop to pid 2836 at 19/07/20 15:14:58]
2019-07-20 15:14:48.525510 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for LogitechVisionPro, no image since startup. Startup time was 1563624776 - now 1563624888 > 5]
2019-07-20 15:14:37.655190 zmdc[863].INF-zmdc.pl ['zma -m 2' starting at 19/07/20 15:14:37, pid = 2844]
2019-07-20 15:14:37.653040 zmdc[2844].INF-zmdc.pl ['zma -m 2' started at 19/07/20 15:14:37]
2019-07-20 15:14:35.863220 zmdc[863].INF-zmdc.pl [Command 'zmc -d /dev/video0' removed from pending list at 19/07/20 15:14:35]
2019-07-20 15:14:35.212020 zmdc[863].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2019-07-20 15:14:34.427780 zmdc[863].INF-zmdc.pl ['zma -m 2' sending stop to pid 2811 at 19/07/20 15:14:34]
2019-07-20 15:14:30.867120 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for PiCam, no image since startup. Startup time was 1563624776 - now 1563624870 > 5]
2019-07-20 15:14:24.050620 zmdc[863].INF-zmdc.pl ['zma -m 1' starting at 19/07/20 15:14:24, pid = 2836]
2019-07-20 15:14:24.045190 zmdc[2836].INF-zmdc.pl ['zma -m 1' started at 19/07/20 15:14:24]
2019-07-20 15:14:23.361770 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' crashed, signal 8]
2019-07-20 15:14:23.347490 zmdc[863].WAR-zmdc.pl ['zmc -d /dev/video0' has not stopped at 19/07/20 15:14:23 after 60 seconds. Sending KILL to pid 2766]
2019-07-20 15:14:23.334900 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2766 at 19/07/20 15:14:23]
2019-07-20 15:14:23.306940 zmdc[863].INF-zmdc.pl ['zma -m 1' exited, signal 14]
2019-07-20 15:14:21.884780 zmdc[863].WAR-zmdc.pl ['zmc -d /dev/video0' has not stopped at 19/07/20 15:14:21 after 60 seconds. Sending KILL to pid 2766]
2019-07-20 15:14:19.570020 zmdc[863].INF-zmdc.pl ['zma -m 1' sending stop to pid 2804 at 19/07/20 15:14:19]
2019-07-20 15:14:17.870250 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for LogitechVisionPro, no image since startup. Startup time was 1563624776 - now 1563624857 > 5]
2019-07-20 15:14:05.786330 zmdc[2811].INF-zmdc.pl ['zma -m 2' started at 19/07/20 15:14:05]
2019-07-20 15:14:05.779260 zmdc[863].INF-zmdc.pl ['zma -m 2' starting at 19/07/20 15:14:05, pid = 2811]
2019-07-20 15:14:05.160638 zmc_dvideo0[2766].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:14:05.138920 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2766 at 19/07/20 15:14:05]
2019-07-20 15:14:03.709660 zmdc[863].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2019-07-20 15:14:01.974020 zmdc[863].INF-zmdc.pl ['zma -m 2' sending stop to pid 2793 at 19/07/20 15:14:01]
2019-07-20 15:13:58.768680 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for PiCam, no image since startup. Startup time was 1563624776 - now 1563624838 > 5]
2019-07-20 15:13:57.245310 zmdc[2804].INF-zmdc.pl ['zma -m 1' started at 19/07/20 15:13:57]
2019-07-20 15:13:57.241840 zmdc[863].INF-zmdc.pl ['zma -m 1' starting at 19/07/20 15:13:57, pid = 2804]
2019-07-20 15:13:55.450581 zmc_dvideo0[2766].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:13:55.425150 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2766 at 19/07/20 15:13:55]
2019-07-20 15:13:54.012220 zmdc[863].INF-zmdc.pl ['zma -m 1' exited, signal 14]
2019-07-20 15:13:51.864910 zmdc[863].INF-zmdc.pl ['zma -m 1' sending stop to pid 2781 at 19/07/20 15:13:51]
2019-07-20 15:13:47.976330 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for LogitechVisionPro, no image since startup. Startup time was 1563624776 - now 1563624827 > 5]
2019-07-20 15:13:22.763260 zmdc[863].INF-zmdc.pl ['zma -m 2' starting at 19/07/20 15:13:22, pid = 2793]
2019-07-20 15:13:22.761000 zmdc[2793].INF-zmdc.pl ['zma -m 2' started at 19/07/20 15:13:22]
2019-07-20 15:13:21.988666 zmc_dvideo0[2766].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:13:20.299190 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2766 at 19/07/20 15:13:20]
2019-07-20 15:13:19.653010 zmdc[863].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2019-07-20 15:13:19.628480 zmdc[863].INF-zmdc.pl ['zma -m 2' sending stop to pid 2758 at 19/07/20 15:13:19]
2019-07-20 15:13:19.023330 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for PiCam, no image since startup. Startup time was 1563624776 - now 1563624799 > 5]
2019-07-20 15:13:18.982240 zmdc[863].INF-zmdc.pl ['zma -m 1' starting at 19/07/20 15:13:18, pid = 2781]
2019-07-20 15:13:18.981630 zmdc[2781].INF-zmdc.pl ['zma -m 1' started at 19/07/20 15:13:18]
2019-07-20 15:13:18.330369 zmc_dvideo0[2766].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:13:18.317480 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2766 at 19/07/20 15:13:18]
2019-07-20 15:13:16.867480 zmdc[863].INF-zmdc.pl ['zma -m 1' exited, signal 14]
2019-07-20 15:13:14.627560 zmdc[863].INF-zmdc.pl ['zma -m 1' sending stop to pid 2747 at 19/07/20 15:13:14]
2019-07-20 15:13:09.153640 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for LogitechVisionPro, no image since startup. Startup time was 1563624776 - now 1563624789 > 5]
2019-07-20 15:12:56.678369 zmc_dvideo0[2766].WAR-zm_local_camera.cpp/1793 [Hue control is not supported]
2019-07-20 15:12:56.642907 zmc_dvideo0[2766].INF-zmc.cpp/223 [Starting Capture version 1.32.3]
2019-07-20 15:12:56.635060 zmc_dvideo0[2766].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
2019-07-20 15:12:56.626514 zmc_dvideo0[2766].WAR-zm_local_camera.cpp/403 [Different capture sizes defined for monitors sharing same device, results may be unpredictable or completely wrong]
2019-07-20 15:12:56.616447 zmc_dvideo0[2766].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:12:56.599244 zmc_dvideo0[2766].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
2019-07-20 15:12:56.587270 zmc_dvideo0[2766].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:12:56.171470 zmdc[2766].INF-zmdc.pl ['zmc -d /dev/video0' started at 19/07/20 15:12:56]
2019-07-20 15:12:56.171430 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' starting at 19/07/20 15:12:56, pid = 2766]
2019-07-20 15:12:56.130630 zmdc[863].INF-zmdc.pl [Starting pending process, zmc -d /dev/video0]
2019-07-20 15:12:47.370890 zmdc[2758].INF-zmdc.pl ['zma -m 2' started at 19/07/20 15:12:47]
2019-07-20 15:12:47.370450 zmdc[863].INF-zmdc.pl ['zma -m 2' starting at 19/07/20 15:12:47, pid = 2758]
2019-07-20 15:12:46.746640 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' exited, signal 14]
2019-07-20 15:12:46.707280 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2750 at 19/07/20 15:12:46]
2019-07-20 15:12:45.792949 zmc_dvideo0[2750].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
2019-07-20 15:12:44.651920 zmdc[863].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2019-07-20 15:12:44.327591 zmc_dvideo0[2750].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:12:43.918050 zmdc[863].INF-zmdc.pl ['zma -m 2' sending stop to pid 2736 at 19/07/20 15:12:43]
2019-07-20 15:12:41.490780 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' starting at 19/07/20 15:12:41, pid = 2750]
2019-07-20 15:12:41.480210 zmdc[2750].INF-zmdc.pl ['zmc -d /dev/video0' started at 19/07/20 15:12:41]
2019-07-20 15:12:40.983310 zmdc[863].INF-zmdc.pl [Starting pending process, zmc -d /dev/video0]
2019-07-20 15:12:38.568020 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for PiCam, no image since startup. Startup time was 1563624668 - now 1563624758 > 5]
2019-07-20 15:12:36.073100 zmdc[2747].INF-zmdc.pl ['zma -m 1' started at 19/07/20 15:12:36]
2019-07-20 15:12:36.073070 zmdc[863].INF-zmdc.pl ['zma -m 1' starting at 19/07/20 15:12:36, pid = 2747]
2019-07-20 15:12:35.310810 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' exited, signal 14]
2019-07-20 15:12:35.276521 zmc_dvideo0[2737].WAR-zm_local_camera.cpp/403 [Different capture sizes defined for monitors sharing same device, results may be unpredictable or completely wrong]
2019-07-20 15:12:34.539380 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2737 at 19/07/20 15:12:34]
2019-07-20 15:12:33.887617 zmc_dvideo0[2737].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:12:33.804880 zmdc[863].INF-zmdc.pl ['zma -m 1' exited, signal 14]
2019-07-20 15:12:28.584988 zmc_dvideo0[2737].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
2019-07-20 15:12:25.089590 zmdc[863].INF-zmdc.pl ['zma -m 1' sending stop to pid 2729 at 19/07/20 15:12:25]
2019-07-20 15:12:22.577209 zmc_dvideo0[2737].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:12:20.680340 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for LogitechVisionPro, no image since startup. Startup time was 1563624668 - now 1563624740 > 5]
2019-07-20 15:12:19.268100 zmdc[2737].INF-zmdc.pl ['zmc -d /dev/video0' started at 19/07/20 15:12:19]
2019-07-20 15:12:19.268070 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' starting at 19/07/20 15:12:19, pid = 2737]
2019-07-20 15:12:15.206500 zmdc[863].INF-zmdc.pl [Starting pending process, zmc -d /dev/video0]
2019-07-20 15:12:12.586050 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' crashed, signal 8]
2019-07-20 15:12:11.657610 zmdc[863].WAR-zmdc.pl ['zmc -d /dev/video0' has not stopped at 19/07/20 15:12:11 after 60 seconds. Sending KILL to pid 2693]
2019-07-20 15:12:09.587320 zmdc[863].INF-zmdc.pl ['zma -m 2' starting at 19/07/20 15:12:09, pid = 2736]
2019-07-20 15:12:09.586670 zmdc[2736].INF-zmdc.pl ['zma -m 2' started at 19/07/20 15:12:09]
2019-07-20 15:12:08.973610 zmc_dvideo0[2693].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:12:06.895770 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2693 at 19/07/20 15:12:06]
2019-07-20 15:12:06.339050 zmdc[863].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2019-07-20 15:12:06.319690 zmdc[863].INF-zmdc.pl ['zma -m 2' sending stop to pid 2720 at 19/07/20 15:12:06]
2019-07-20 15:12:03.257250 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for PiCam, no image since startup. Startup time was 1563624668 - now 1563624723 > 5]
2019-07-20 15:12:02.330600 zmdc[863].INF-zmdc.pl ['zma -m 1' starting at 19/07/20 15:12:02, pid = 2729]
2019-07-20 15:12:02.330540 zmdc[2729].INF-zmdc.pl ['zma -m 1' started at 19/07/20 15:12:02]
2019-07-20 15:12:01.703094 zmc_dvideo0[2693].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:11:57.921150 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2693 at 19/07/20 15:11:57]
2019-07-20 15:11:55.199790 zmdc[863].INF-zmdc.pl ['zma -m 1' exited, signal 14]
2019-07-20 15:11:54.174550 zmdc[863].INF-zmdc.pl ['zma -m 1' sending stop to pid 2713 at 19/07/20 15:11:54]
2019-07-20 15:11:50.044270 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for LogitechVisionPro, no image since startup. Startup time was 1563624668 - now 1563624710 > 5]
2019-07-20 15:11:38.216100 zmdc[2720].INF-zmdc.pl ['zma -m 2' started at 19/07/20 15:11:38]
2019-07-20 15:11:38.213210 zmdc[863].INF-zmdc.pl ['zma -m 2' starting at 19/07/20 15:11:38, pid = 2720]
2019-07-20 15:11:37.598463 zmc_dvideo0[2693].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:11:37.585580 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2693 at 19/07/20 15:11:37]
2019-07-20 15:11:36.031920 zmdc[863].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2019-07-20 15:11:34.404670 zmdc[863].INF-zmdc.pl ['zma -m 2' sending stop to pid 2706 at 19/07/20 15:11:34]
2019-07-20 15:11:33.768150 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for PiCam, no image since startup. Startup time was 1563624668 - now 1563624693 > 5]
2019-07-20 15:11:30.777900 zmdc[2713].INF-zmdc.pl ['zma -m 1' started at 19/07/20 15:11:30]
2019-07-20 15:11:30.777870 zmdc[863].INF-zmdc.pl ['zma -m 1' starting at 19/07/20 15:11:30, pid = 2713]
2019-07-20 15:11:30.127834 zmc_dvideo0[2693].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:11:27.835860 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2693 at 19/07/20 15:11:27]
2019-07-20 15:11:25.028790 zmdc[863].INF-zmdc.pl ['zma -m 1' exited, signal 14]
2019-07-20 15:11:23.376880 zmdc[863].INF-zmdc.pl ['zma -m 1' sending stop to pid 2699 at 19/07/20 15:11:23]
2019-07-20 15:11:21.550390 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for LogitechVisionPro, no image since startup. Startup time was 1563624668 - now 1563624681 > 5]
2019-07-20 15:11:11.462620 zmdc[863].INF-zmdc.pl ['zma -m 2' starting at 19/07/20 15:11:11, pid = 2706]
2019-07-20 15:11:11.460840 zmdc[2706].INF-zmdc.pl ['zma -m 2' started at 19/07/20 15:11:11]
2019-07-20 15:11:10.829303 zmc_dvideo0[2693].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:11:08.825810 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2693 at 19/07/20 15:11:08]
2019-07-20 15:11:08.370697 zmc_dvideo0[2693].WAR-zm_local_camera.cpp/1793 [Hue control is not supported]
2019-07-20 15:11:08.234566 zmc_dvideo0[2693].INF-zmc.cpp/223 [Starting Capture version 1.32.3]
2019-07-20 15:11:08.208025 zmc_dvideo0[2693].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
2019-07-20 15:11:08.202760 zmdc[863].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2019-07-20 15:11:07.354340 zmc_dvideo0[2693].WAR-zm_local_camera.cpp/403 [Different capture sizes defined for monitors sharing same device, results may be unpredictable or completely wrong]
2019-07-20 15:11:05.058430 zmdc[863].INF-zmdc.pl ['zma -m 2' sending stop to pid 2681 at 19/07/20 15:11:05]
2019-07-20 15:11:04.477447 zmc_dvideo0[2693].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:11:04.389820 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for PiCam, no image since startup. Startup time was 1563624459 - now 1563624664 > 5]
2019-07-20 15:11:03.659267 zmc_dvideo0[2693].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
2019-07-20 15:11:03.633540 zmdc[2699].INF-zmdc.pl ['zma -m 1' started at 19/07/20 15:11:03]
2019-07-20 15:11:03.633520 zmdc[863].INF-zmdc.pl ['zma -m 1' starting at 19/07/20 15:11:03, pid = 2699]
2019-07-20 15:10:57.667329 zmc_dvideo0[2693].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:10:56.651890 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' starting at 19/07/20 15:10:56, pid = 2693]
2019-07-20 15:10:56.643700 zmdc[2693].INF-zmdc.pl ['zmc -d /dev/video0' started at 19/07/20 15:10:56]
2019-07-20 15:10:54.438760 zmdc[863].WAR-zmdc.pl [Can't find process with command of 'zmc -d /dev/video0']
2019-07-20 15:10:52.347620 zmdc[863].INF-zmdc.pl ['zma -m 1' exited, signal 14]
2019-07-20 15:10:49.936110 zmdc[863].INF-zmdc.pl ['zma -m 1' sending stop to pid 2670 at 19/07/20 15:10:49]
2019-07-20 15:10:48.630100 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for LogitechVisionPro, no image since startup. Startup time was 0 - now 1563624648 > 5]
2019-07-20 15:10:31.641430 zmdc[2681].INF-zmdc.pl ['zma -m 2' started at 19/07/20 15:10:31]
2019-07-20 15:10:31.640420 zmdc[863].INF-zmdc.pl ['zma -m 2' starting at 19/07/20 15:10:31, pid = 2681]
2019-07-20 15:10:29.474180 zmdc[863].INF-zmdc.pl [Command 'zmc -d /dev/video0' removed from pending list at 19/07/20 15:10:29]
2019-07-20 15:10:26.136180 zmdc[863].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2019-07-20 15:10:24.650180 zmdc[863].INF-zmdc.pl ['zma -m 2' sending stop to pid 2658 at 19/07/20 15:10:24]
2019-07-20 15:10:23.336870 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for PiCam, no image since startup. Startup time was 1563624459 - now 1563624623 > 5]
2019-07-20 15:10:17.708410 zmdc[863].INF-zmdc.pl ['zma -m 1' starting at 19/07/20 15:10:17, pid = 2670]
2019-07-20 15:10:17.708190 zmdc[2670].INF-zmdc.pl ['zma -m 1' started at 19/07/20 15:10:17]
2019-07-20 15:10:17.096430 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' exited, signal 14]
2019-07-20 15:10:17.084982 web_php[1892].ERR-/usr/share/zoneminder/www/includes/functions.php/2051 [No data to read from socket]
2019-07-20 15:10:17.084753 zmc_dvideo0[2662].WAR-zm_local_camera.cpp/403 [Different capture sizes defined for monitors sharing same device, results may be unpredictable or completely wrong]
2019-07-20 15:10:14.197249 web_php[1892].ERR-/usr/share/zoneminder/www/ajax/stream.php/90 [Timed out waiting for msg /var/run/zm/zms-588475s.sock]
2019-07-20 15:10:12.659455 zms_m2[2663].ERR-zm_monitorstream.cpp/713 [Terminating, last frame sent time 10.159279 secs more than maximum of 10.000000]
2019-07-20 15:10:12.447513 zmc_dvideo0[2662].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:10:12.349950 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2662 at 19/07/20 15:10:12]
2019-07-20 15:10:06.647420 zmdc[863].INF-zmdc.pl ['zma -m 1' exited, signal 14]
2019-07-20 15:10:06.630758 zmc_dvideo0[2662].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
2019-07-20 15:10:04.474536 zmc_dvideo0[2662].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:10:04.165100 zmdc[863].INF-zmdc.pl ['zma -m 1' sending stop to pid 2592 at 19/07/20 15:10:04]
2019-07-20 15:10:03.099554 zms_m2[2663].WAR-zm_monitorstream.cpp/711 [no last_frame_sent.  Shouldn't happen. frame_mod was (1) frame_count (0) ]
2019-07-20 15:10:01.999260 zmdc[2662].INF-zmdc.pl ['zmc -d /dev/video0' started at 19/07/20 15:10:01]
2019-07-20 15:10:01.994640 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' starting at 19/07/20 15:10:01, pid = 2662]
2019-07-20 15:10:00.524800 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for LogitechVisionPro, no image since startup. Startup time was 0 - now 1563624600 > 5]
2019-07-20 15:09:59.510890 zmdc[863].INF-zmdc.pl [Starting pending process, zmc -d /dev/video0]
2019-07-20 15:09:59.077973 web_js[2305].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-186361s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2019-07-20 15:09:58.989727 web_php[2305].ERR-/usr/share/zoneminder/www/includes/functions.php/2051 [Socket /var/run/zm/zms-186361s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2019-07-20 15:09:58.929603 zms_m2[2655].ERR-zm_monitorstream.cpp/713 [Terminating, last frame sent time 10.429453 secs more than maximum of 10.000000]
2019-07-20 15:09:50.468760 zmdc[863].INF-zmdc.pl ['zma -m 2' starting at 19/07/20 15:09:50, pid = 2658]
2019-07-20 15:09:50.466760 zmdc[2658].INF-zmdc.pl ['zma -m 2' started at 19/07/20 15:09:50]
2019-07-20 15:09:49.012780 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' exited, signal 14]
2019-07-20 15:09:48.927384 zms_m1[2603].ERR-zm_monitorstream.cpp/713 [Terminating, last frame sent time 10.427275 secs more than maximum of 10.000000]
2019-07-20 15:09:48.709744 zms_m2[2655].WAR-zm_monitorstream.cpp/711 [no last_frame_sent.  Shouldn't happen. frame_mod was (1) frame_count (0) ]
2019-07-20 15:09:48.274189 zmc_dvideo0[2593].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
2019-07-20 15:09:47.566814 zmc_dvideo0[2593].WAR-zm_local_camera.cpp/403 [Different capture sizes defined for monitors sharing same device, results may be unpredictable or completely wrong]
2019-07-20 15:09:46.860140 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2593 at 19/07/20 15:09:46]
2019-07-20 15:09:45.547807 zmc_dvideo0[2593].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:09:45.443380 zmdc[863].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2019-07-20 15:09:44.697744 zmc_dvideo0[2593].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
2019-07-20 15:09:42.626288 web_php[2145].ERR-/usr/share/zoneminder/www/ajax/stream.php/90 [Timed out waiting for msg /var/run/zm/zms-773808s.sock]
2019-07-20 15:09:41.587722 zmc_dvideo0[2593].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:09:39.280334 zms_m1[2603].WAR-zm_monitorstream.cpp/711 [no last_frame_sent.  Shouldn't happen. frame_mod was (1) frame_count (0) ]
2019-07-20 15:09:39.004990 zmdc[863].INF-zmdc.pl ['zma -m 2' sending stop to pid 2551 at 19/07/20 15:09:39]
2019-07-20 15:09:38.989168 web_php[1892].ERR-/usr/share/zoneminder/www/includes/functions.php/2051 [No data to read from socket]
2019-07-20 15:09:28.005470 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' starting at 19/07/20 15:09:27, pid = 2593]
2019-07-20 15:09:27.996940 zmdc[2593].INF-zmdc.pl ['zmc -d /dev/video0' started at 19/07/20 15:09:27]
2019-07-20 15:09:27.729248 web_php[1892].ERR-/usr/share/zoneminder/www/ajax/stream.php/90 [Timed out waiting for msg /var/run/zm/zms-314686s.sock]
2019-07-20 15:09:27.324570 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for PiCam, no image since startup. Startup time was 1563624459 - now 1563624567 > 5]
2019-07-20 15:09:25.852250 zmdc[863].INF-zmdc.pl [Starting pending process, zmc -d /dev/video0]
2019-07-20 15:09:25.678249 zms_m1[2585].ERR-zm_monitorstream.cpp/713 [Terminating, last frame sent time 10.177968 secs more than maximum of 10.000000]
2019-07-20 15:09:20.911610 zmdc[2592].INF-zmdc.pl ['zma -m 1' started at 19/07/20 15:09:20]
2019-07-20 15:09:20.909030 zmdc[863].INF-zmdc.pl ['zma -m 1' starting at 19/07/20 15:09:20, pid = 2592]
2019-07-20 15:09:20.191130 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' exited, signal 14]
2019-07-20 15:09:19.040511 web_php[1892].ERR-/usr/share/zoneminder/www/ajax/stream.php/90 [Timed out waiting for msg /var/run/zm/zms-314686s.sock]
2019-07-20 15:09:18.837505 zmc_dvideo0[2566].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:09:16.390370 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2566 at 19/07/20 15:09:16]
2019-07-20 15:09:15.953551 zms_m1[2585].WAR-zm_monitorstream.cpp/711 [no last_frame_sent.  Shouldn't happen. frame_mod was (1) frame_count (0) ]
2019-07-20 15:09:15.708770 zmdc[863].INF-zmdc.pl ['zma -m 1' exited, signal 14]
2019-07-20 15:09:15.696950 zmc_dvideo0[2566].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
2019-07-20 15:09:14.478040 zmdc[863].INF-zmdc.pl ['zma -m 1' sending stop to pid 2491 at 19/07/20 15:09:14]
2019-07-20 15:09:14.187410 zmc_dvideo0[2566].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:09:14.010984 web_php[2145].ERR-/usr/share/zoneminder/www/includes/functions.php/2051 [Socket /var/run/zm/zms-702575s.sock does not exist.  This file is created by zms, and since it does not exist, either zms did not run, or zms exited early.  Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly.  Make sure that ZM is actually recording.  If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2019-07-20 15:09:13.789302 web_js[2308].ERR-?view=watch [getStreamCmdResponse stream error: No data to read from socket - checkStreamForErrors()]
2019-07-20 15:09:13.662849 web_php[1892].ERR-/usr/share/zoneminder/www/includes/functions.php/2051 [No data to read from socket]
2019-07-20 15:09:13.648500 zmdc[863].ERR-zmdc.pl ['zmfilter.pl --filter_id=2 --daemon' exited abnormally, exit status 2]
2019-07-20 15:09:12.215924 web_php[1892].ERR-/usr/share/zoneminder/www/ajax/stream.php/90 [Timed out waiting for msg /var/run/zm/zms-702575s.sock]
2019-07-20 15:09:10.685139 zms_m1[2554].ERR-zm_monitorstream.cpp/713 [Terminating, last frame sent time 10.185011 secs more than maximum of 10.000000]
2019-07-20 15:09:09.988550 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for LogitechVisionPro, no image since startup. Startup time was 1563624459 - now 1563624549 > 5]
2019-07-20 15:09:09.424200 zmdc[2566].INF-zmdc.pl ['zmc -d /dev/video0' started at 19/07/20 15:09:09]
2019-07-20 15:09:09.420310 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' starting at 19/07/20 15:09:09, pid = 2566]
2019-07-20 15:09:06.086640 zmdc[863].INF-zmdc.pl [Starting pending process, zmc -d /dev/video0]
2019-07-20 15:09:05.071830 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' crashed, signal 8]
2019-07-20 15:09:04.909750 zmdc[863].WAR-zmdc.pl ['zmc -d /dev/video0' has not stopped at 19/07/20 15:09:04 after 60 seconds. Sending KILL to pid 2454]
2019-07-20 15:09:04.169540 zmdc[863].INF-zmdc.pl ['zmfilter.pl --filter_id=2 --daemon' starting at 19/07/20 15:09:04, pid = 2557]
2019-07-20 15:09:04.168950 zmdc[2557].INF-zmdc.pl ['zmfilter.pl --filter_id=2 --daemon' started at 19/07/20 15:09:04]
2019-07-20 15:09:00.823856 zms_m1[2554].WAR-zm_monitorstream.cpp/711 [no last_frame_sent.  Shouldn't happen. frame_mod was (1) frame_count (0) ]
2019-07-20 15:08:59.939170 zmdc[863].INF-zmdc.pl [Starting pending process, zmfilter.pl --filter_id=2 --daemon]
2019-07-20 15:08:55.548680 zmdc[863].INF-zmdc.pl ['zma -m 2' starting at 19/07/20 15:08:55, pid = 2551]
2019-07-20 15:08:55.541650 zmdc[2551].INF-zmdc.pl ['zma -m 2' started at 19/07/20 15:08:55]
2019-07-20 15:08:55.513430 zms_e25[2272].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:08:49.341920 zmdc[863].ERR-zmdc.pl ['zmaudit.pl -c' exited abnormally, exit status 255]
2019-07-20 15:08:49.341078 zmc_dvideo0[2454].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:08:47.916180 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2454 at 19/07/20 15:08:47]
2019-07-20 15:08:46.374480 zmdc[863].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2019-07-20 15:08:46.008610 zmdc[863].INF-zmdc.pl ['zma -m 2' sending stop to pid 2476 at 19/07/20 15:08:46]
2019-07-20 15:08:45.750990 zmaudit[2490].FAT-zmaudit.pl [zmaudit.pl appears to already be running at pid 966. If not, please delete /var/run/zm/zmaudit.pid or use the --force command line option.]
2019-07-20 15:08:44.765620 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for PiCam, no image since startup. Startup time was 1563624459 - now 1563624524 > 5]
2019-07-20 15:08:44.721840 zmdc[2491].INF-zmdc.pl ['zma -m 1' started at 19/07/20 15:08:44]
2019-07-20 15:08:44.720080 zmdc[863].INF-zmdc.pl ['zma -m 1' starting at 19/07/20 15:08:44, pid = 2491]
2019-07-20 15:08:44.695890 zmdc[2490].INF-zmdc.pl ['zmaudit.pl -c' started at 19/07/20 15:08:44]
2019-07-20 15:08:44.694310 zmdc[863].INF-zmdc.pl ['zmaudit.pl -c' starting at 19/07/20 15:08:44, pid = 2490]
2019-07-20 15:08:43.941960 zmdc[863].INF-zmdc.pl [Starting pending process, zmaudit.pl -c]
2019-07-20 15:08:43.941269 zmc_dvideo0[2454].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:08:36.144090 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2454 at 19/07/20 15:08:36]
2019-07-20 15:08:33.234600 zmdc[863].INF-zmdc.pl ['zma -m 1' exited, signal 14]
2019-07-20 15:08:29.497950 zmdc[863].INF-zmdc.pl ['zma -m 1' sending stop to pid 2469 at 19/07/20 15:08:29]
2019-07-20 15:08:26.084290 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for LogitechVisionPro, no image since startup. Startup time was 1563624459 - now 1563624506 > 5]
2019-07-20 15:08:18.733240 zmdc[863].ERR-zmdc.pl ['zmfilter.pl --filter_id=1 --daemon' exited abnormally, exit status 2]
2019-07-20 15:08:16.143900 zmdc[2477].INF-zmdc.pl ['zmfilter.pl --filter_id=1 --daemon' started at 19/07/20 15:08:16]
2019-07-20 15:08:16.143090 zmdc[863].INF-zmdc.pl ['zmfilter.pl --filter_id=1 --daemon' starting at 19/07/20 15:08:16, pid = 2477]
2019-07-20 15:08:16.064090 zmdc[863].INF-zmdc.pl [Starting pending process, zmfilter.pl --filter_id=1 --daemon]
2019-07-20 15:08:11.755560 zmdc[863].INF-zmdc.pl ['zma -m 2' starting at 19/07/20 15:08:11, pid = 2476]
2019-07-20 15:08:11.752280 zmdc[2476].INF-zmdc.pl ['zma -m 2' started at 19/07/20 15:08:11]
2019-07-20 15:08:11.172083 zmc_dvideo0[2454].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:08:09.806470 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2454 at 19/07/20 15:08:09]
2019-07-20 15:08:09.254040 zmdc[863].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2019-07-20 15:08:09.232130 zmdc[863].INF-zmdc.pl ['zma -m 2' sending stop to pid 2458 at 19/07/20 15:08:09]
2019-07-20 15:08:08.619760 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for PiCam, no image since startup. Startup time was 1563624459 - now 1563624488 > 5]
2019-07-20 15:08:03.396130 zmdc[863].INF-zmdc.pl ['zma -m 1' starting at 19/07/20 15:08:03, pid = 2469]
2019-07-20 15:08:03.392740 zmdc[2469].INF-zmdc.pl ['zma -m 1' started at 19/07/20 15:08:03]
2019-07-20 15:08:02.783562 zmc_dvideo0[2454].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-07-20 15:08:00.204090 zmdc[863].INF-zmdc.pl ['zmc -d /dev/video0' sending stop to pid 2454 at 19/07/20 15:08:00]
2019-07-20 15:07:58.633580 zmdc[863].INF-zmdc.pl ['zma -m 1' exited, signal 14]
2019-07-20 15:07:56.345080 zmdc[863].INF-zmdc.pl ['zma -m 1' sending stop to pid 2457 at 19/07/20 15:07:56]
2019-07-20 15:07:53.533820 zmwatch[972].INF-zmwatch.pl [Restarting capture daemon for LogitechVisionPro, no image since startup. Startup time was 1563624459 - now 1563624473 > 5]
2019-07-20 15:07:47.879790 zmdc[863].INF-zmdc.pl ['zma -m 2' starting at 19/07/20 15:07:47, pid = 2458]
2019-07-20 15:07:47.875670 zmdc[2458].INF-zmdc.pl ['zma -m 2' started at 19/07/20 15:07:47]
2019-07-20 15:07:47.522500 zmdc[863].INF-zmdc.pl [Starting pending process, zma -m 2]
2019-07-20 15:07:40.050640 zmdc[863].INF-zmdc.pl ['zma -m 1' starting at 19/07/20 15:07:40, pid = 2457]
2019-07-20 15:07:40.029590 zmdc[2457].INF-zmdc.pl ['zma -m 1' started at 19/07/20 15:07:40]
2019-07-20 15:07:39.441168 zmc_dvideo0[2454].WAR-zm_local_camera.cpp/1793 [Hue control is not supported]
2019-07-20 15:07:39.392795 zmc_dvideo0[2454].INF-zmc.cpp/223 [Starting Capture version 1.32.3]
2019-07-20 15:07:39.360477 zmc_dvideo0[2454].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
2019-07-20 15:07:39.349931 zmc_dvideo0[2454].WAR-zm_local_camera.cpp/403 [Different capture sizes defined for monitors sharing same device, results may be unpredictable or completely wrong]
2019-07-20 15:07:39.335952 zmc_dvideo0[2454].INF-zm_local_camera.cpp/385 [Selected capture palette: YUYV 4:2:2 (0x56595559)]
2019-07-20 15:07:39.307952 zmc_dvideo0[2454].INF-zm_local_camera.cpp/447 [No direct match for the selected palette (0x00000001) and target colorspace (04). Format conversion is required, performance penalty expected]
mikb
Post by mikb »
bbunge wrote: Sat Jul 20, 2019 12:29 am Video does not work on a Pi
I get you that you mean that Zoneminder does not support video directly from the hardware camera, rather than literally as written :)
I don't know if this would work in practice, but, there are streamer programs which will take /dev/video0 (from the hardware camera, from a USB camera) and convert it into a web-streamable resource. Using one of those running on the PI would allow Zoneminder to connect to that program locally as if the on-board PI Camera was now an IP camera.
I think somewhere in the options for FFMPEG it can be convinced to do this, but there are standalone programs for it too.
