Dedicated drive issue - Ubuntu 18.04
ScottBouch
Post by ScottBouch » Sun Jan 27, 2019 1:04 pm
Hi all,
I recently rebuilt my server with Ubuntu 18.04.
I have mounted a dedicated hard drive to /mnt/CCTV using fstab by the drive UUID.
I read and tried to follow these instructions on telling Zoneminder how to find the drive: https://zoneminder.readthedocs.io/en/la ... drive.html
When trying to set the permissions, I found that I don't have a user or group called "apache" so instead (hoping for the best, and after a bit of internet searching) carried out:
sudo chown -R www-data:www-data /mnt/CCTV/events
I then created /etc/zm/drives.conf containing the line: ZM_DIR_EVENTS=/mnt/CCTV/events
After restarting zonmeminder with systemctl, it is not saving to this new directory.
Any ideas please?
Cheers, Scott.
Re: Dedicated drive issue - Ubuntu 18.04
Post by bbunge » Sun Jan 27, 2019 5:19 pm
Better to use the systemd mount procedure. See the wiki for the how to.
kitkat
Post by kitkat » Sun Jan 27, 2019 7:02 pm
My situation is similar but not exactly the same (I'm simply using a directory under /home rather than a dedicated disk, and I'm moving the entire /var/lib/zoneminder directory) and I found that I also had to change the Default Storage Path at Options -> Storage in the ZoneMinder console.
I also had success using mount --bind /my/new/data/dir /var/lib/zoneminder and not changing the ZoneMinder paths at all. (In fstab it's /my/new/data/dir /var/lib/zoneminder auto bind,defaults 0 0)
ScottBouch
Post by ScottBouch » Tue Feb 05, 2019 1:51 pm
Thanks,
This is now fixed using the systemd method, which was surprisingly straightforward.
Thanks, Scott.
