ffmpeg with rtsp not working
wootah
Post by wootah »
Before I had a Zoneminder setup running with Ubuntu 16.04 and some cheap Digoo MQ1 wifi camera's
This seemed to work perfectly, just follow the onvif wizard and the connection was made easy peasy.
Now with Ubuntu 18.04 things are different. Since it was impossible to use the old zoneminder from 16.04 while I installed it, I decided to start using the development branch/ppa. Which I'm still using today.
Unfortunately I'm not able to make to use the camera with ffmpeg
I also tried upgrading ffmpeg to version 4, without any results.
I know ffmpeg works because I can dump a video from my wifi cam like this:
ffmpeg -i rtsp://admin:password@192.168.1.12:554/onvif1 -vcodec copy -r 60 -y /mnt/usb/video-dump.mp4
which results in a perfect video.
When I make the simple switch to libvlc I can get an image and it works.
Unfortunately libvlc is sensitive to some connection drops, which seems to occur every now and then, they are cheap wifi camera's in the end :D
When the connection drops libvlc doesn't seem to recover (the video will be stuck on the last successful frame) while ffmpeg (at least in my past Ubuntu 16.04 installation) keeps working.
The log, with debugging turned on in the options looks like this:
2019-01-03 22:47:01.482724 zmc_m2[9819].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://admin:password@192.168.1.12:554/onvif1]
2019-01-03 22:46:51.478894 zmc_m2[9819].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-01-03 22:46:51.473555 zmc_m2[9819].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://admin:password@192.168.1.12:554/onvif1 due to: Connection timed out]
2019-01-03 22:46:51.466681 zmc_m2[9819].WAR-zm_ffmpeg.cpp/64 [Nonmatching transport in server reply
2019-01-03 22:46:51.329016 zmc_m2[9819].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://admin:password@192.168.1.12:554/onvif1]
2019-01-03 22:46:47.630470 zmfilter_2[6752].INF-zmfilter.pl [Checking filter Update DiskSpace update disk space returned 0 events ]
2019-01-03 22:46:47.462280 zmfilter_1[6747].INF-zmfilter.pl [Checking filter PurgeWhenFull delete returned 0 events ]
2019-01-03 22:46:41.324426 zmc_m2[9819].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-01-03 22:46:41.316620 zmc_m2[9819].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://admin:password@192.168.1.12:554/onvif1 due to: Connection timed out]
2019-01-03 22:46:41.309643 zmc_m2[9819].WAR-zm_ffmpeg.cpp/64 [Nonmatching transport in server reply
2019-01-03 22:46:41.170769 zmc_m2[9819].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://admin:password@192.168.1.12:554/onvif1]
2019-01-03 22:46:31.165765 zmc_m2[9819].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-01-03 22:46:31.158749 zmc_m2[9819].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://admin:password@192.168.1.12:554/onvif1 due to: Connection timed out]
2019-01-03 22:46:31.153525 zmc_m2[9819].WAR-zm_ffmpeg.cpp/64 [Nonmatching transport in server reply
2019-01-03 22:46:31.009541 zmc_m2[9819].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://admin:password@192.168.1.12:554/onvif1]
2019-01-03 22:46:21.005630 zmc_m2[9819].ERR-zmc.cpp/253 [Failed to prime capture of initial monitor]
2019-01-03 22:46:21.000231 zmc_m2[9819].ERR-zm_ffmpeg_camera.cpp/357 [Unable to open input rtsp://admin:password@192.168.1.12:554/onvif1 due to: Connection timed out]
2019-01-03 22:46:20.993562 zmc_m2[9819].WAR-zm_ffmpeg.cpp/64 [Nonmatching transport in server reply
Any idea how I can solve this situation?
If any other information is required I'd gladly supply it.
Re: ffmpeg with rtsp not working
I think the key may be the Nonmatching transport in server reply log.
Try different values for Monitor->Source->Method
wootah
Post by wootah »
iconnor wrote: Thu Jan 03, 2019 11:40 pm I think the key may be the Nonmatching transport in server reply log.
Strangely enough that seems to work. On my old notes I do have written down that I did use to use TCP.
But when using VLC on my PC I can also see its a UDP stream and not TCP.
I guess libvlc figures that out on his own or simply ignores the method selection.
The setup has been running now for a couple hours without issue.
Relying on the ONVIF setup isn't flawless then though. By default TCP will be selected, but I suppose it should be UDP?
Or is this also camera specific?
I do get a lot of these warnings now btw:
reference count 1 overflow	zm_ffmpeg.cpp line 64
tr3b0r
Post by tr3b0r »
Are you sure your camera is always attaching to the network with the same address?
See my posts in this thread viewtopic.php?f=14&t=26663
wootah
Post by wootah »
tr3b0r wrote: Thu Mar 14, 2019 12:53 pm Are you sure your camera is always attaching to the network with the same address?
Yes, I set a static ip in my DHCP server. Ever since switching to UDP it has been working perfectly without interruptions.
