Connecting Wyze V2 to Zoneminder
SeattleMike
Post by SeattleMike »
(If this isn't the right board for this issue, my apologies in advance.)
At the moment I have an Amcrest IP2M-841 and a Foscam R2 both working very well in ZM. So far, so good. :D
I also have a Wyze V2 camera flashed with the beta FW from Wyze that supports RTSP. The camera works correctly in the Wyze app. The connect string that the app generates is:
rtsp://<name>:<password>@192.168.254.53/live
I'm trying to connect it to Zoneminder but I'm having no luck. I'm pretty sure it's just a matter of settings but I've tried about 40 kabillion variations with no luck. I search the forum but didn't find anything that got me going (if I missed a particular post that would point me in the right direction, please let me know) .
Has anyone gotten the Wyze V2 stock FW camera to connect, and if so, could you share your settings?
I'm running ZM 1.32.3 (flatpack version, Ubuntu via Ian Connor's PPA https://launchpad.net/~iconnor/+archive ... zoneminder)
OS: Linux Mint Tessa
I've pasted in the ZM Log file below.
I can send screenshots but I thought I'd ask first to see if this was a known and/or solved camera setup. Please let me know if you'd like screen shots of the (non-working) Wyze settings.
If there's anything else I can provide, please let me know and I'll be glad to find and post it here.
ZM log file: (The camera name and password'have been replaced for security)
2019-05-17 07:32:35.334290 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:341800 - Capturing at 10.00 fps, capturing bandwidth 19896bytes/sec]
2019-05-17 07:32:34.358264 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:4200 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:32:30.106080 zmdc[1091].INF-zmdc.pl [Command 'zmc -m 11' removed from pending list at 19/05/17 07:32:30]
2019-05-17 07:32:29.966680 zmdc[1091].INF-zmdc.pl ['zmc -m 11' exited normally]
2019-05-17 07:32:29.913790 zmwatch[1182].INF-zmwatch.pl [Restarting capture daemon for WyzeCam1, no image since startup. Startup time was 1558103539 - now 1558103549 > 5]
2019-05-17 07:32:25.335125 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:341700 - Capturing at 10.00 fps, capturing bandwidth 20055bytes/sec]
2019-05-17 07:32:24.271798 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:4100 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:32:19.858834 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:32:19.850000 zmdc[1091].INF-zmdc.pl ['zmc -m 11' sending stop to pid 17908 at 19/05/17 07:32:19]
2019-05-17 07:32:19.810548 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:32:19.757671 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:32:19.675370 zmwatch[1182].INF-zmwatch.pl [Restarting capture daemon for WyzeCam1, no image since startup. Startup time was 1558103529 - now 1558103539 > 5]
2019-05-17 07:32:15.338440 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:341600 - Capturing at 10.00 fps, capturing bandwidth 19767bytes/sec]
2019-05-17 07:32:14.189128 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:4000 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:32:09.707284 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:32:09.659724 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:32:09.622168 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:32:05.337236 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:341500 - Capturing at 10.00 fps, capturing bandwidth 20019bytes/sec]
2019-05-17 07:32:04.104660 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:3900 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:32:00.379760 zmfilter_1[1167].INF-zmfilter.pl [Checking filter PurgeWhenFull delete returned 0 events ]
2019-05-17 07:32:00.304710 zmfilter_2[1171].INF-zmfilter.pl [Checking filter Update DiskSpace update disk space returned 0 events ]
2019-05-17 07:31:59.580118 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:31:59.544117 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:31:59.501465 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:31:55.333511 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:341400 - Capturing at 10.00 fps, capturing bandwidth 19815bytes/sec]
2019-05-17 07:31:54.020884 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:3800 - Capturing at 9.09 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:31:49.451008 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:31:49.400362 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:31:49.341776 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:31:45.334577 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:341300 - Capturing at 10.00 fps, capturing bandwidth 19974bytes/sec]
2019-05-17 07:31:43.886990 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:3700 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:31:39.291646 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:31:39.243018 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:31:39.198088 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:31:35.333731 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:341200 - Capturing at 10.00 fps, capturing bandwidth 19885bytes/sec]
2019-05-17 07:31:33.803835 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:3600 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:31:29.156174 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:31:29.116491 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:31:29.072126 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:31:25.336682 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:341100 - Capturing at 10.00 fps, capturing bandwidth 20088bytes/sec]
2019-05-17 07:31:23.721111 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:3500 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:31:19.030018 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:31:18.990685 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:31:18.944464 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:31:15.337200 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:341000 - Capturing at 10.00 fps, capturing bandwidth 19873bytes/sec]
2019-05-17 07:31:13.629560 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:3400 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:31:08.894149 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:31:08.845609 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:31:08.742690 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:31:05.336102 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:340900 - Capturing at 10.00 fps, capturing bandwidth 19947bytes/sec]
2019-05-17 07:31:03.548023 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:3300 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:31:00.327840 zmfilter_1[1167].INF-zmfilter.pl [Checking filter PurgeWhenFull delete returned 0 events ]
2019-05-17 07:31:00.262170 zmfilter_2[1171].INF-zmfilter.pl [Checking filter Update DiskSpace update disk space returned 0 events ]
2019-05-17 07:30:58.692347 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:30:58.645246 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:30:58.591032 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:30:55.335130 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:340800 - Capturing at 10.00 fps, capturing bandwidth 19977bytes/sec]
2019-05-17 07:30:53.454567 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:3200 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:30:48.549101 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:30:48.509414 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:30:48.464605 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:30:45.336316 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:340700 - Capturing at 10.00 fps, capturing bandwidth 20300bytes/sec]
2019-05-17 07:30:43.364026 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:3100 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:30:38.414257 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:30:38.365930 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:30:38.295005 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:30:35.361017 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:340600 - Capturing at 10.00 fps, capturing bandwidth 19868bytes/sec]
2019-05-17 07:30:33.278180 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:3000 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:30:28.244448 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:30:28.195953 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:30:28.143351 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:30:25.337532 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:340500 - Capturing at 10.00 fps, capturing bandwidth 19830bytes/sec]
2019-05-17 07:30:23.186778 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:2900 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:30:18.101404 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:30:18.062453 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:30:18.017841 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:30:15.341488 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:340400 - Capturing at 10.00 fps, capturing bandwidth 19918bytes/sec]
2019-05-17 07:30:13.099310 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:2800 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:30:07.908250 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:30:07.865930 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:30:07.789870 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:30:05.341384 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:340300 - Capturing at 10.00 fps, capturing bandwidth 19948bytes/sec]
2019-05-17 07:30:03.009404 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:2700 - Capturing at 9.09 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:30:00.273260 zmfilter_1[1167].INF-zmfilter.pl [Checking filter PurgeWhenFull delete returned 0 events ]
2019-05-17 07:30:00.215100 zmfilter_2[1171].INF-zmfilter.pl [Checking filter Update DiskSpace update disk space returned 0 events ]
2019-05-17 07:29:57.739392 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:29:57.691728 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:29:57.637555 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:29:55.337233 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:340200 - Capturing at 10.00 fps, capturing bandwidth 20057bytes/sec]
2019-05-17 07:29:52.918425 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:2600 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:29:47.587231 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:29:47.540519 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:29:47.486222 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:29:45.340369 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:340100 - Capturing at 10.00 fps, capturing bandwidth 19904bytes/sec]
2019-05-17 07:29:42.826927 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:2500 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:29:37.444109 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:29:37.404025 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:29:37.359563 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:29:35.338561 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:340000 - Capturing at 10.00 fps, capturing bandwidth 20134bytes/sec]
2019-05-17 07:29:32.739423 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:2400 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:29:27.309131 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:29:27.262999 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:29:27.208065 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:29:25.338574 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:339900 - Capturing at 10.00 fps, capturing bandwidth 20001bytes/sec]
2019-05-17 07:29:22.650129 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:2300 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:29:17.157607 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:29:17.109886 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:29:17.071790 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:29:15.337519 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:339800 - Capturing at 10.00 fps, capturing bandwidth 19869bytes/sec]
2019-05-17 07:29:12.559324 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:2200 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:29:07.029766 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:29:06.989715 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:29:06.953390 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:29:05.336790 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:339700 - Capturing at 10.00 fps, capturing bandwidth 20112bytes/sec]
2019-05-17 07:29:02.475688 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:2100 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:29:00.224840 zmfilter_1[1167].INF-zmfilter.pl [Checking filter PurgeWhenFull delete returned 0 events ]
2019-05-17 07:29:00.172980 zmfilter_2[1171].INF-zmfilter.pl [Checking filter Update DiskSpace update disk space returned 0 events ]
2019-05-17 07:28:56.911269 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:28:56.874457 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:28:56.685493 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:28:55.337729 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:339600 - Capturing at 10.00 fps, capturing bandwidth 19955bytes/sec]
2019-05-17 07:28:52.389871 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:2000 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:28:46.635085 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:28:46.586941 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:28:46.533777 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:28:45.336317 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:339500 - Capturing at 10.00 fps, capturing bandwidth 19951bytes/sec]
2019-05-17 07:28:42.302309 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:1900 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:28:36.483473 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:28:36.431218 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:28:36.365018 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:28:35.338969 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:339400 - Capturing at 10.00 fps, capturing bandwidth 20055bytes/sec]
2019-05-17 07:28:32.220214 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:1800 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:28:26.322872 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:28:26.282962 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:28:26.238675 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:28:25.335615 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:339300 - Capturing at 10.00 fps, capturing bandwidth 19828bytes/sec]
2019-05-17 07:28:22.136200 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:1700 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:28:16.196516 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:28:16.156858 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:28:16.112518 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:28:15.336744 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:339200 - Capturing at 10.00 fps, capturing bandwidth 19779bytes/sec]
2019-05-17 07:28:12.054979 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:1600 - Capturing at 9.09 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:28:06.061847 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:28:06.015826 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:28:05.969312 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:28:05.335656 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:339100 - Capturing at 10.00 fps, capturing bandwidth 20086bytes/sec]
2019-05-17 07:28:01.970268 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:1500 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:28:00.165450 zmfilter_1[1167].INF-zmfilter.pl [Checking filter PurgeWhenFull delete returned 0 events ]
2019-05-17 07:28:00.123710 zmfilter_2[1171].INF-zmfilter.pl [Checking filter Update DiskSpace update disk space returned 0 events ]
2019-05-17 07:27:55.918878 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:27:55.870227 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:27:55.818219 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:27:55.337186 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:339000 - Capturing at 10.00 fps, capturing bandwidth 19878bytes/sec]
2019-05-17 07:27:51.892349 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:1400 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:27:45.767827 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:27:45.719905 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:27:45.665556 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:27:45.337448 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:338900 - Capturing at 10.00 fps, capturing bandwidth 19791bytes/sec]
2019-05-17 07:27:41.809383 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:1300 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:27:35.623632 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:27:35.583779 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:27:35.539219 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:27:35.338818 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:338800 - Capturing at 10.00 fps, capturing bandwidth 19762bytes/sec]
2019-05-17 07:27:31.723758 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:1200 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:27:25.489048 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:27:25.441094 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:27:25.354656 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:27:25.337039 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:338700 - Capturing at 10.00 fps, capturing bandwidth 19812bytes/sec]
2019-05-17 07:27:21.636310 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:1100 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:27:15.338190 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:338600 - Capturing at 10.00 fps, capturing bandwidth 19672bytes/sec]
2019-05-17 07:27:15.304256 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:27:15.251935 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:27:15.195172 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:27:11.550673 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:1000 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:27:05.337831 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:338500 - Capturing at 10.00 fps, capturing bandwidth 20751bytes/sec]
2019-05-17 07:27:05.144709 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:27:05.096805 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:27:05.043789 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:27:01.462637 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:900 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:27:00.110540 zmfilter_1[1167].INF-zmfilter.pl [Checking filter PurgeWhenFull delete returned 0 events ]
2019-05-17 07:27:00.061260 zmfilter_2[1171].INF-zmfilter.pl [Checking filter Update DiskSpace update disk space returned 0 events ]
2019-05-17 07:26:55.337106 zmc_m3[7352].INF-zm_monitor.cpp/2477 [Interior-1: images:338400 - Capturing at 10.00 fps, capturing bandwidth 20118bytes/sec]
2019-05-17 07:26:55.001527 zmc_m11[17908].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-05-17 07:26:54.962171 zmc_m11[17908].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast due to: Operation now in progress]
2019-05-17 07:26:54.918302 zmc_m11[17908].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast]
2019-05-17 07:26:54.875074 zmc_m11[17908].INF-zmc.cpp/223 [Starting Capture version 1.32.3]
2019-05-17 07:26:54.770650 zmdc[17908].INF-zmdc.pl ['zmc -m 11' started at 19/05/17 07:26:54]
2019-05-17 07:26:54.770640 zmdc[1091].INF-zmdc.pl ['zmc -m 11' starting at 19/05/17 07:26:54, pid = 17908]
2019-05-17 07:26:54.730120 zmdc[1091].INF-zmdc.pl [Starting pending process, zmc -m 11]
2019-05-17 07:26:51.376204 zmc_m10[17818].INF-zm_monitor.cpp/2477 [Foscam1: images:800 - Capturing at 10.00 fps, capturing bandwidth 0bytes/sec]
2019-05-17 07:26:49.676180 zmdc[1091].INF-zmdc.pl ['zmc -m 11' exited normally]
2019-05-17 07:26:49.616184 zmc_m11[17905].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-05-17 07:26:49.569600 zmdc[1091].INF-zmdc.pl ['zmc -m 11' sending stop to pid 17905 at 19/05/17 07:26:49]
2019-05-17 07:26:49.401930 zmwatch[1182].INF-zmwatch.pl [Restarting capture daemon for WyzeCam1, no image since startup. Startup time was 1558103200 - now 1558103209 > 5]
BaseballSS
Re: Connecting Wyze V2 to Zoneminder
Post by BaseballSS »
What is the correct url? rtsp://<name>:<password>@192.168.254.53/live or rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast?
SeattleMike
BaseballSS wrote: Fri May 17, 2019 6:00 pm What is the correct url? rtsp://<name>:<password>@192.168.254.53/live or rtsp://<cameraname>:<password>@192.168.254.62:8554/unicast?
I don't know, I've been trying a variety of settings and strings to see if any of them would do anything. No luck so far.
The Wyze app generates this URL:
rtsp://<name]>:<password>@192.168.254.53/live
So that's probably the correct string, and it's what I've been using. (It's possible some of the lines in the log show entries from when I was trying other URLs. I've pasted in a more recent log entry using that as the URL.)
I'd use that string in ZM but I don't know what the other settings should be.
For example, in the General tab. What should I be using for Source Type? Ffmpeg, Remote, Libvlc...?
And in the Source tab, what should I use for the Source Path, Method, and Options (if any)?
More recent log entry (some of the Wyze entries are highlighted):
2019-05-17 15:11:55 zmdc 1091 INF Starting pending process, zmc -m 11 zmdc.pl
2019-05-17 15:11:55 zmdc 1091 INF 'zmc -m 11' starting at 19/05/17 15:11:55, pid = 27971 zmdc.pl
2019-05-17 15:11:55 zmdc 27971 INF 'zmc -m 11' started at 19/05/17 15:11:55 zmdc.pl
2019-05-17 15:11:55 zmc_m11 27971 INF Starting Capture version 1.32.3 zmc.cpp 223
2019-05-17 15:11:55 zmc_m11 27971 INF Priming capture from rtsp://<name>:<pass>@192.168.254.53/live zm_libvlc_camera.cpp 160
2019-05-17 15:11:54 zmc_m10 20616 INF Foscam1: images:331200 - Capturing at 16.67 fps, capturing bandwidth 0bytes/sec zm_monitor.cpp 2477
2019-05-17 15:11:51 zmc_m3 20667 INF Interior-1: images:221600 - Capturing at 9.09 fps, capturing bandwidth 21605bytes/sec zm_monitor.cpp 2477
2019-05-17 15:11:50 zmdc 1091 INF 'zmc -m 11' exited normally zmdc.pl
2019-05-17 15:11:49 zmwatch 1182 INF Restarting capture daemon for WyzeCam1, no image since startup. Startup time was 1558131101 - now 1558131109 > 5 zmwatch.pl
2019-05-17 15:11:49 zmdc 1091 INF 'zmc -m 11' sending stop to pid 27949 at 19/05/17 15:11:49 zmdc.pl
2019-05-17 15:11:49 zmc_m11 27949 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2019-05-17 15:11:48 zmc_m10 20616 INF Foscam1: images:331100 - Capturing at 14.29 fps, capturing bandwidth 0bytes/sec zm_monitor.cpp 2477
2019-05-17 15:11:41 zmc_m10 20616 INF Foscam1: images:331000 - Capturing at 14.29 fps, capturing bandwidth 0bytes/sec zm_monitor.cpp 2477
2019-05-17 15:11:41 zmdc 1091 INF Starting pending process, zmc -m 11 zmdc.pl
2019-05-17 15:11:41 zmdc 1091 INF 'zmc -m 11' starting at 19/05/17 15:11:41, pid = 27949 zmdc.pl
2019-05-17 15:11:41 zmdc 27949 INF 'zmc -m 11' started at 19/05/17 15:11:41 zmdc.pl
2019-05-17 15:11:41 zmc_m11 27949 INF Priming capture from rtsp://<name>:<pass>@192.168.254.53/live zm_libvlc_camera.cpp 160
2019-05-17 15:11:41 zmc_m11 27949 INF Starting Capture version 1.32.3 zmc.cpp 223
2019-05-17 15:11:40 zmdc 1091 INF 'zmc -m 11' exited normally zmdc.pl
2019-05-17 15:11:40 zmc_m3 20667 INF Interior-1: images:221500 - Capturing at 11.11 fps, capturing bandwidth 26462bytes/sec zm_monitor.cpp 2477
2019-05-17 15:11:39 zmwatch 1182 INF Restarting capture daemon for WyzeCam1, no image since startup. Startup time was 1558131089 - now 1558131099 > 5 zmwatch.pl
2019-05-17 15:11:39 zmdc 1091 INF 'zmc -m 11' sending stop to pid 27916 at 19/05/17 15:11:39 zmdc.pl
2019-05-17 15:11:39 zmc_m11 27916 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2019-05-17 15:11:34 zmc_m10 20616 INF Foscam1: images:330900 - Capturing at 16.67 fps, capturing bandwidth 0bytes/sec zm_monitor.cpp 2477
2019-05-17 15:11:31 zmc_m3 20667 INF Interior-1: images:221400 - Capturing at 10.00 fps, capturing bandwidth 24076bytes/sec zm_monitor.cpp 2477
2019-05-17 15:11:30 zmfilter_1 1167 INF Checking filter PurgeWhenFull delete returned 0 events zmfilter.pl
2019-05-17 15:11:30 zmfilter_2 1171 INF Checking filter Update DiskSpace update disk space returned 0 events zmfilter.pl
2019-05-17 15:11:29 zmwatch 1182 ERR Memory map file '/dev/shm/zm.mmap.11' does not exist. zmc might not be running. zmwatch.pl
2019-05-17 15:11:29 zmwatch 1182 INF Restarting capture daemon for WyzeCam1, shared data not valid zmwatch.pl
2019-05-17 15:11:29 zmdc 1091 WAR Can't find process with command of 'zmc -m 11' zmdc.pl
2019-05-17 15:11:29 zmdc 27916 INF 'zmc -m 11' started at 19/05/17 15:11:29 zmdc.pl
2019-05-17 15:11:29 zmdc 1091 INF 'zmc -m 11' starting at 19/05/17 15:11:29, pid = 27916 zmdc.pl
2019-05-17 15:11:29 zmc_m11 27916 INF Starting Capture version 1.32.3 zmc.cpp 223
2019-05-17 15:11:29 zmc_m11 27916 INF Priming capture from rtsp://<name>:<pass>@192.168.254.53/live zm_libvlc_camera.cpp 160
2019-05-17 15:11:28 zmc_m10 20616 INF Foscam1: images:330800 - Capturing at 14.29 fps, capturing bandwidth 0bytes/sec zm_monitor.cpp 2477
2019-05-17 15:11:21 zmc_m3 20667 INF Interior-1: images:221300 - Capturing at 10.00 fps, capturing bandwidth 23750bytes/sec zm_monitor.cpp 2477
2019-05-17 15:11:21 zmc_m10 20616 INF Foscam1: images:330700 - Capturing at 14.29 fps, capturing bandwidth 0bytes/sec zm_monitor.cpp 2477
2019-05-17 15:11:18 zmwatch 1182 ERR Memory map file '/dev/shm/zm.mmap.11' does not exist. zmc might not be running. zmwatch.pl
2019-05-17 15:11:18 zmwatch 1182 INF Restarting capture daemon for WyzeCam1, shared data not valid zmwatch.pl
2019-05-17 15:11:18 zmdc 1091 INF Command 'zmc -m 11' removed from pending list at 19/05/17 15:11:18 zmdc.pl
2019-05-17 15:11:14 zmc_m10 20616 INF Foscam1: images:330600 - Capturing at 14.29 fps, capturing bandwidth 0bytes/sec zm_monitor.cpp 2477
2019-05-17 15:11:11 zmc_m3 20667 INF Interior-1: images:221200 - Capturing at 9.09 fps, capturing bandwidth 21179bytes/sec zm_monitor.cpp
BaseballSS
Does the Wyze app specify a port for RTSP? The standard port is 554, so I would try that if it doesn't state otherwise. So the url would be:
rtsp://<name>:<password>@192.168.254.53:554/live
I would suggest trying Ffmpeg and TCP first. If TCP won't work, try UDP.
Additionally, have you gotten the url working in VLC?
SeattleMike
Hmmm, this gets odder and odder....
The Wyze beta app that supports RTSP doesn't specify a port in the software when you view the device RTSP info. I tried several ports to no effect. One note is that it says "Oprn the URL on your RTSP compatible video player while using the local network". I don't know if that "local network" bit means it won't work any other way. (??)
I did manage to get the camera recognized in tinyCam, but I had to specify my Wyze account user name (an email address) and password to get it to connect. It wants my Wyze web account password, not the username and password that was set in the camera itself.
I tried using that in the Source Path string but it doesn't work. Nothing I've tried so far will get it to show up in ZM, and VLC won't connect or show the camera either. VLC did tip me off to the fact that it wants the Wyze web account info as part of the connect string, but VLC still won't open or display the feed.
I took a second Wyze cam with stock FW and was able to get it working in the Wyze app, but when adding it to tinyCam, it shows the first Wyze camera. (I mention this only for completeness, since I'm more interested in getting the Wyze cams to work in ZM than anything else.)
tinyCam does show some interesting info, and I'm including that as a screenshot here in case it reveals something useful. It shows a port number and IP, but the IP must be from Wyze Labs, since it's not a 192.168.... IP.
At this point I'm befuddled and have no idea what to try next or what setting to try to use in ZM. Maybe the Wyze cam just isn't compatible with ZM? It should be, since the beta FW seems to support RTSP, but I'm not sure where to go from here.
Note- also added a shot of the ZM console, just to show that it's working well with an Amcrest and Foscam camera. :)
Also, reading the docs, I see ZM does have some ability to control pan/tilt/zoom, but I'm unsure of how to set that up for specific cameras. Are there some preconfigured scripts for specific cameras?
EDIT: Where is the "Control" tab in Zoneminder 1.32.3? Has this been moved or relocated? I don't see it anywhere. (??)
Screenshot_20190518-092135_tinyCam PRO.jpg (474.52 KiB) Viewed 30454 times
Zoneminder-2019-05-18 09-38-50.png (85.42 KiB) Viewed 30454 times
BaseballSS
Enable OPT_CONTROL under Options>System. That will make the Control tab visible. There are several pre-made scripts. If you're trying to control a pretty popular camera, it's probably already made.
tinyCam isn't accessing the local rtsp stream. It is accessing the stream from Wyze's servers using some sort of cloud/p2p protocol that ZM probably can't work with. Can you post screenshots of your config for Wyze in ZM?
SeattleMike
Ahh, that did it.
I see several Foscam cameras but I don't see the Foscam model R2.
I tried one of the pre-made Foscam selections but when viewing the feed I didn't see any change (like control buttons); I'm guessing there's more I need to do to enable it, or...?
I'd love to find scripts for the Amcrest 841 and the Foscam R2.
BaseballSS wrote: Sat May 18, 2019 6:07 pm tinyCam isn't accessing the local rtsp stream. It is accessing the stream from Wyze's servers using some sort of cloud/p2p protocol that ZM probably can't work with. Can you post screenshots of your config for Wyze in ZM?
Yep, that's what I figured, given the IP and other params it displayed.
Here are the General and Source tabs, I believe all the other settings in ZM are at their defaults. The Source/Method is set to TCP but I also tried UDP with the same result.
BaseballSS
The script for the R2C was added right after 1.32.3 was released so it isn't in there unfortunately. You can upgrade to 1.33 or find the script on GitHub and add it manually.
Looks like you have a typo in your capture height. Doubt that's the problem, but setting the wrong resolution has definitely caused issues in the past. I think you probably need to figure out the correct port. Have you tried re-flashing the beta firmware onto the Wyze cam?
SeattleMike
I changed the capture height to 1920 X 1080, same result.
I'll contact Wyze and see if I can find out the port, and if the URL that their app generates is correct.
Thank you for all your help, and I'll let you know what I find out.
snake
Post by snake »
Hopefully Wyze will be kind enough as to provide you with the camera stream paths, but after that, you may have to use wireshark, and do some digging. Any good camera will include the stream paths in the User Manual, or they will be in the ispy website.
See:
https://wiki.zoneminder.com/Finding_Camera_Stream_Paths
In fact, I see an entry for Wyze Cam V2 on ispy. Did you try that?
SeattleMike
snake wrote: Sat May 18, 2019 8:58 pm In fact, I see an entry for Wyze Cam V2 on ispy. Did you try that?
They generate this string: http://<name>:password>@<IP address>image.jpg
I've tried a few options using that (with my own IP) but no luck so far.
I found this image in the Wyze forum discussion, but there's not enough there to really help:
https://forums.wyzecam.com/t/real-time- ... -rtsp/6694
SeattleMike
After a fair amount of fiddling around and a great deal of skilled assistance from a user named "InnocentBystander" in the Wyze forum, I was able to get RTSP working in ZM.
There's a long thread here where you can follow my blundering and flailing, and finally the successful conclusion:
https://forums.wyzecam.com/t/real-time- ... p/6694/685
If you go there, please give a shout of thanks to InnocentBystander for me, he was instrumental in getting me up and running.
I now have 3 cameras running in ZM- an Amcrest 841, a Foscam R2, and a Wyze Cam. I'll be adding a second Wyze Cam after I flash it with the RSTP-capable FW from the Wyze beta program.
I guess the last couple of questions I have at this time involve whether or not need to set some sort of channel info in ZM to differentiate the 2 Wyze Cams. When I added them to tinyCam on my tablet, I needed to set them to different channels in order to see both streams. Will I need to do that or will ZM differentiate them based on the IP address?
Finally, does anyone have experience with ZM Ninja? It looks very slick and seems to provide a lot of functionality. Any thoughts on the ZM Ninja app?
BaseballSS
I'm glad you got it working!
You should be able to add a new monitor to ZM with the other IP address.
zmNinja is a fantastic mobile viewer for ZM. It's well-worth the $5 bill. There is a 'Mobile Apps' section on this forum that is mainly support for zmNinja. asker (zmNinja's dev) is very responsive and goes out of his way to help users.
You can go to the zmNinja repo and try it for free on desktop to see if you like it.
SeattleMike
BaseballSS wrote: Mon May 20, 2019 11:38 pm I'm glad you got it working!
I should definitely mention that you were also very, very helpful, and I appreciate everything you and the other folks did here to get me going. I can't thank you guys enough. :)
BaseballSS wrote: Mon May 20, 2019 11:38 pmzmNinja is a fantastic mobile viewer for ZM. It's well-worth the $5 bill. There is a 'Mobile Apps' section on this forum that is mainly support for zmNinja. asker (zmNinja's dev) is very responsive and goes out of his way to help users.
Consider me sold. I'll buy it and see what I need to do to get it working. :)
I can also recommend tinyCam, which is a tremendously useful and functional app for $4.00. it's not on par with ZM, but it's very good. I'm seriously considering trying to make a mini security dvr out of a cheap Kodi box and tinyCam.
Anyway, thanks again. I have some questions about hooking up some ethernet cameras over wifi, but I'll start another thread about that. :)
Cheers!
EDIT: Just for fun, here's a screenshot of ZM running with 4 cameras from 3 different manufacturers. :)
Loonysup
Post by Loonysup »
Would it possible to post the final working config you used for the Wyze Cams? I’m banging my head against a wall with these things. Also the Foscam settings would be awesome also.
Thanks in advance,
David
