Zoneminder add server option not work
PuneetGocher
Post by PuneetGocher »
So I just was looking through the options and saw add server. I have 2 zoneminder installations currently and would love to be able to manage them from the same console. Is that its purpose?
Also, when I click add It only gives me the option of adding a new server name and then doesn't save.
Re: Zoneminder add server option not work
The feature is to distribute recording over many machines. There will be 1 database, so your two servers need to share one database.
How recent is your ZM install? Server saving works for me.
Pedulla
Post by Pedulla »
You'll want to look this over too: https://zoneminder.readthedocs.io/en/st ... erver.html
It's from older versions of ZM but the logic is good.
