1.31.44~20180604150154-xenial amd64 cycle reload login page and artefacts
Eradicator
Post by Eradicator »
There is too hard to auth in last build. Login page reloads in cycle!
In addition appeared artefacts such as viewtopic.php?f=37&t=27216&sid=a5155a73 ... 33cb3383b9
Screenshot in attachment.
Eradicator
Re: 1.31.44~20180604150154-xenial amd64 cycle reload login page and artefacts
And monitors still don't move in list. =(
Hmmm nothing has been done with auth in quite some time. The visual artefacts look like they could be due to using udp instead of tcp in the rtsp stream. dragndrop sorting of monitors should work in the next release.
Eradicator
iconnor wrote: Wed Jun 06, 2018 5:39 pm Hmmm nothing has been done with auth in quite some time. The visual artefacts look like they could be due to using udp instead of tcp in the rtsp stream. dragndrop sorting of monitors should work in the next release.
Auth reload was on last firefox and safari browsers.
As for artefacts i'm using TCP on all cams. But after switch cam to "none", and return to "record", artefacts are disappeared!
Thanks in advance for dragndrop!
