Linked Monitors
Maximo1970
Linked Monitors
Post by Maximo1970 » Sat Jan 05, 2019 10:25 pm
Looking for some help and advice.
I'm using a NVR that provides two streams, one Hi-Res and the other Lo-Res. I've setup my motion detection on the Lo-Res streams and linked the monitors to the Hi-Res equivalent, if I've understood it correctly these means that when motion is detected the Hi-res stream is also recorded. But that's not happening.
The Lo-Res monitors is set to Modect and the Hi-Res equivalent is set to Nodect.
BiloxiGeek
Re: Linked Monitors
Post by BiloxiGeek » Mon Jan 07, 2019 11:03 am
Sounds like your links are backwards. The Hi-res monitors should be linked to the low-res. That means they'll record if the low-res is recording.
Maximo1970
Re: Linked Monitors
Post by Maximo1970 » Mon Jan 07, 2019 11:55 am
I'll give that a go and report back. Is there a specific logfile that would be useful to look at for this?
Maximo1970
Re: Linked Monitors
Post by Maximo1970 » Mon Jan 07, 2019 2:57 pm
The change above hasn't made a difference, I'm still not getting recordings from the Hi-Res cameras, just the Lo-res. Is there a debug logfile I can take a look at that would offer some form of assistance in tracking down the issue?
Just the clarify I've tried this approach:
Modect (Hi-Res Stream) -> Nodect (Lo-Res Stream)
Nodect (Lo-Res Stream) -> Modect (Hi-Res Stream)
Modect (Hi-Res Stream) <-> Nodect (Lo-Res Stream)
Nodect (Lo-Res Stream) <-> Modect (Hi-Res Stream)
I also have two separate groups in place, one that contains all of the Hi-Res streams and the other that contains the Lo-Res streams. Would this have an affect at all?
dparring
Re: Linked Monitors
Post by dparring » Tue Jan 08, 2019 9:15 pm
You want it like this:
Modect (Low Res)
Nodect (High Res)
Low Res config: no linked monitors
High Res config: linked to Low Res monitor
Groups shouldn't have an effect.
Maximo1970
Re: Linked Monitors
Post by Maximo1970 » Wed Jan 09, 2019 1:46 pm
Sadly that's not worked either. Is there another configuration change I need to make that will allow this to work?
dparring
Re: Linked Monitors
Post by dparring » Thu Jan 17, 2019 7:04 pm
I can't think of anything obvious - you might want to go through some debugging steps:
- Verify events are being triggered on SD
- Verify you can manually trigger HD events
- Verify Enabled is checked in monitor configs
Maximo1970
Re: Linked Monitors
Post by Maximo1970 » Mon Jan 21, 2019 2:09 pm
Thanks for getting back to me.
I've now discovered that I can link between Lo-Res cameras, but not between Lo-Res and Hi-Res. So it's more than likely I've setup my system in a way that's not compatible. I've created two groups, one of each set of feeds, such as all of the Lo-Res in one group and the Hi-Res on the other group. it makes viewing the montage a lot easier. For me at least.
Should I have also created groups for each camera, containing both feeds?
Maximo1970
Re: Linked Monitors
Post by Maximo1970 » Mon Jan 21, 2019 10:58 pm
I think I've found the reason why it's not working as I expect. I'm running a Multi-Server configuration. All of my Lo-Res streams are on one server and the Hi-Res streams are spread across three other servers.
So it seems that Linked Monitors only works if all the streams are on the same server. Which means I need to have a think about my current setup.
Users browsing this forum: No registered users and 13 guests
