The user specified as a definer ('debian-sys-maint'@'localhost') does not exist
craver84
Post by craver84 » Tue Jul 02, 2019 1:34 pm
I've just installed Debian 9.9.0 with zoneminder 1.32.3 and I imported my old DB backup (it came from Ubuntu 18.04)
mysql  --user=root --password=[password] zm      < ZMbackup.SQL
but I have problems with the user that zm use to connect to the db
ZM LOG:
TRIGGER command denied to user 'debian-sys-maint'@'localhost' for table 'Events_Month'
I tried to add a new user to mysql with the same root password, but it doesn't work...
MariaDB [mysql]> select User,Password from mysql.user;
| User             | Password                                  |
| root             |                                           |
| zmuser           | *C1D2D6FC5C596AFB19FFC4331DF6DAA287749A3E |
| debian-sys-maint | *B332BC835CE65A37167E623E25F1F660A850C7BE |
how can I solve it?
may I use zmuser to connect to the db?
many thanks
Paolo
AfricanSwallow
Re: The user specified as a definer ('debian-sys-maint'@'localhost') does not exist
Post by AfricanSwallow » Wed Jul 03, 2019 6:44 pm
is there a reason your zoneminder is using debian-sys-maint user instead of zmuser? Does the user/pass configured in /etc/zm/zm.conf allow you to login using mysql client manually from command line?
mysql -u zmuser -pzmpass
or
mysql -u debian-sys-maint -pzmpass
are you using debian-sys-maint to perform backups? if so, zoneminder should not be using that user necessarily, but just give that user read permissions to the zm database so it can perform those backups. You can also change the password for that user if you do wish to continue using it for zoneminder, but that may break functionality elsewhere if you are using that same mysql user for other tasks on the system.
I'd say either use the existing zmuser/zmpass or create a new one specifically for zoneminder and restart:
CREATE USER 'zmuser'@'localhost' IDENTIFIED BY 'yourZMPass';
GRANT ALL PRIVILEGES ON zm.* TO 'zmuser'@'localhost';
Then edit your /etc/zm/zm.conf file and update accordingly. NOTE! You will also need to modify for your api configuration as i believe that is only configured during installation and if the msyql user is changed after that, api will break. I believe the file is /usr/share/zoneminder/www/api/app/Config/database.php and you'll want to modify this entry:
public $default = array(
'datasource' => 'Database/Mysql',
'persistent' => false,
'login' => ZM_DB_USER,
'password' => ZM_DB_PASS,
'database' => ZM_DB_NAME,
//'ssl_ca' => ZM_DB_SSL_CA_CERT,
//'ssl_key' => ZM_DB_SSL_CLIENT_KEY,
//'ssl_cert' => ZM_DB_SSL_CLIENT_CERT,
'prefix' => '',
'encoding' => 'utf8',
Restart zoneminder afterwards.
Hope that helps,
AfricanSwallow
nixcamic
Post by nixcamic » Tue Dec 03, 2019 3:18 pm
Sorry to zombie this but I'm having the exact same problem. Where is zmstats.pl pulling the debian-sys-maint user from?
nixcamic
Post by nixcamic » Tue Dec 03, 2019 5:11 pm
So, it seems zoneminder was pulling debian-sys-maint@localhost from the definer for the triggers under zones and events in the SQL database. I changed it to zmuser@localhost and now it's working fine.
For whoever next has this issue, hopefully you don't have to grep a string on your whole hard drive to find out where the heck ZM is getting it from :D
Users browsing this forum: No registered users and 0 guests
