Event record stops forced
ivankuraev
Post by ivankuraev »
Hello.
My English is not good, so :)
I have ZM 1.32.2, Ubuntu 18.04.
Connect 1 camera and set to record.
In "Monitor" settings Misc tab set 'section length' to 1800.
I have that error in log
Camera 1: 17646 - Closing event 134, section end forced zm_monitor.cpp
And my event records is not 30 mins, they randomly drops record and start again.
What should I do to fix that?
Screenshot 2018-11-16 at 08.54.53.png (656.72 KiB) Viewed 4262 times
Pedulla
Re: Event record stops forced
Post by Pedulla »
Did you try shorter events?
I stick to 10 mins (600) on my continuous record.
30 mins seems like a really big recording to have to manage.
ivankuraev
Yes, I tried, but it didn't help.
ivankuraev
In the daytime recording events in parts of 900 seconds, in the nighttime the events begins stop records randomly.
Any ideas?
Aktarus
Post by Aktarus »
I have also seen such behaviour in my zm server in some cases.
Could you please provide infos about: your monitor settings, i.e. source tab settings and storage tab settings?
ivankuraev
Sometimes event record drops with that error
2018-11-22 18:32:15	zma_m1		24205	INF	Camera 1: image_count:836 - Closing event 1283, shutting down	zm_monitor.cpp	643
2018-11-22 18:32:15	zmdc		24223	INF	'zmc -m 1' started at 18/11/22 18:32:15	zmdc.pl
2018-11-22 18:32:15	zmdc		17692	INF	'zmc -m 1' starting at 18/11/22 18:32:15, pid = 24223	zmdc.pl
2018-11-22 18:32:15	zmdc		17692	INF	Starting pending process, zmc -m 1	zmdc.pl
2018-11-22 18:32:14	zmdc		17692	ERR	'zmc -m 1' exited abnormally, exit status 255	zmdc.pl
2018-11-22 18:32:14	zmc_m1		20856	FAT	Maximum number (25) of JPEG errors reached, exiting	zm_jpeg.cpp	43
2018-11-22 18:32:14	zmc_m1		20856	ERR	Invalid JPEG file structure: two SOI markers	zm_jpeg.cpp	40
2018-11-22 18:32:12	zmfilter_2	19994	INF	Checking filter Update DiskSpace update disk space returned 0 events	zmfilter.pl
2018-11-22 18:32:11	zmfilter_1	19981	INF	Checking filter PurgeWhenFull delete returned 0 events	zmfilter.pl
2018-11-22 18:31:25	zmc_m1		20856	INF	Camera 1: images:167000 - Capturing at 4.50 fps, capturing bandwidth 935136bytes/sec	zm_monitor.cpp	2473
2018-11-22 18:31:12	zmfilter_2	19994	INF	Checking filter Update DiskSpace update disk space returned 0 events	zmfilter.pl
2018-11-22 18:31:11	zmfilter_1	19981	INF	Checking filter PurgeWhenFull delete returned 0 events	zmfilter.pl
2018-11-22 18:30:12	zmfilter_2	19994	INF	Checking filter Update DiskSpace update disk space returned 1 events	zmfilter.pl
2018-11-22 18:30:11	zmfilter_1	19981	INF	Checking filter PurgeWhenFull delete returned 0 events	zmfilter.pl
2018-11-22 18:30:09	zma_m1		24205	INF	Camera 1: 287 - Opening new event 1283, section start	zm_monitor.cpp	1482
2018-11-22 18:30:08	zmc_m1		20856	WAR	Last image read from shared memory 8 seconds ago, zma may have gone away	zm_monitor.cpp	2442
2018-11-22 18:30:08	zmc_m1		20856	WAR	Buffer overrun at index 15, image 166655, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	2437
2018-11-22 18:30:04	zmc_m1		20856	WAR	Buffer overrun at index 15, image 166635, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	2437
Sometimes with - Camera 1: 17646 - Closing event 134, section end forced zm_monitor.cpp
Monitor buffer settings
Image Buffer Size (frames) 20
Warmup Frames 0
Pre Event Image Count 0
Post Event Image Count 5
Stream Replay Image Buffer 0
Alarm Frame Count 1
I attach my monitor settings (general, source, storage)
