Layout messed up after 1.31.44 update
muggi
Re: Layout messed up after 1.31.44 update
Post by muggi » Mon Aug 13, 2018 9:07 pm
hmm,
seems like its a permission thing:
when trying to open the link from som of the cache files from the browser
it gives me:
Forbidden
You don't have permission to access /zm/cache/skins_classic_css_classic_views_console-classic-1533760722.css on this server.
Apache/2.4.18 (Ubuntu) Server at 192.168.10.56 Port 80
zd59
Post by zd59 » Tue Aug 14, 2018 7:21 am
I had the same issue.
After skin was changed in recent ZM, developers introduced folder /zm/cache.
It must have permissions that allow R/W to Apache - Apache user and Group.
I use Slackware and have a user/group apache/apache.
I belive Mint use www-data:www-data for that.
So you have to:
chown -R www-data:www-data /zm/cache
I think, you'd fugured out that by yourself. :D
muggi
Post by muggi » Tue Aug 14, 2018 7:20 pm
thank you for the update.
I did a Chown of the folder /var/cache/zoneminder/cache
and checked the owner:
~ $ ls -l /var/cache/zoneminder
total 24
drwxrwxrwx 2 www-data www-data 12288 Aug 11 23:16 cache
drwxrwxrwx 2 www-data www-data  4096 May  9  2017 events
drwxrwxrwx 2 www-data www-data  4096 May  9  2017 images
drwxrwxrwx 2 www-data www-data  4096 May  9  2017 temp
i also checked the owner and permission of /var/cache/zoneminder/cache:
~ $ ls -l /var/cache/zoneminder/cache
total 220
lrwxrwxrwx 1 www-data www-data 57 Jun  5 14:09 skins_classic_css_base_skin-classic-1528138921.css -> /usr/share/zoneminder/www/skins/classic/css/base/skin.css
lrwxrwxrwx 1 www-data www-data 57 Jun  7 20:49 skins_classic_css_base_skin-classic-1528306764.css -> /usr/share/zoneminder/www/skins/classic/css/base/skin.css
lrwxrwxrwx 1 www-data www-data 57 Aug  4 15:28 skins_classic_css_base_skin-classic-1533058777.css -> /usr/share/zoneminder/www/skins/classic/css/base/skin.css
lrwxrwxrwx 1 www-data www-data 57 Aug 11 13:00 skins_classic_css_base_skin-classic-1533760722.css -> /usr/share/zoneminder/www/skins/classic/css/base/skin.css
lrwxrwxrwx 1 www-data www-data 57 Jun  5 14:04 skins_classic_css_base_skin-dark-1528138921.css -> /usr/share/zoneminder/www/skins/classic/css/base/skin.css
lrwxrwxrwx 1 www-data www-data 66 Jun  5 14:11 skins_classic_css_base_views_console-classic-1528138921.css -> /usr/share/zoneminder/www/skins/classic/css/base/views/console.css
lrwxrwxrwx 1 www-data www-data 66 Jun  7 20:49 skins_classic_css_base_views_console-classic-1528306764.css -> /usr/share/zoneminder/www/skins/classic/css/base/views/console.css
lrwxrwxrwx 1 www-data www-data 66 Aug  4 15:28 skins_classic_css_base_views_console-classic-1533058777.css -> /usr/share/zoneminder/www/skins/classic/css/base/views/console.css
lrwxrwxrwx 1 www-data www-data 66 Aug 11 13:00 skins_classic_css_base_views_console-classic-1533760722.css -> /usr/share/zoneminder/www/skins/classic/css/base/views/console.css
lrwxrwxrwx 1 www-data www-data 66 Jun  5 14:04 skins_classic_css_base_views_console-dark-1528138921.css -> /usr/share/zoneminder/www/skins/classic/css/base/views/console.css
lrwxrwxrwx 1 www-data www-data 62 Jun  6 21:17 skins_classic_css_base_views_log-classic-1528138921.css -> /usr/share/zoneminder/www/skins/classic/css/base/views/log.css
lrwxrwxrwx 1 www-data www-data 62 Jun  7 21:58 skins_classic_css_base_views_log-classic-1528306764.css -> /usr/share/zoneminder/www/skins/classic/css/base/views/log.css
lrwxrwxrwx 1 www-data www-data 62 Aug 11 23:16 skins_classic_css_base_views_log-classic-1533760722.css -> /usr/share/zoneminder/www/skins/classic/css/base/views/log.css
lrwxrwxrwx 1 www-data www-data 62 Jun  5 14:08 skins_classic_css_base_views_log-dark-1528138921.css -> /usr/share/zoneminder/www/skins/classic/css/base/views/log.css
lrwxrwxrwx 1 www-data www-data 66 Jun  5 14:11 skins_classic_css_base_views_montage-classic-1528138921.css -> /usr/share/zoneminder/www/skins/classic/css/base/views/montage.css
lrwxrwxrwx 1 www-data www-data 66 Jun  7 20:49 skins_classic_css_base_views_montage-classic-1528306764.css -> /usr/share/zoneminder/www/skins/classic/css/base/views/montage.css
lrwxrwxrwx 1 www-data www-data 72 Jun  6 21:18 skins_classic_css_base_views_montagereview-classic-1528138921.css -> /usr/share/zoneminder/www/skins/classic/css/base/views/montagereview.css
lrwxrwxrwx 1 www-data www-data 66 Jun  5 14:09 skins_classic_css_base_views_options-classic-1528138921.css -> /usr/share/zoneminder/www/skins/classic/css/base/views/options.css
lrwxrwxrwx 1 www-data www-data 66 Jun  7 20:55 skins_classic_css_base_views_options-classic-1528306764.css -> /usr/share/zoneminder/www/skins/classic/css/base/views/options.css
lrwxrwxrwx 1 www-data www-data 66 Aug  4 15:29 skins_classic_css_base_views_options-classic-1533058777.css -> /usr/share/zoneminder/www/skins/classic/css/base/views/options.css
lrwxrwxrwx 1 www-data www-data 66 Aug 11 14:36 skins_classic_css_base_views_options-classic-1533760722.css -> /usr/share/zoneminder/www/skins/classic/css/base/views/options.css
lrwxrwxrwx 1 www-data www-data 66 Jun  5 14:05 skins_classic_css_base_views_options-dark-1528138921.css -> /usr/share/zoneminder/www/skins/classic/css/base/views/options.css
lrwxrwxrwx 1 www-data www-data 72 Jun  5 14:09 skins_classic__css_classic_jquery-ui-theme-classic-1528138921.css -> /usr/share/zoneminder/www/skins/classic//css/classic/jquery-ui-theme.css
lrwxrwxrwx 1 www-data www-data 72 Jun  7 20:49 skins_classic__css_classic_jquery-ui-theme-classic-1528306764.css -> /usr/share/zoneminder/www/skins/classic//css/classic/jquery-ui-theme.css
lrwxrwxrwx 1 www-data www-data 72 Aug  4 15:28 skins_classic__css_classic_jquery-ui-theme-classic-1533058777.css -> /usr/share/zoneminder/www/skins/classic//css/classic/jquery-ui-theme.css
lrwxrwxrwx 1 www-data www-data 72 Aug 11 13:00 skins_classic__css_classic_jquery-ui-theme-classic-1533760722.css -> /usr/share/zoneminder/www/skins/classic//css/classic/jquery-ui-theme.css
lrwxrwxrwx 1 www-data www-data 60 Jun  5 14:09 skins_classic_css_classic_skin-classic-1528138921.css -> /usr/share/zoneminder/www/skins/classic/css/classic/skin.css
lrwxrwxrwx 1 www-data www-data 60 Jun  7 20:49 skins_classic_css_classic_skin-classic-1528306764.css -> /usr/share/zoneminder/www/skins/classic/css/classic/skin.css
lrwxrwxrwx 1 www-data www-data 60 Aug  4 15:28 skins_classic_css_classic_skin-classic-1533058777.css -> /usr/share/zoneminder/www/skins/classic/css/classic/skin.css
lrwxrwxrwx 1 www-data www-data 60 Aug 11 13:00 skins_classic_css_classic_skin-classic-1533760722.css -> /usr/share/zoneminder/www/skins/classic/css/classic/skin.css
lrwxrwxrwx 1 www-data www-data 69 Jun  5 14:11 skins_classic_css_classic_views_console-classic-1528138921.css -> /usr/share/zoneminder/www/skins/classic/css/classic/views/console.css
lrwxrwxrwx 1 www-data www-data 69 Jun  7 20:49 skins_classic_css_classic_views_console-classic-1528306764.css -> /usr/share/zoneminder/www/skins/classic/css/classic/views/console.css
lrwxrwxrwx 1 www-data www-data 69 Aug  4 15:28 skins_classic_css_classic_views_console-classic-1533058777.css -> /usr/share/zoneminder/www/skins/classic/css/classic/views/console.css
lrwxrwxrwx 1 www-data www-data 69 Aug 11 13:00 skins_classic_css_classic_views_console-classic-1533760722.css -> /usr/share/zoneminder/www/skins/classic/css/classic/views/console.css
lrwxrwxrwx 1 www-data www-data 65 Jun  6 21:17 skins_classic_css_classic_views_log-classic-1528138921.css -> /usr/share/zoneminder/www/skins/classic/css/classic/views/log.css
lrwxrwxrwx 1 www-data www-data 65 Jun  7 21:58 skins_classic_css_classic_views_log-classic-1528306764.css -> /usr/share/zoneminder/www/skins/classic/css/classic/views/log.css
lrwxrwxrwx 1 www-data www-data 65 Aug 11 23:16 skins_classic_css_classic_views_log-classic-1533760722.css -> /usr/share/zoneminder/www/skins/classic/css/classic/views/log.css
lrwxrwxrwx 1 www-data www-data 69 Jun  5 14:11 skins_classic_css_classic_views_montage-classic-1528138921.css -> /usr/share/zoneminder/www/skins/classic/css/classic/views/montage.css
lrwxrwxrwx 1 www-data www-data 69 Jun  7 20:49 skins_classic_css_classic_views_montage-classic-1528306764.css -> /usr/share/zoneminder/www/skins/classic/css/classic/views/montage.css
lrwxrwxrwx 1 www-data www-data 75 Jun  6 21:18 skins_classic_css_classic_views_montagereview-classic-1528138921.css -> /usr/share/zoneminder/www/skins/classic/css/classic/views/montagereview.css
lrwxrwxrwx 1 www-data www-data 69 Jun  5 14:09 skins_classic_css_classic_views_options-classic-1528138921.css -> /usr/share/zoneminder/www/skins/classic/css/classic/views/options.css
lrwxrwxrwx 1 www-data www-data 69 Jun  7 20:55 skins_classic_css_classic_views_options-classic-1528306764.css -> /usr/share/zoneminder/www/skins/classic/css/classic/views/options.css
lrwxrwxrwx 1 www-data www-data 69 Aug  4 15:29 skins_classic_css_classic_views_options-classic-1533058777.css -> /usr/share/zoneminder/www/skins/classic/css/classic/views/options.css
lrwxrwxrwx 1 www-data www-data 69 Aug 11 14:36 skins_classic_css_classic_views_options-classic-1533760722.css -> /usr/share/zoneminder/www/skins/classic/css/classic/views/options.css
lrwxrwxrwx 1 www-data www-data 69 Jun  5 14:04 skins_classic__css_dark_jquery-ui-theme-dark-1528138921.css -> /usr/share/zoneminder/www/skins/classic//css/dark/jquery-ui-theme.css
lrwxrwxrwx 1 www-data www-data 57 Jun  5 14:04 skins_classic_css_dark_skin-dark-1528138921.css -> /usr/share/zoneminder/www/skins/classic/css/dark/skin.css
lrwxrwxrwx 1 www-data www-data 66 Jun  5 14:04 skins_classic_css_dark_views_console-dark-1528138921.css -> /usr/share/zoneminder/www/skins/classic/css/dark/views/console.css
lrwxrwxrwx 1 www-data www-data 62 Jun  5 14:08 skins_classic_css_dark_views_log-dark-1528138921.css -> /usr/share/zoneminder/www/skins/classic/css/dark/views/log.css
lrwxrwxrwx 1 www-data www-data 66 Jun  5 14:05 skins_classic_css_dark_views_options-dark-1528138921.css -> /usr/share/zoneminder/www/skins/classic/css/dark/views/options.css
lrwxrwxrwx 1 www-data www-data 53 Jun  5 14:09 skins_classic_js_classic-classic-1528138921.js -> /usr/share/zoneminder/www/skins/classic/js/classic.js
lrwxrwxrwx 1 www-data www-data 53 Jun  7 20:49 skins_classic_js_classic-classic-1528306764.js -> /usr/share/zoneminder/www/skins/classic/js/classic.js
lrwxrwxrwx 1 www-data www-data 53 Aug  4 15:28 skins_classic_js_classic-classic-1533058777.js -> /usr/share/zoneminder/www/skins/classic/js/classic.js
lrwxrwxrwx 1 www-data www-data 53 Aug 11 13:00 skins_classic_js_classic-classic-1533760722.js -> /usr/share/zoneminder/www/skins/classic/js/classic.js
lrwxrwxrwx 1 www-data www-data 89 Jun  5 14:09 skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1528138921.css -> /usr/share/zoneminder/www/skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css
lrwxrwxrwx 1 www-data www-data 89 Jun  7 20:49 skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1528306764.css -> /usr/share/zoneminder/www/skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css
lrwxrwxrwx 1 www-data www-data 89 Aug  4 15:28 skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533058777.css -> /usr/share/zoneminder/www/skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css
lrwxrwxrwx 1 www-data www-data 89 Aug 11 13:00 skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533760722.css -> /usr/share/zoneminder/www/skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css
lrwxrwxrwx 1 www-data www-data 89 Jun  5 14:04 skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-dark-1528138921.css -> /usr/share/zoneminder/www/skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css
lrwxrwxrwx 1 www-data www-data 88 Jun  5 14:09 skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1528138921.css -> /usr/share/zoneminder/www/skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css
lrwxrwxrwx 1 www-data www-data 88 Jun  7 20:49 skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1528306764.css -> /usr/share/zoneminder/www/skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css
lrwxrwxrwx 1 www-data www-data 88 Aug  4 15:28 skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533058777.css -> /usr/share/zoneminder/www/skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css
lrwxrwxrwx 1 www-data www-data 88 Aug 11 13:00 skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533760722.css -> /usr/share/zoneminder/www/skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css
lrwxrwxrwx 1 www-data www-data 88 Jun  5 14:04 skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-dark-1528138921.css -> /usr/share/zoneminder/www/skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css
lrwxrwxrwx 1 www-data www-data 50 Jun  5 14:09 skins_classic_js_skin-classic-1528138921.js -> /usr/share/zoneminder/www/skins/classic/js/skin.js
lrwxrwxrwx 1 www-data www-data 50 Jun  7 20:49 skins_classic_js_skin-classic-1528306764.js -> /usr/share/zoneminder/www/skins/classic/js/skin.js
lrwxrwxrwx 1 www-data www-data 50 Aug  4 15:28 skins_classic_js_skin-classic-1533058777.js -> /usr/share/zoneminder/www/skins/classic/js/skin.js
lrwxrwxrwx 1 www-data www-data 50 Aug 11 13:00 skins_classic_js_skin-classic-1533760722.js -> /usr/share/zoneminder/www/skins/classic/js/skin.js
lrwxrwxrwx 1 www-data www-data 50 Jun  5 14:04 skins_classic_js_skin-dark-1528138921.js -> /usr/share/zoneminder/www/skins/classic/js/skin.js
lrwxrwxrwx 1 www-data www-data 59 Jun  5 14:11 skins_classic_views_js_console-classic-1528138921.js -> /usr/share/zoneminder/www/skins/classic/views/js/console.js
lrwxrwxrwx 1 www-data www-data 59 Jun  7 20:49 skins_classic_views_js_console-classic-1528306764.js -> /usr/share/zoneminder/www/skins/classic/views/js/console.js
lrwxrwxrwx 1 www-data www-data 59 Aug  4 15:28 skins_classic_views_js_console-classic-1533058777.js -> /usr/share/zoneminder/www/skins/classic/views/js/console.js
lrwxrwxrwx 1 www-data www-data 59 Aug 11 13:00 skins_classic_views_js_console-classic-1533760722.js -> /usr/share/zoneminder/www/skins/classic/views/js/console.js
lrwxrwxrwx 1 www-data www-data 59 Jun  5 14:04 skins_classic_views_js_console-dark-1528138921.js -> /usr/share/zoneminder/www/skins/classic/views/js/console.js
lrwxrwxrwx 1 www-data www-data 55 Jun  6 21:17 skins_classic_views_js_log-classic-1528138921.js -> /usr/share/zoneminder/www/skins/classic/views/js/log.js
lrwxrwxrwx 1 www-data www-data 55 Jun  7 21:58 skins_classic_views_js_log-classic-1528306764.js -> /usr/share/zoneminder/www/skins/classic/views/js/log.js
lrwxrwxrwx 1 www-data www-data 55 Aug 11 23:16 skins_classic_views_js_log-classic-1533760722.js -> /usr/share/zoneminder/www/skins/classic/views/js/log.js
lrwxrwxrwx 1 www-data www-data 55 Jun  5 14:08 skins_classic_views_js_log-dark-1528138921.js -> /usr/share/zoneminder/www/skins/classic/views/js/log.js
lrwxrwxrwx 1 www-data www-data 59 Jun  5 14:11 skins_classic_views_js_montage-classic-1528138921.js -> /usr/share/zoneminder/www/skins/classic/views/js/montage.js
lrwxrwxrwx 1 www-data www-data 59 Jun  7 20:49 skins_classic_views_js_montage-classic-1528306764.js -> /usr/share/zoneminder/www/skins/classic/views/js/montage.js
lrwxrwxrwx 1 www-data www-data 65 Jun  6 21:18 skins_classic_views_js_montagereview-classic-1528138921.js -> /usr/share/zoneminder/www/skins/classic/views/js/montagereview.js
lrwxrwxrwx 1 www-data www-data 70 Jun  7 21:33 skins_classic_views_js_report_event_audit-classic-1528306764.js -> /usr/share/zoneminder/www/skins/classic/views/js/report_event_audit.js
lrwxrwxrwx 1 www-data www-data 59 Jun  6 21:18 skins_classic_views_js_version-classic-1528138921.js -> /usr/share/zoneminder/www/skins/classic/views/js/version.js
lrwxrwxrwx 1 www-data www-data 59 Jun  7 21:11 skins_classic_views_js_version-classic-1528306764.js -> /usr/share/zoneminder/www/skins/classic/views/js/version.js
lrwxrwxrwx 1 www-data www-data 59 Aug 11 13:23 skins_classic_views_js_version-classic-1533760722.js -> /usr/share/zoneminder/www/skins/classic/views/js/version.js
lrwxrwxrwx 1 www-data www-data 59 Jun  5 14:07 skins_classic_views_js_version-dark-1528138921.js -> /usr/share/zoneminder/www/skins/classic/views/js/version.js
seems like the right apache owner and permissions.
But i stil get the 403 error in zm,
so i got a crazy idea, i renamed the /var/cache/zoneminder/cache to /var/cache/zoneminder/cache_
so the path to the cache dir is "broken" and suddenly ZM works ???
I do not understand this!
muggi
Post by muggi » Tue Aug 14, 2018 7:27 pm
Just an update, I was a bit to fast on the trigger.
Interface in webrowser works in ZM,
but the log file in Zm gives me a lot of broken link errors, beacuse of the missing cache folder I think:
Date/Time
Component	Server	PID	Level	Message	File	Line
2018-08-14 21:23:58.262797	web_php		6175	WAR	Failed linking skins/classic/views/js/donate.js to skins_classic_views_js_donate-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:58.254230	web_php		6175	WAR	Failed linking skins/classic/js/skin.js to skins_classic_js_skin-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:58.246034	web_php		6175	WAR	Failed linking skins/classic/js/classic.js to skins_classic_js_classic-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:58.237396	web_php		6175	WAR	Failed linking skins/classic//css/classic/jquery-ui-theme.css to skins_classic__css_classic_jquery-ui-theme-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:58.228479	web_php		6175	WAR	Failed linking skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css to skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:58.220198	web_php		6175	WAR	Failed linking skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css to skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:58.211744	web_php		6175	WAR	Failed linking skins/classic/css/classic/skin.css to skins_classic_css_classic_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:58.200714	web_php		6175	WAR	Failed linking skins/classic/css/base/skin.css to skins_classic_css_base_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:57.180424	web_php		6175	WAR	Failed linking skins/classic/views/js/console.js to skins_classic_views_js_console-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:57.171805	web_php		6175	WAR	Failed linking skins/classic/js/skin.js to skins_classic_js_skin-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:57.164796	web_php		6175	WAR	Failed linking skins/classic/js/classic.js to skins_classic_js_classic-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:57.154635	web_php		6175	WAR	Failed linking skins/classic//css/classic/jquery-ui-theme.css to skins_classic__css_classic_jquery-ui-theme-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:57.145954	web_php		6175	WAR	Failed linking skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css to skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:57.137927	web_php		6175	WAR	Failed linking skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css to skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:57.129405	web_php		6175	WAR	Failed linking skins/classic/css/classic/views/console.css to skins_classic_css_classic_views_console-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:57.120538	web_php		6175	WAR	Failed linking skins/classic/css/base/views/console.css to skins_classic_css_base_views_console-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:57.112051	web_php		6175	WAR	Failed linking skins/classic/css/classic/skin.css to skins_classic_css_classic_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:57.105944	web_php		6175	WAR	Failed linking skins/classic/css/base/skin.css to skins_classic_css_base_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:35.840255	web_php		5430	WAR	Failed linking skins/classic/views/js/donate.js to skins_classic_views_js_donate-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:35.831943	web_php		5430	WAR	Failed linking skins/classic/js/skin.js to skins_classic_js_skin-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:35.823874	web_php		5430	WAR	Failed linking skins/classic/js/classic.js to skins_classic_js_classic-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:35.814932	web_php		5430	WAR	Failed linking skins/classic//css/classic/jquery-ui-theme.css to skins_classic__css_classic_jquery-ui-theme-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:35.806485	web_php		5430	WAR	Failed linking skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css to skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:35.798111	web_php		5430	WAR	Failed linking skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css to skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:35.789887	web_php		5430	WAR	Failed linking skins/classic/css/classic/skin.css to skins_classic_css_classic_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:35.783678	web_php		5430	WAR	Failed linking skins/classic/css/base/skin.css to skins_classic_css_base_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:34.694921	web_php		5430	WAR	Failed linking skins/classic/views/js/console.js to skins_classic_views_js_console-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:34.686227	web_php		5430	WAR	Failed linking skins/classic/js/skin.js to skins_classic_js_skin-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:34.677607	web_php		5430	WAR	Failed linking skins/classic/js/classic.js to skins_classic_js_classic-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:34.669212	web_php		5430	WAR	Failed linking skins/classic//css/classic/jquery-ui-theme.css to skins_classic__css_classic_jquery-ui-theme-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:34.660534	web_php		5430	WAR	Failed linking skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css to skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:34.651795	web_php		5430	WAR	Failed linking skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css to skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:34.643264	web_php		5430	WAR	Failed linking skins/classic/css/classic/views/console.css to skins_classic_css_classic_views_console-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:34.634951	web_php		5430	WAR	Failed linking skins/classic/css/base/views/console.css to skins_classic_css_base_views_console-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:34.627391	web_php		5430	WAR	Failed linking skins/classic/css/classic/skin.css to skins_classic_css_classic_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:34.619247	web_php		5430	WAR	Failed linking skins/classic/css/base/skin.css to skins_classic_css_base_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:23:29.475710	zmfilter_2		5660	INF	Checking filter Update DiskSpace update disk space returned 0 events	zmfilter.pl
2018-08-14 21:23:27.682570	zmfilter_1		5655	INF	Checking filter PurgeWhenFull delete returned 0 events	zmfilter.pl
2018-08-14 21:23:13.703180	zmdc		5628	ERR	'zmtelemetry.pl' exited abnormally, exit status 9	zmdc.pl
2018-08-14 21:23:13.035150	zmdc		6109	INF	'zmtelemetry.pl' started at 18/08/14 21:23:13	zmdc.pl
2018-08-14 21:23:13.032920	zmdc		5628	INF	'zmtelemetry.pl' starting at 18/08/14 21:23:13, pid = 6109	zmdc.pl
2018-08-14 21:23:13.019750	zmdc		5628	INF	Starting pending process, zmtelemetry.pl	zmdc.pl
2018-08-14 21:22:34.135726	web_php		5918	WAR	Failed linking skins/classic/views/js/donate.js to skins_classic_views_js_donate-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:34.126747	web_php		5918	WAR	Failed linking skins/classic/js/skin.js to skins_classic_js_skin-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:34.118538	web_php		5918	WAR	Failed linking skins/classic/js/classic.js to skins_classic_js_classic-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:34.109720	web_php		5918	WAR	Failed linking skins/classic//css/classic/jquery-ui-theme.css to skins_classic__css_classic_jquery-ui-theme-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:34.101118	web_php		5918	WAR	Failed linking skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css to skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:34.092912	web_php		5918	WAR	Failed linking skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css to skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:34.084416	web_php		5918	WAR	Failed linking skins/classic/css/classic/skin.css to skins_classic_css_classic_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:34.076145	web_php		5918	WAR	Failed linking skins/classic/css/base/skin.css to skins_classic_css_base_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:33.093686	web_php		5918	WAR	Failed linking skins/classic/views/js/console.js to skins_classic_views_js_console-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:33.085415	web_php		5918	WAR	Failed linking skins/classic/js/skin.js to skins_classic_js_skin-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:33.077175	web_php		5918	WAR	Failed linking skins/classic/js/classic.js to skins_classic_js_classic-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:33.068115	web_php		5918	WAR	Failed linking skins/classic//css/classic/jquery-ui-theme.css to skins_classic__css_classic_jquery-ui-theme-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:33.059541	web_php		5918	WAR	Failed linking skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css to skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:33.050796	web_php		5918	WAR	Failed linking skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css to skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:33.044445	web_php		5918	WAR	Failed linking skins/classic/css/classic/views/console.css to skins_classic_css_classic_views_console-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:33.033775	web_php		5918	WAR	Failed linking skins/classic/css/base/views/console.css to skins_classic_css_base_views_console-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:33.025533	web_php		5918	WAR	Failed linking skins/classic/css/classic/skin.css to skins_classic_css_classic_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:33.018968	web_php		5918	WAR	Failed linking skins/classic/css/base/skin.css to skins_classic_css_base_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:29.453740	zmfilter_2		5660	INF	Checking filter Update DiskSpace update disk space returned 0 events	zmfilter.pl
2018-08-14 21:22:27.664240	zmfilter_1		5655	INF	Checking filter PurgeWhenFull delete returned 0 events	zmfilter.pl
2018-08-14 21:22:26.963051	web_php		5446	WAR	Failed linking skins/classic/views/js/log.js to skins_classic_views_js_log-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:26.954685	web_php		5446	WAR	Failed linking skins/classic/js/skin.js to skins_classic_js_skin-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:26.948064	web_php		5446	WAR	Failed linking skins/classic/js/classic.js to skins_classic_js_classic-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:26.937516	web_php		5446	WAR	Failed linking skins/classic//css/classic/jquery-ui-theme.css to skins_classic__css_classic_jquery-ui-theme-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:26.929048	web_php		5446	WAR	Failed linking skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css to skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:26.920648	web_php		5446	WAR	Failed linking skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css to skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:26.912284	web_php		5446	WAR	Failed linking skins/classic/css/classic/views/log.css to skins_classic_css_classic_views_log-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:26.903955	web_php		5446	WAR	Failed linking skins/classic/css/base/views/log.css to skins_classic_css_base_views_log-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:26.895370	web_php		5446	WAR	Failed linking skins/classic/css/classic/skin.css to skins_classic_css_classic_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:22:26.887144	web_php		5446	WAR	Failed linking skins/classic/css/base/skin.css to skins_classic_css_base_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:49.303276	web_php		5446	WAR	Failed linking skins/classic/views/js/monitor.js to skins_classic_views_js_monitor-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:49.294805	web_php		5446	WAR	Failed linking skins/classic/js/skin.js to skins_classic_js_skin-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:49.288038	web_php		5446	WAR	Failed linking skins/classic/js/classic.js to skins_classic_js_classic-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:49.277938	web_php		5446	WAR	Failed linking skins/classic//css/classic/jquery-ui-theme.css to skins_classic__css_classic_jquery-ui-theme-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:49.269393	web_php		5446	WAR	Failed linking skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css to skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:49.260788	web_php		5446	WAR	Failed linking skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css to skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:49.252258	web_php		5446	WAR	Failed linking skins/classic/css/classic/views/monitor.css to skins_classic_css_classic_views_monitor-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:49.243681	web_php		5446	WAR	Failed linking skins/classic/css/base/views/monitor.css to skins_classic_css_base_views_monitor-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:49.235542	web_php		5446	WAR	Failed linking skins/classic/css/classic/skin.css to skins_classic_css_classic_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:49.227474	web_php		5446	WAR	Failed linking skins/classic/css/base/skin.css to skins_classic_css_base_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:36.156061	web_php		5446	WAR	Failed linking skins/classic/views/js/onvifprobe.js to skins_classic_views_js_onvifprobe-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:36.147612	web_php		5446	WAR	Failed linking skins/classic/js/skin.js to skins_classic_js_skin-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:36.139248	web_php		5446	WAR	Failed linking skins/classic/js/classic.js to skins_classic_js_classic-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:36.130586	web_php		5446	WAR	Failed linking skins/classic//css/classic/jquery-ui-theme.css to skins_classic__css_classic_jquery-ui-theme-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:36.122244	web_php		5446	WAR	Failed linking skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css to skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:36.113907	web_php		5446	WAR	Failed linking skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css to skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:36.105433	web_php		5446	WAR	Failed linking skins/classic/css/classic/skin.css to skins_classic_css_classic_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:36.100511	web_php		5446	WAR	Failed linking skins/classic/css/base/skin.css to skins_classic_css_base_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:29.433310	zmfilter_2		5660	INF	Checking filter Update DiskSpace update disk space returned 0 events	zmfilter.pl
2018-08-14 21:21:29.007622	web_php		5446	WAR	Failed linking skins/classic/views/js/donate.js to skins_classic_views_js_donate-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:28.997238	web_php		5446	WAR	Failed linking skins/classic/js/skin.js to skins_classic_js_skin-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:28.988665	web_php		5446	WAR	Failed linking skins/classic/js/classic.js to skins_classic_js_classic-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:28.979827	web_php		5446	WAR	Failed linking skins/classic//css/classic/jquery-ui-theme.css to skins_classic__css_classic_jquery-ui-theme-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:28.971655	web_php		5446	WAR	Failed linking skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css to skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:28.962725	web_php		5446	WAR	Failed linking skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css to skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:28.954326	web_php		5446	WAR	Failed linking skins/classic/css/classic/skin.css to skins_classic_css_classic_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:28.945537	web_php		5446	WAR	Failed linking skins/classic/css/base/skin.css to skins_classic_css_base_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:27.887593	web_php		5446	WAR	Failed linking skins/classic/views/js/console.js to skins_classic_views_js_console-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:27.878874	web_php		5446	WAR	Failed linking skins/classic/js/skin.js to skins_classic_js_skin-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:27.870487	web_php		5446	WAR	Failed linking skins/classic/js/classic.js to skins_classic_js_classic-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:27.861558	web_php		5446	WAR	Failed linking skins/classic//css/classic/jquery-ui-theme.css to skins_classic__css_classic_jquery-ui-theme-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:27.853483	web_php		5446	WAR	Failed linking skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css to skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:27.844790	web_php		5446	WAR	Failed linking skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css to skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:27.835774	web_php		5446	WAR	Failed linking skins/classic/css/classic/views/console.css to skins_classic_css_classic_views_console-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:27.827631	web_php		5446	WAR	Failed linking skins/classic/css/base/views/console.css to skins_classic_css_base_views_console-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:27.819236	web_php		5446	WAR	Failed linking skins/classic/css/classic/skin.css to skins_classic_css_classic_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:27.813469	web_php		5446	WAR	Failed linking skins/classic/css/base/skin.css to skins_classic_css_base_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:21:27.640910	zmfilter_1		5655	INF	Checking filter PurgeWhenFull delete returned 0 events	zmfilter.pl
2018-08-14 21:20:52.597332	web_php		5446	WAR	Failed linking skins/classic/views/js/onvifprobe.js to skins_classic_views_js_onvifprobe-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:52.589168	web_php		5446	WAR	Failed linking skins/classic/js/skin.js to skins_classic_js_skin-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:52.580566	web_php		5446	WAR	Failed linking skins/classic/js/classic.js to skins_classic_js_classic-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:52.546863	web_php		5446	WAR	Failed linking skins/classic//css/classic/jquery-ui-theme.css to skins_classic__css_classic_jquery-ui-theme-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:52.537971	web_php		5446	WAR	Failed linking skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css to skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:52.529585	web_php		5446	WAR	Failed linking skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css to skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:52.521183	web_php		5446	WAR	Failed linking skins/classic/css/classic/skin.css to skins_classic_css_classic_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:52.511310	web_php		5446	WAR	Failed linking skins/classic/css/base/skin.css to skins_classic_css_base_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:45.872049	web_php		5446	WAR	Failed linking skins/classic/views/js/monitor.js to skins_classic_views_js_monitor-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:45.863485	web_php		5446	WAR	Failed linking skins/classic/js/skin.js to skins_classic_js_skin-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:45.856986	web_php		5446	WAR	Failed linking skins/classic/js/classic.js to skins_classic_js_classic-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:45.844144	web_php		5446	WAR	Failed linking skins/classic//css/classic/jquery-ui-theme.css to skins_classic__css_classic_jquery-ui-theme-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:45.835096	web_php		5446	WAR	Failed linking skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css to skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:45.826488	web_php		5446	WAR	Failed linking skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css to skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:45.818050	web_php		5446	WAR	Failed linking skins/classic/css/classic/views/monitor.css to skins_classic_css_classic_views_monitor-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:45.809526	web_php		5446	WAR	Failed linking skins/classic/css/base/views/monitor.css to skins_classic_css_base_views_monitor-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:45.801032	web_php		5446	WAR	Failed linking skins/classic/css/classic/skin.css to skins_classic_css_classic_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:45.792968	web_php		5446	WAR	Failed linking skins/classic/css/base/skin.css to skins_classic_css_base_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:29.409260	zmfilter_2		5660	INF	Checking filter Update DiskSpace update disk space returned 0 events	zmfilter.pl
2018-08-14 21:20:27.613000	zmfilter_1		5655	INF	Checking filter PurgeWhenFull delete returned 0 events	zmfilter.pl
2018-08-14 21:20:27.207114	web_php		5430	WAR	Failed linking skins/classic/views/js/donate.js to skins_classic_views_js_donate-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:27.198622	web_php		5430	WAR	Failed linking skins/classic/js/skin.js to skins_classic_js_skin-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:27.190268	web_php		5430	WAR	Failed linking skins/classic/js/classic.js to skins_classic_js_classic-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:27.182455	web_php		5430	WAR	Failed linking skins/classic//css/classic/jquery-ui-theme.css to skins_classic__css_classic_jquery-ui-theme-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:27.173875	web_php		5430	WAR	Failed linking skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css to skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:27.164618	web_php		5430	WAR	Failed linking skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css to skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:27.155924	web_php		5430	WAR	Failed linking skins/classic/css/classic/skin.css to skins_classic_css_classic_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:27.147259	web_php		5430	WAR	Failed linking skins/classic/css/base/skin.css to skins_classic_css_base_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:25.283993	web_php		5430	WAR	Failed linking skins/classic/views/js/console.js to skins_classic_views_js_console-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:25.275725	web_php		5430	WAR	Failed linking skins/classic/js/skin.js to skins_classic_js_skin-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:25.267232	web_php		5430	WAR	Failed linking skins/classic/js/classic.js to skins_classic_js_classic-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:25.258163	web_php		5430	WAR	Failed linking skins/classic//css/classic/jquery-ui-theme.css to skins_classic__css_classic_jquery-ui-theme-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:25.249970	web_php		5430	WAR	Failed linking skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css to skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:25.240712	web_php		5430	WAR	Failed linking skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css to skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:25.232324	web_php		5430	WAR	Failed linking skins/classic/css/classic/views/console.css to skins_classic_css_classic_views_console-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:25.224107	web_php		5430	WAR	Failed linking skins/classic/css/base/views/console.css to skins_classic_css_base_views_console-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:25.213537	web_php		5430	WAR	Failed linking skins/classic/css/classic/skin.css to skins_classic_css_classic_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:20:25.205516	web_php		5430	WAR	Failed linking skins/classic/css/base/skin.css to skins_classic_css_base_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:19:29.388780	zmfilter_2		5660	INF	Checking filter Update DiskSpace update disk space returned 0 events	zmfilter.pl
2018-08-14 21:19:27.592500	zmfilter_1		5655	INF	Checking filter PurgeWhenFull delete returned 0 events	zmfilter.pl
2018-08-14 21:19:24.517247	web_php		5699	WAR	Failed linking skins/classic/views/js/donate.js to skins_classic_views_js_donate-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:19:24.508924	web_php		5699	WAR	Failed linking skins/classic/js/skin.js to skins_classic_js_skin-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:19:24.500962	web_php		5699	WAR	Failed linking skins/classic/js/classic.js to skins_classic_js_classic-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:19:24.492289	web_php		5699	WAR	Failed linking skins/classic//css/classic/jquery-ui-theme.css to skins_classic__css_classic_jquery-ui-theme-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:19:24.483704	web_php		5699	WAR	Failed linking skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css to skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:19:24.474796	web_php		5699	WAR	Failed linking skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css to skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:19:24.466394	web_php		5699	WAR	Failed linking skins/classic/css/classic/skin.css to skins_classic_css_classic_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:19:24.459045	web_php		5699	WAR	Failed linking skins/classic/css/base/skin.css to skins_classic_css_base_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:19:22.287924	web_php		5699	WAR	Failed linking skins/classic/views/js/console.js to skins_classic_views_js_console-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:19:22.279733	web_php		5699	WAR	Failed linking skins/classic/js/skin.js to skins_classic_js_skin-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:19:22.270957	web_php		5699	WAR	Failed linking skins/classic/js/classic.js to skins_classic_js_classic-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:19:22.262596	web_php		5699	WAR	Failed linking skins/classic//css/classic/jquery-ui-theme.css to skins_classic__css_classic_jquery-ui-theme-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:19:22.253912	web_php		5699	WAR	Failed linking skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css to skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:19:22.245243	web_php		5699	WAR	Failed linking skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css to skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:19:22.236519	web_php		5699	WAR	Failed linking skins/classic/css/classic/views/console.css to skins_classic_css_classic_views_console-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:19:22.228398	web_php		5699	WAR	Failed linking skins/classic/css/base/views/console.css to skins_classic_css_base_views_console-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:19:22.219398	web_php		5699	WAR	Failed linking skins/classic/css/classic/skin.css to skins_classic_css_classic_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:19:22.208407	web_php		5699	WAR	Failed linking skins/classic/css/base/skin.css to skins_classic_css_base_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:18:29.365680	zmfilter_2		5660	INF	Checking filter Update DiskSpace update disk space returned 0 events	zmfilter.pl
2018-08-14 21:18:27.573650	zmfilter_1		5655	INF	Checking filter PurgeWhenFull delete returned 0 events	zmfilter.pl
2018-08-14 21:18:21.472284	web_php		5827	WAR	Failed linking skins/classic/views/js/donate.js to skins_classic_views_js_donate-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:18:21.463713	web_php		5827	WAR	Failed linking skins/classic/js/skin.js to skins_classic_js_skin-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:18:21.455639	web_php		5827	WAR	Failed linking skins/classic/js/classic.js to skins_classic_js_classic-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:18:21.446693	web_php		5827	WAR	Failed linking skins/classic//css/classic/jquery-ui-theme.css to skins_classic__css_classic_jquery-ui-theme-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:18:21.438233	web_php		5827	WAR	Failed linking skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css to skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:18:21.427939	web_php		5827	WAR	Failed linking skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css to skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:18:21.409132	web_php		5827	WAR	Failed linking skins/classic/css/classic/skin.css to skins_classic_css_classic_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:18:21.399886	web_php		5827	WAR	Failed linking skins/classic/css/base/skin.css to skins_classic_css_base_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:18:19.296402	web_php		5827	WAR	Failed linking skins/classic/views/js/console.js to skins_classic_views_js_console-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:18:19.287168	web_php		5827	WAR	Failed linking skins/classic/js/skin.js to skins_classic_js_skin-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:18:19.278746	web_php		5827	WAR	Failed linking skins/classic/js/classic.js to skins_classic_js_classic-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:18:19.269717	web_php		5827	WAR	Failed linking skins/classic//css/classic/jquery-ui-theme.css to skins_classic__css_classic_jquery-ui-theme-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:18:19.265555	web_php		5827	WAR	Failed linking skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css to skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:18:19.252763	web_php		5827	WAR	Failed linking skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css to skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:18:19.244317	web_php		5827	WAR	Failed linking skins/classic/css/classic/views/console.css to skins_classic_css_classic_views_console-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:18:19.236108	web_php		5827	WAR	Failed linking skins/classic/css/base/views/console.css to skins_classic_css_base_views_console-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:18:19.227652	web_php		5827	WAR	Failed linking skins/classic/css/classic/skin.css to skins_classic_css_classic_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:18:19.221606	web_php		5827	WAR	Failed linking skins/classic/css/base/skin.css to skins_classic_css_base_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:17:29.469440	zmaudit		5664	INF	Deleted 0 log table entries by time	zmaudit.pl
2018-08-14 21:17:29.455760	zmaudit		5664	INF	Auditing All Storage Areas	zmaudit.pl
2018-08-14 21:17:29.346420	zmfilter_2		5660	INF	Checking filter Update DiskSpace update disk space returned 0 events	zmfilter.pl
2018-08-14 21:17:27.553880	zmfilter_1		5655	INF	Checking filter PurgeWhenFull delete returned 0 events	zmfilter.pl
2018-08-14 21:17:17.878969	web_php		5445	WAR	Failed linking skins/classic/views/js/donate.js to skins_classic_views_js_donate-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:17:17.870671	web_php		5445	WAR	Failed linking skins/classic/js/skin.js to skins_classic_js_skin-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:17:17.852012	web_php		5445	WAR	Failed linking skins/classic/js/classic.js to skins_classic_js_classic-classic-1533760722.js	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:17:17.843251	web_php		5445	WAR	Failed linking skins/classic//css/classic/jquery-ui-theme.css to skins_classic__css_classic_jquery-ui-theme-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:17:17.834820	web_php		5445	WAR	Failed linking skins/classic//js/jquery-ui-1.12.1/jquery-ui.structure.min.css to skins_classic__js_jquery-ui-1.12.1_jquery-ui.structure.min-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:17:17.826394	web_php		5445	WAR	Failed linking skins/classic//js/dateTimePicker/jquery-ui-timepicker-addon.css to skins_classic__js_dateTimePicker_jquery-ui-timepicker-addon-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:17:17.817371	web_php		5445	WAR	Failed linking skins/classic/css/classic/skin.css to skins_classic_css_classic_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
2018-08-14 21:17:17.810175	web_php		5445	WAR	Failed linking skins/classic/css/base/skin.css to skins_classic_css_base_skin-classic-1533760722.css	/usr/share/zoneminder/www/includes/functions.php	2087
zd59
Post by zd59 » Tue Sep 11, 2018 10:47 am
Hi muggi!
Sorry for a late reply, have'nt noticed your posts and no e-mails about them.
The catch is in your zoneminder.conf
Alias /zoneminder/cache "@ZM_CACHEDIR@"
I think it's wrong. I had the same issue: wrong path in config file, working GUI, log errors, or right path in config file but GUI not working. But after permissions solved and right path all works.
You wrote that your cache folder is
Pay attention to this I mentioned before:
In my case, it once worked absolute/full path "/var/zm/cache", next git release (after few days) worked "/zm/cache".
So according to above your right path statement should be
Alias /var/cache/zoneminder/cache "@ZM_CACHEDIR@"
- full path
Alias /cache/zoneminder/cache "@ZM_CACHEDIR@"
- path relative to /var
Experiment with that.
The right config you will have, when your cache folder will have Apache user/group write rights and there are plenty of files in it.
Users browsing this forum: No registered users and 6 guests
