More problem founds
sagitt
More problem founds
Post by sagitt »
I found 2 problems with 1.32 version:
1. The App "IP Cam Viewer Pro" for iOS and Android that supports "ZoneMinder Server" as source are now broken.
2. In PTZ controls after uncheck all flags on "Presets" and save it, re-opening the script (like HikVision) the flags are again on. And i have buttons like Home in my live view that not work.
Schermata 2018-09-18 alle 20.22.42.png (67.33 KiB) Viewed 2453 times
3. If I delete a filter i can't re-use the ID. So now my filters starts from ID 5.
Schermata 2018-09-18 alle 20.27.15.png (34.43 KiB) Viewed 2451 times
4. Upload won't work.
