add new monitor give error: Can't find process with command of 'zma -m'
muggi
Post by muggi » Sun Jun 24, 2018 5:22 pm
hope someone can give a hint here to above mentioned problem:
Zm version: 1.30.4
Under Linux MInt 18.2 Sonya.
I got everything working fine with 2 Hikvision cameras, which have MODECT running fine. (cameras add a couple of weeks ago)
When trying to add a Cheap IP camera with PTZ.
Brand: KKmoon MOdel: TP-C810FD
IIII-467744-FADBD
Software version: v9.1.12.1.17-20170925
I am logged in as Admin in Zm
Im trying to add it via the ONVIF option:
Detected cameras: unknown ONVIF camera @ 192.168.10.90
Choosing:
Detected Profiles: MainProfile: H264 (1920x1080 @ 25 fps)
General tab
Source Tab:
LOG error when trying, to add the camera:
2018-06-24 18:13:36.502290	zmdc		1326	WAR	Can't find process with command of 'zma -m'	zmdc.pl
2018-06-24 18:13:36.385660	zmdc		1326	WAR	Can't find process with command of 'zmc -m'	zmdc.pl
2018-06-24 18:13:36.267840	zmdc		1326	WAR	Can't find process with command of 'zma -m'	zmdc.pl
and the monitor do not get added!
Camera is working fine on an android app called Onvifer! (added automatically in app by Onvif detect)
Re: add new monitor give error: Can't find process with command of 'zma -m'
Post by bbunge » Mon Jun 25, 2018 2:12 am
Yoi may not have the correct resolution in Zoneminder. The Android app or VLC should tell you what the camera uses. Also possible you have run out of RAM or tmpfs. If this is the case lower the resolution by half.
muggi
Post by muggi » Mon Jun 25, 2018 11:38 am
thank you for the reply.
Htop in terminal tells me 3.6 gb is used out of 7.63 gb.
Zm tells me Load: 0.59 - Disk: 63% - /dev/shm: 18%,
so the disk should not be the problem I think (45 gb free) ?
I also tried to add the low subprofile capture from the camera:
VLC tells me this from the mainstream:
Codec: H264 - MPEG-4 AVC (part 10) (h264)
Resolution: 1920x1090
Display resolution: 1920x1080
Frame rate: 20
Decoded format: Planar 4:2:0 YUV
muggi
Post by muggi » Tue Jul 03, 2018 5:02 pm
Just an update:
With the program BlueIris, I can add the camera in BlueIris without any problem, by using the path from ZM (from the ZM SOURCE tab, when trying to add the Camera by using ONVIF in ZM).
The path using is rtsp://user:password@192.168.10.90:554/11
muggi
Post by muggi » Tue Jul 03, 2018 5:12 pm
This is some of the info from Blueiris:
Users browsing this forum: No registered users and 6 guests
