Upgraded 1.30.4 to 1.32.2 -- Monitors not displaying
rudedog830
Post by rudedog830 »
Upgraded to 1.32.2. APIs are verified working. ZmNinja will not display monitors. Tried on linux version and android.
Log:
Screenshot from 2018-11-02 23-15-32.png (53.5 KiB) Viewed 5603 times
asker
Re: Upgraded 1.30.4 to 1.32.2 -- Monitors not displaying
Post by asker »
1. Try the version here https://drive.google.com/drive/folders/ ... sp=sharing
2. Run the wizard again
Please read before posting:
ES docs
zmNinja docs
rudedog830
Thanks for the help. Loaded new app and re-ran wizard. Same issues. It is a cgi-bin problem. The wizard doesn't discover the cgi-bin path. What should I do next?
rudedog830
Screenshot from 2018-11-03 17-21-37.png (49.71 KiB) Viewed 5587 times
Screenshot from 2018-11-03 17-21-12.png (43.81 KiB) Viewed 5587 times
asker
Post by asker »
Are your monitors displaying in ZM console?
ES docs
zmNinja docs
rudedog830
Yes, they are.
asker
Post by asker »
1. Your first post error showed a monitor load error but your next post says i'ts a cgi-bin error. Those are two different situations and not the same issue. Did the monitor load error go away? In other words, if you go to the "monitors" page are you able to see the list of monitors?
2. Did it work before you upgraded?
3. When you say monitors don't display. I assume you mean live feeds? How about events - do they play?
4. Open up your web console and do an inspect element - see the cgi-bin URL. Match it with what you have set in zmNinja
In the above case my zmNinja cgi-bin setting is https://myserver:myport/zm/cgi-bin
5. Make sure when you say it works in console, you have tried on a browser on a different machine (not the same machine that is running ZM)
6. Make sure you have read the FAQ about live streaming (and have made sure they have been read properly, not skimmed, as 99% of the problems I see are from folks who haven't read this properly)
7. If you are sure you have validated all of the above, can you please shoot me an email (pliable pixels at gmail) with logs. Please don't send me a small section of logs - it doesn't help me. A full log helps.
ES docs
zmNinja docs
rudedog830
I was receiving the following errors when zmNinja was trying to load monitors:
Notice (8): Use of undefined constant ZM_DB_SSL_CA_CERT - assumed 'ZM_DB_SSL_CA_CERT' [CORE/Cake/Model/ConnectionManager.php, line 69]
Notice (8): Use of undefined constant ZM_DB_SSL_CLIENT_KEY - assumed 'ZM_DB_SSL_CLIENT_KEY' [CORE/Cake/Model/ConnectionManager.php, line 69]
Notice (8): Use of undefined constant ZM_DB_SSL_CLIENT_CERT - assumed 'ZM_DB_SSL_CLIENT_CERT' [CORE/Cake/Model/ConnectionManager.php, line 69]
I was not able to see this errors in the zmNinja log, but when I pasted the URL from the log into a web page, I was able to see them.
Based on the input from another user on the forum, this entry in the zoneminder.conf got everything working:
# SSL CA certificate for ZoneMinder database
ZM_DB_SSL_CA_CERT=
# SSL client key for ZoneMinder database
ZM_DB_SSL_CLIENT_KEY=
# SSL client cert for ZoneMinder database
ZM_DB_SSL_CLIENT_CERT=
All good now. Thanks @asker for your help!
