ZM 1.32.3 ARM board Ubuntu 16.04 - Can't play recorded events
landrower
Post by landrower » Wed Mar 06, 2019 6:20 pm
Hello!
I have an ARM Board(Banana PI M3), whit Ubuntu 16.04 Xenial.
I have mjpeg and RTSP cameras, and with ZM 1.29.0 and 1.30.04 this issue not happen.
With 1.32.3 I can see live cameras individually, I can see on montage grups like a charm, but I can't play the recorded events.
I can see the frames and stills, and jpgs are really on the disk.
With ZmNinja I can play the recorded events like a charm.
When I see on the logs I get:
Mar 6 14:49:39 localhost web_php[19064]: ERR [Timed out waiting for msg /var/run/zm/zms-155972s.sock]
Mar 6 14:49:39 localhost web_php[19064]: ERR [No data to read from socket]
Mar 6 14:49:39 localhost web_php[19064]: ERR [getCmdResponse stream error: No data to read from socket - checkStreamForErrors()]
The more strange is that I can play recorded events on "Montage Review", with 1 and 8 hours.
If I click on a monitor during the review it's open a new window and I can view the recorded video, although it play backwards.
When I can play it from montage review, the windows have the url:
192.168.70.6/zm/index.php?view=event&eid=5983&fid=4600&popup=1
When I can't play it from normal event list, the window have the url:
http://192.168.70.6/zm/index.php?view=e ... c=0&page=1
Maybe it is an malformed URL?
I got this zoneminder 1.32.3 for xenial with apt-get from "deb http://ppa.launchpad.net/iconnor/zoneminder-1.32/ubuntu xenial main"
Sorry for my bad english, and please, help-me with this.
I really tried many times before ask for help.
Thanks!
Lawrence Waclawiak
pat2
Re: ZM 1.32.3 ARM board Ubuntu 16.04 - Can't play recorded events
Post by pat2 » Mon Mar 25, 2019 10:25 am
hi,
playing with /etc/zm/zm.conf I was able to view recorded jpeg!
I edited
ZM_PATH_CGI= /zm/cgi-bin/nph-zms and then returned back to M_PATH_CGI=/usr/lib/zoneminder/cgi-bin
and it started to work. Really strange!
Since starting from a fresh install i did many changes, I retried starting again from a fresh install and I was no more succesful. :(
So, I think it's a configuration issue on our distro not fully tested by developers.
Hope someone will help us to fix.
thanks
Post by bbunge » Tue Mar 26, 2019 7:26 pm
Save the images as jpeg. Video recording does not work on arm.
pat2
Post by pat2 » Thu Mar 28, 2019 6:29 am
we are saving as jpeg.
even if the jpegs are really saved (we could see them in the folder) ZM is not able to reproduce a video (as per the previous versions, i.e. 1.30.4) for recorded jpegs. even if other tool able to reproduce video from recorded jpegs.
it is happening to many users for a fresh install starting from a fresh distro. launching the script you proposed or following exactly instructions on the zoneminder site. and coinfiguring properly the camera. but it doesn't work.
for sure it's a not perfect configuration done by ZM installation on some distro. but we are not able to fix.
Users browsing this forum: Taurus61 and 2 guests
