Distroted video over time - RESOLVED
tapstah
Post by tapstah »
Okay. I believe I have gone through all of the online docs with no luck, and I searched the forum but didn't find something precisely inline.
Zoneminder 1.32.3
os: Ubuntu 18.04.2
Camera: Hosafe H2MD4A
Screen shots included.
Having a persistent problem with just the hosafe cameras. I have other camera types that run fine, so it shouldn't be install specific, I don't think.
This camera works great, love the camera, plan on getting more but I need to sort out this issue first. When the camera has been running on mocord for longer than 15 hours it starts to get distorted, as in the image attached (see when running fine vs when not). It used to be this would happen within an hour, I changed the fps settings and the problem now takes several hours.
Any ideas where to start? Let me know if there is anything needed. Thanks in advance folks.
Screenshot_2019-06-05 ZM - Garage (2) - Feed.jpg (921.22 KiB) Viewed 5005 times
Screenshot_2019-06-05 ZM - Monitor - Garage (2)(1).png (14.98 KiB) Viewed 5005 times
Screenshot_2019-06-05 ZM - Garage (2) - Feed(1).jpg (380.41 KiB) Viewed 5005 times
tapstah
Re: Distroted video over time
Post by tapstah »
more photos...
Screenshot_2019-06-05 ZM - Monitor - Garage (2)(4).png (10.62 KiB) Viewed 5004 times
Screenshot_2019-06-05 ZM - Monitor - Garage (2)(3).png (8.9 KiB) Viewed 5004 times
Screenshot_2019-06-05 ZM - Monitor - Garage (2)(2).png (12.74 KiB) Viewed 5004 times
tapstah
Post by tapstah »
more...
Screenshot_2019-06-05 ZM - Monitor - Garage (2).png (19.89 KiB) Viewed 5003 times
Screenshot_2019-06-05 ZM - Monitor - Garage (2)(5).png (17.76 KiB) Viewed 5003 times
kitkat
Post by kitkat »
Have you tried using H.264 Passthrough as the Video Writer, instead of X.264 Encode?
tapstah
Post by tapstah »
kitkat wrote: Wed Jun 05, 2019 10:53 pm Have you tried using H.264 Passthrough as the Video Writer, instead of X.264 Encode?
No, I haven't. Just switched the setting now. I'll report back how it performs!
snake
Re: Distorted video over time
Post by snake »
You shouldn't have Max FPS set on ZM for FFMPEG, generally. See the help icon next to it. Leave that blank.
If that doesn't solve it, search around these forums. Some people have had screen tearing and artifacts solved with a variety of solution such as:
Force TCP or UDP mode on camera.
Lower camera FPS (on camera not on ZM)
Increase key frame rate
Try libVLC instead of FFMPEG
Increase CAPTURES_PER_FRAME to 2 or 3
Lower resolution of camera
Double down on the no MaxFPS/AlarmMaxFPS. Those were needed for 1.30 but cause problems for 1.32. They starve ffmpeg for cpu.
You are already using TCP, so that's fine.
increasing key frame rate should cause it to correct faster
CAPTURES_PER_FRAME is not applicable to FFMPEG
I have seen this too on my crappy cameras, and I have resolved it, so do not despair. I think it is likely the MaxFPS/AlarmMaxFPS
There is a lot of great work in our master branch which may help. Feel free to upgrade to it. We are basically in feature freeze and just fixing bugs/updating docs before 1.34. it is safe to upgrade.
tapstah
Post by tapstah »
All great replys. Sorry it took so long to reply - I was waiting to see if the issue was resolved. Kitkat's solution of x.264 Passthrough was the answer. I had already been tweaking with all of the other options for some time and it only made incremental improvements but the passthrough solved it. Thanks a ton!
