Linked cameras don't keep in sync
ckilner
Post by ckilner »
I have a low res camera running modect and a linked high res version of the same camera running nodect.
It appears that close-together events triggered by the low res camera are not recorded by the high res camera. For example, if two events are triggered close together, I only get the first one recorded by the high res version of the camera and the second event disappears.
Anyone else seen this behaviour?
RusFM
Re: Linked cameras don't keep in sync
Post by RusFM »
I recently switched from 1.30 on a VM to 1.32 on a physical server and have a similar setup. The low res feeds trigger the high res feeds for recording.
I'm also seeing where not all low res events are being recorded by the high res feeds. I've troubleshot a good bit and see nothing wrong with the config.
I just looked at a few and they are not close together however. Sometimes they just don't record.
Rus
