Configuring a Edimax IC-7001W into ZM
Radiotwo
Post by Radiotwo »
Hi
I am trying to configure a Edimax IC-7001W Ip Camera into ZM V1.30.4
I have searched both the forum and Google but not found a correct answer, the is similar settings but either nothing happens or the best I have had
is just a blue screen where the picture is.
this one that I found:
https://wiki.zoneminder.com/Edimax_ic7000
I can view the camera on the browser by just typing in the ip address so it is visible with in the network and if I use the app for the Cam can view it outside the network
Any ideas please
Re: Configuring a Edimax IC-7001W into ZM
Best advice is to get the camera to stream with VLC and use the VLC setrings in Zoneminder. Also check VLC for the display resolution to use. Wrong resolution may be your problem!
