Several zma/zmc for same HD ipcam
m3lab
Post by m3lab »
I'm running ZM 1.30.2 on Raspian Jessie with LEMP with 6 IPcams of which 5 are SD and only 1 is in HD.
For each SD cam, there is a couple of zma and zmc processes, while for HD there is 1 zma and 5 to 6 zmc processes: is this correct or I've to tune up something?
Thanks in advance,
m
Pedulla
Re: Several zma/zmc for same HD ipcam
Post by Pedulla »
I think that's normal. I can't explain why, but all of my ZM's exhibit the same behavior.
There should only be 1 zmc and 1 zma for each camera.
