i could successfully install 1.30.4 on a new install of Suse Leap 15. Both ffmpeg and vlc protocols produce video streams from my camera.
Now I wanted to symlink events and images to a directory on my NAS.
Following the directions in https://wiki.zoneminder.com/Using_a_ded ... Hard_Drive
did not bring success. I cannot change the ownership of my new directory on the NAS (events, images) with the command
chown -R apache:apache /symlink/events
as apache seems to be an invalid user. If I use wwwrun instead of apache it is a valid user, still the permission to change the ownership is not permitted.
I think that it is either about the permissions on the NAS's side (which I checked), or the attributes in the fstab symlink setup of 'events' and 'images'.
Any comment or link to further sources is most welcome.
thanks,
Knut
Suse Leap and cifs: using a dedicated hard drive
Re: Suse Leap and cifs: using a dedicated hard drive
The problem is getting a reliable connection to the nas when your Zoneminder server boots up. In Ubuntu I tested using systemd to mount a share which worked well because Zoneminder can be delayed until the mount is connected. You also need to have a file system on the nas that understands symbolic links.
Check put the WIKI for zm Ubuntu for the steps to do systemd mount.
What file system is your NAS using? FAT? ext2/3/4? NTFS?
A lot of these cheaper/lower end NAS boxes still use FAT file systems internally that don't know a thing about permissions and ownership, and so the NAS (or linux) may have to fake up some answers for you when accessed over the network.
I have two NASes here, where all files are owned by "root.root" no matter what I do, symlinks are a mystery, and any changes in mode (rwx) are automatically applied to user, group, and other, in parallel -- so no "rwxr-x-r-x" distinctions.
I don't use them for ZoneMinder
thanks for your advice. I have to admit that I gave up setting up cifs as a protocol. Instead, I switched to nfs - and thus I was successful in chown the events and images folder on my NAS system to wwwrun.
So: it works!
thanks again,
Knut
So: it works!
thanks again,
Knut
... which means your underlying file system probably *is* something usable (ext2-3-4) and it's just that the CIFS/SMB implementation is only expecting to talk to DOS level computers.
Glad you sorted it.
Glad you sorted it.
