Audio Operation not permitted
jannnfe
Post by jannnfe » Tue Dec 11, 2018 11:20 pm
I want to have audio in events from camera. I configure my camera with this Source: rtsp://user:pass@192.168.178.19:554/11
and Video Writer to H264 Camera Passthrough.
When triggering an event i get this log. How to fix this?
2018-12-12 00:10:17 zmc_m5 48465 WAR /build/zoneminder-59iecC/zoneminder-1.32.3/src/zm_videostore.cpp:836: Writing frame [av_interleaved_write_frame()] failed: Operation not permitted(-1) zm_videostore.cpp 836
2018-12-12 00:10:17 zmc_m5 48465 ERR Error writing audio frame packet: Operation not permitted zm_videostore.cpp 1070
Thanks!
Re: Audio Operation not permitted
Post by bbunge » Wed Dec 12, 2018 2:01 am
Linux distro and version? Camera make and model?
jannnfe
Post by jannnfe » Wed Dec 12, 2018 10:04 am
Ubuntu Server 16
Zoneminder 1.32.3
Camera from https://www.aliexpress.com/item/Camhi-P ... 4c4dKY07Ty
That helps to solve the problem?
Post by bbunge » Fri Dec 14, 2018 1:04 am
Ubuntu Server 16
Zoneminder 1.32.3
Well, it might especially if someone has had that issue with the same hardware. It is also a requirement of the forum..
viewtopic.php?f=38&t=27501
Tell us exactly what version of ZoneMinder you are using and whether or not you are using a release or a development snapshot
Tell us how you installed ZoneMinder and what installation instructions you followed. You will be asked!
In most cases, we need to see the contents of your ZoneMinder log. Copy & paste it. More is better. Do not edit anything or leave bits out! If the logs are large, feel free to use a service like pastebin or one of the many others and post the link in the forum
If the error concerns a camera, we need to know the make and model of the camera. We also need to know the complete camera configuration in ZoneMinder. Screenshots are preferred.
If your question concerns the API, make sure you have followed the documentation mentioned previously.
Post by iconnor » Fri Dec 14, 2018 3:48 am
Honestly that's a new error message for me. (I'm the author of the code). I've seen invalid parameter, invalid this, invalid that. Never operation not permitted.
This is going to take some effort to debug.
One thing you can do is upgrade to master (1.33.0) which include some code that captures more debug messages from ffmpeg.
twice
Post by twice » Thu Dec 20, 2018 11:16 pm
Good day,
I have the same error and think I can provide the needed information,
I’m running running Ubuntu 16.04 desktop
Intel Core Duo CPU E7500 @ 2.93GHz
4 Gigs Ram
Zoneminder 1.30.4 updated from ppa:iconnor/zoneminder-1.32
1.32.2 and then to 1.32.3 all updates were done by ppa and a little forum searching
Cameras = 3: 1st is iCamera-1000
Ffmpeg rtsp://10.0.0.34:1024/img/media.sav TCP
From VLC: Video Codec: H264 - MPEG-4 AVC (part 10) (h264)
Audio Codec: G.726 ADPCM Audio (g726)
Camera 2: Kkmoon 801,
Ffmpeg rtsp://user:pass@10.0.0.40:554/11 TCP
From VLC: Codec: H264 - MPEG-4 AVC (part 10) (h264)
Audio Codec: PCM ALAW (alaw)
Camera 3: PLC
Ffmpeg rtsp://10.0.0.129:554/onvif1 UDP
Errors from log ,,
2018-12-20 17:01:31 zmc_m1 9551 WAR /build/zoneminder-59iecC/zoneminder- 1.32.3/src/zm_videostore.cpp:836: Writing frame [av_interleaved_write_frame()] failed: Operation not permitted(-1) zm_videostore.cpp 836
2018-12-20 17:01:30 zmc_m1 9551 WAR /build/zoneminder-59iecC/zoneminder-1.32.3/src/zm_videostore.cpp:836: Writing frame [av_interleaved_write_frame()] failed: Operation not permitted(-1) zm_videostore.cpp 836
2018-12-20 17:01:29 zmc_m1 9551 ERR Error writing audio frame packet: Operation not permitted zm_videostore.cpp
10702018-12-20 17:01:29 zmc_m1 9551 ERR Error writing audio frame packet: Operation not permitted zm_videostore.cpp 1070
All cameras work with clean install of zoneminder 1.32.3 on test box
Thanks! :D
twice
Post by twice » Fri Dec 21, 2018 4:30 pm
Good Day,
Updated to master 1.33.0 and a bit more in the log ,
Thanks!
2018-12-21 10:21:20	zmc_m1		31837	ERR	Error writing audio frame packet: Operation not permitted	zm_videostore.cpp	1111
2018-12-21 10:21:20	zmc_m1		31837	WAR	Malformed AAC bitstream detected: use the audio bitstream filter 'aac_adtstoasc' to fix it ('-bsf:a aac_adtstoasc' option with ffmpeg)	zm_ffmpeg.cpp	64
2018-12-21 10:21:20	zmc_m4		31862	INF	ignoring invalid SAR: 0/0	zm_ffmpeg.cpp	64
2018-12-21 10:21:20	zmc_m3		31853	INF	ignoring invalid SAR: 0/0	zm_ffmpeg.cpp	64
2018-12-21 10:21:19	zmc_m4		31862	INF	ignoring invalid SAR: 0/0	zm_ffmpeg.cpp	64
2018-12-21 10:21:19	zmc_m1		31837	WAR	Malformed AAC bitstream detected: use the audio bitstream filter 'aac_adtstoasc' to fix it ('-bsf:a aac_adtstoasc' option with ffmpeg)	zm_ffmpeg.cpp	64
2018-12-21 10:21:19	zmc_m1		31837	ERR	Error writing audio frame packet: Operation not permitted	zm_videostore.cpp	1111
2018-12-21 10:21:19	zmc_m3		31853	INF	ignoring invalid SAR: 0/0	zm_ffmpeg.cpp	64
twice
Post by twice » Thu Jan 10, 2019 1:45 am
Good day!
I solved this by purging zoneminder and ffmpeg and reinstalling
Thanks!
