version 1.31.43 in iconner PPA zoneminder-master
Does version 1.31.43 belong in iconner PPA zoneminder-master? I noticed while updating that v 1.31.43 is in the master branch and not storageareas.
Anyway installed and the web console does not work correctly. CSS seems missing. changing display style / skin /css has no effect.
although zmNinja works well and ZM seems to be streaming. Not sure why so I am mentioning the glitch.
padeath
Re: version 1.31.43 in iconner PPA zoneminder-master
Post by padeath »
I upgraded to this version today too, I'm also seeing this missing css issue.
I'm also getting email alerts of alerts from my oldest events, I keep 3 days of images, and as they are getting deleted it seems I'm getting an email alert be sent by the filter that I have setup that is supposed to only send on new movement. I'm thinking that the filter code doesn't realise that the event alert has already been sent?
padeath
Post by padeath »
I was looking into this a bit and found that the css files are there, they are just forbidden by apache config.
I added Require all granted to the <Directory> in the config for apache now the are able to be loaded.
Still not sure on all the past alerts that are coming through though.
juanmoura
Post by juanmoura »
same problem with me
I fixed it by removing the Alias /zm/cache statement from the web server config and I replaced it with a sym-link I made from the command line
from -> /var/cache/zoneminder/cache to -> /usr/share/zoneminder/www/cache
then the CSS was working again for the web console
juanmoura
Post by juanmoura »
how can i do this?
are you running Apache as the web server? If yes, open /etc/apache2/conf-available/zoneminder.conf and around line 10
comment out this line :
#Alias /zm/cache /var/cache/zoneminder/cache
make sure that the copy in /etc/apache2/conf-enabled/zoneminder.conf is the same (should be a sym-link)
restart Apache
in a terminal enter ->
ln -s /var/cache/zoneminder/cache /usr/share/zoneminder/www/cache
I am not sure if it will work for you or not. My setup that I fixed is running Hiawatha 10.8.1 as the web server and the configuration is different but it should have a similar effect in Apache.
elchavodel8
Post by elchavodel8 »
rockedge wrote: Tue May 01, 2018 1:48 am are you running Apache as the web server? If yes, open /etc/apache2/conf-available/zoneminder.conf and around line 10
restart Apache
Thank you ! :D it repair my css now can go to tabs , but still having problem with one camera that stops each moment
If you are running an Apache web server then it would be better to remove the sym-link and make sure the newer zoneminder.conf is active and has all the lines it needs for it to work.
So again open /etc/apache2/conf-available/zoneminder.conf and around line 10
un-comment the Alias and add the 2 lines
AllowOverride All
Require all granted
as it is below.
<Directory /var/cache/zoneminder/cache>
  AllowOverride All
  Require all granted
</Directory>
Restart the Apache web server.
This would be a better way to correct the css locating, the other way was a hack I can use in Puppy Linux when using the Hiawatha web server.
