CamON Live app to use an Android device as an IP camera
spynet
Post by spynet » Mon Sep 24, 2018 5:25 pm
CamON Live is a free Android app that allows to convert a common device, phone or tablet, to a flexible IP camera.
I'm maintaining this app and just verified its integration in ZM successfully.
If you want to try you can find it at https://play.google.com/store/apps/deta ... ynet.camon.
There is also an integrated web page and a REST API that allows your own customization.
salfare
Re: CamON Live app to use an Android device as an IP camera
Post by salfare » Tue Jul 23, 2019 4:39 pm
any chance you remember the settings on CamOn and ZM ?
I always get:
Captured image does not match expected size, check width, height and colour depth
regardless of the ZM and CamOn configuration
spynet
Post by spynet » Fri Oct 18, 2019 11:19 pm
