Zoneminder Capture Failing
So I have 4 cameras set up to use Mocord. I am using the unraid docker of zoneminder. My server has 32 GB of RAM of which I am sharing 65% of it for Zoneminder. I have noticed that two of my cameras are failing to capture correctly. I keep seeing black screens every so often so i looked into it a bit an these two cameras seem to be recording more events than the other two. I assume this is happening because they are coming back and starting a new event each time they crash whereas the other two record the whole event but I can't figure out why. I will attach my log file. The two cameras are South Cam Day and Driveway Cam Day.
- zm-log.txt
- (927.79 KiB) Downloaded 199 times
Re: Zoneminder Capture Failing
I'm going to suggest you switch to the ffmpeg monitor type. It looks like our not handling audio packets is causing the problem.
That worked perfectly. Thanks for the help.
