1.32.3 upgrade on xenial 16.04
vajonam
Post by vajonam »
I am looking to upgrade my docker imager which is based on xenal, but i cannot find some of the depends.
The following packages have unmet dependencies:
 zoneminder : Depends: libswresample2 but it is not installable or
                       libswresample3 but it is not installable or
                       libswresample24 but it is not installable
Which repos can I get this from for xenial?
siconic
Re: 1.32.3 upgrade on xenial 16.04
Post by siconic »
Same! I have been running on Xenial 16.04 for over 2 years now. I have been waiting patiently to go ahead and upgrade Zoneminder to 1.32.x for some kind of guide or something, but haven't seen one yet.
I was considering a clean install, since I am running it under Freenas 11.1 and may need to rebuild my VM after the newest Freenas 11.2 implementation anyway. BUT I have so many customization's, I am HOPING to do an upgrade.
vajonam
Post by vajonam »
you should be able to get to 1.32.2, which is what I am running the the dependency issue only comes up for 1.32.3
vajonam
Post by vajonam »
upgraded my instance to bionic .. :-) and was able to upgrade, might still be an issue with xenial.
siconic
Post by siconic »
How did you do the upgrade? Anything Special?
vajonam wrote: Mon Jan 07, 2019 3:13 pm I am looking to upgrade my docker imager which is based on xenal, but i cannot find some of the depends.
Make sure the universe repositorys are in the sources list.
You will have to go to 1.33.1 which is master development snapshots.
