Event playback progress indicator not working after upgrade
penataquit
Post by penataquit »
Hello all,
I upgraded our Centos 7.5 Zoneminder installation the other day and it mostly seems to be working fine, but ran an issue with event playback. The progress information no longer appears correctly, showing "NaN" instead of seconds for progress and "0x" for zoom and playback rate. I thought maybe it was a Firefox issue but it's happening in Chrome also. The indicators work properly in live view, just not playback, and all worked fine in 1.30.4. I enabled debug logging but can't find any errors that stand out. Anyone else having this problem?
penataquit
Re: Event playback progress indicator not working after upgrade
Bump ... is nobody else having this issue?!
frhun
Post by frhun »
Well no - you aren't the only one.
I have the same problem and over here viewtopic.php?p=108065 there are some others with a similar problem. :?
