Onvifprobe.php error 500
shardick
Post by shardick » Mon Feb 25, 2019 10:03 pm
i'm using 1.30.4 on Raspbian 9 (Raspberry Pi 3B+) and i'm getting error 500 when accessing onvifprobe.php page from monitor
Below the apache error.log:
[Mon Feb 25 22:45:10.617780 2019] [:error] [pid 25646] [client 10.0.0.24:54148] PHP Parse error: syntax error, unexpected end of file in /usr/share/zoneminder/www/skins/classic/views/onvifprobe.php on line 285, referer: http://10.0.0.35/zm/index.php?view=monitor&mid=2
Hope this helps.
Re: Onvifprobe.php error 500
Post by bbunge » Tue Feb 26, 2019 2:35 am
ONVIF monitor does not always work on this version of Zoneminder. Likely not just an issue with the Pi. You are better off using VLC or an Android ONVIF app.
I will fire up my Pi tomorrow to see if I get the same error.
Post by bbunge » Tue Feb 26, 2019 1:28 pm
Did not get an ONVIF error on my fresh Pi install.
Use a modified install procedure:
apt install php mariadb-server php-mysql libapache2-mod-php7.0 apache2
mysql_secure_installation
Edit sources.list
nano /etc/apt/sources.list
For Pi uncomment:
deb-src http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free$
Ctrl+o Enter to save
Ctrl+x to exit
apt update
Install Zoneminder
apt install zoneminder
chmod 740 /etc/zm/zm.conf
adduser www-data video
For Pi, Create Zoneminder database in Mariadb (Note: this also creates the default Zoneminder user and permissions in MySQL)
mysqladmin -uroot -p reload
Start Zoneminder
a2enmod cgi
a2enmod rewrite
a2enconf zoneminder
Add timezone to PHP
sed -i "s/;date.timezone =/date.timezone = $(sed 's/\//\\\//' /etc/timezone)/g" /etc/php/7.0/apache2/php.ini
Restart Apache
service apache2 restart
shardick
Post by shardick » Tue Feb 26, 2019 8:46 pm
did the same procedure (as found on zoneminder wiki)
it seems a phone syntax error, read the phone source code but without finding the error.
Post by bbunge » Tue Feb 26, 2019 9:23 pm
The procedure was changed on the wiki this morning. There are differences from the STDs Debian install. Suggest you start with a fresh Raspbian and try again.
shardick
Post by shardick » Sat Mar 02, 2019 7:41 pm
ok, thanks (I've to enable the mail notifications :D)
how to uninstall it?
lselinger
Post by lselinger » Thu Jun 06, 2019 4:23 pm
Has anyone else seen this? I've done a fresh install from scratch 2 times and still get this 500 error. I' following the install on the wiki from the Raspberry Pi 3B Zoneminder 1.30.4 section of This page: https://wiki.zoneminder.com/Debian_9_64 ... der_1.30.4
The error is the same as previous:
the weird thing is that file doesn't even have a line 285:
# wc -l /usr/share/zoneminder/www/skins/classic/views/onvifprobe.php
284 /usr/share/zoneminder/www/skins/classic/views/onvifprobe.php
I'm at a loss right now lol ... redoing gthe steps a few times to make sure they were done to a 'T' has not improved the situation. Is it possible there is a better guide or possibly something else I'm missing? For posterity I'm using the raspian lite image
lselinger
Post by lselinger » Thu Jun 06, 2019 5:04 pm
Never mind now all of a sudden it's all good :shock:
mitchell_cj
Post by mitchell_cj » Sun Jun 16, 2019 11:16 am
People getting this message...
There are 2 stray curly braces in this file for some reason.
Edit the file and remove/comment out lines 103 & 107.
If your editor doesn't have line numbers...
find "function probeProfiles"
remove the line after "preg_match"...there are 2 of these in this function, remove both. there are a single line containing {
zm_user
Post by zm_user » Tue Jun 25, 2019 6:54 am
Good morning,
I also have problem with
I comment lines 103 & 107 as mitchell_cj suggested but now in error.log I see
 PHP Fatal error:  Uncaught Error: Call to undefined method Logger::Debug() in /usr/share/zoneminder/www/skins/classic/views/onvifprobe.php:44\nStack trace:\n#0 /usr/share/zoneminder/www/skins/classic/views/onvifprobe.php(54): execONVIF('probe')\n#1 /usr/share/zoneminder/www/skins/classic/views/onvifprobe.php(148): probeCameras('')\n#2 /usr/share/zoneminder/www/index.php(213): require_once('/usr/share/zone...')\n#3 {main}\n  thrown in /usr/share/zoneminder/www/skins/classic/views/onvifprobe.php on line 44
Does anybody meet this error and know how to resolve it?
Users browsing this forum: No registered users and 11 guests
