Close Link on main page
PCMedicJAX
Post by PCMedicJAX »
I am running zoneminder in kiosk mode and want to put a link on main page to close the browser as well as remove a few of the links. which pages would I need to edit to accomplish this.
Re: Close Link on main page
Kiosk mode???
If what you want to do is limit the monitors displayed in Montage set up a group for the user. Works well and you can also restrict the monitors a user can see. There is a close link on the montage screen..
PCMedicJAX
kiosk mode hides the address bar and disallows right click within the browser. I am not using user authentication. this system is not going to be online. just connected to a switch and a Monitor. When the system comes up they will see a desktop with 3 icons. Live View (Montage Review), Review Events(Console page), and Reboot system(executes silent reboot command)
so a link that closes the entire browser? or just return to the 3 icons?
PCMedicJAX
i figured it out. I just had to comment out the links I didn't want seen and added a basic close link copied from the Montage review page. It closes the browser and returns the user to the desktop.
