[SOLVED] 404 RTSP
foxtrot1014
[SOLVED] 404 RTSP
Post by foxtrot1014 »
After that annoying pop up telling me for months that there was an update to ZM, I updated myself to Ubuntu Server Bionic Beaver (18.04.x) and Zoneminder 1.32.x
Before doing so, I took screenshots of all the configurations for the camera. Once everything was done updating and it was time to configure, I set things up exactly the same as before, but my log keeps saying "No RTSP sources", "Unexpected response code 404, text is 'Stream Not Found'", and a few apparently related errors... here's the log:
zm-log.txt
(434.34 KiB) Downloaded 138 times
The camera itself is working correctly. I can watch both feeds in VLC using the MRL "rtsp://username:password@10.0.0.41:554//Streaming/Channels/[0 or 1]"
I tried messing with some settings on the camera to no avail, such as using H265 instead of H264 and changing the resolution from 4K to 1080P.
Should I just downgrade everything?
Re: 404 RTSP
Likely in doing the upgrade to Bionic you ended up with two versions of PHP. Bionic uses PHP 7.2 so you need to uninstall the older version.
foxtrot1014
Re: 404 RTSP
bbunge wrote: Sun Jul 14, 2019 12:39 am Likely in doing the upgrade...
I could and should have been a little bit more precise in how I worded things. In the process of "upgrading" to Bionic and ZM 1.32, I upgraded the hard drive for a freshly formatted (and much larger) one. So, my Ubuntu/ZM upgrades were actually clean installations on the computer (though an 'upgrade' from my perspective). And when I say clean installation, I mean clean, I even cleared the CMOS.
Unfortunately for me, that's not the solution.
Thanks for the suggestion though! Any other ideas?
foxtrot1014
Re: 404 RTSP
Partially solved!
Instead of using "remote" as the source type, I went with ffmpeg and used the mrl format for the source path rtsp://[user]:[password]@[ip]:[port,probably554]//Streaming/Channels/[0 or 1], method was UDP.
Just started trying different settings and it happened. Strangely, I know for a fact, that with the prior versions I was operating ffmpeg didn't work. Now it does.
Conversely, I still have a problem (probably for a new thread?). My camera has 4K resolution output, and in the past it worked just fine. Now at 4K, I can't see 80% of the frames and the ones that do, only 1/4 of them is visible--lots of grays, greens and blurriness. When I step it down to 1080P, the pixelation reduces but there is still a lot of glitchiness in the feed.
What's going on? Is the newer version of Zoneminder more CPU intensive? I don't recall my load going above 1.00 in the past, with 4K it was at 1.3 and higher. Now at 1080P it's floating around 1.00 (some above some below).
Baylink
Re: [SOLVED] 404 RTSP
Post by Baylink »
You opened a separate thread for that, and got it resolved, right?
