ZM 1.31.1 on Ubuntu 18.04 Bionic
For those of you who just have to try Zoneminder 1.31.x on Ubuntu Bionic...
Follow the basic Ubuntu 16.04 install instructions at:
Except...
Add PPA Master: add-apt-repository ppa:iconnor/zoneminder-master
Edit php.ini : nano /etc/php/7.2/apache2/php.ini
To "fix" the API
Download api.fixed.tar.gz from: https://drive.google.com/open?id=1QjvVe ... vXBASFXnNY
Copy api.fixed.tar.gz to the home directory of your Ubuntu server and extract it. All files will be in a folder called api.
Rename /usr/share/zoneminder/www/api to /usr/share/zoneminder/www/api.org
Copy or move the extracted api folder in your home directory to /usr/share/zoneminder/www/
Restart Apache and your Zoneminder api will work.
These are not my usual "detailed" instructions because if you are playing with Beta software you should know a bit about what you are doing with Ubuntu. If you are at all unsure, don't! There are instructions in the WIKI to install the Zoneminder stable 1.30.4 on Ubuntu Bionic.
hans109h
Re: ZM 1.31.1 on Ubuntu 18.04 Bionic
Post by hans109h »
Just an FYI that I had to manually install the libapache2-mod-php7.2, disable the 7.1 mod and enable the 7.2 for things to work out. I had some issues with my upgrade to 18.04, so not sure if this will apply to others but figured I'd post here in case it is helpful.
Hans
hans109h wrote: Sat Apr 28, 2018 1:11 am Just an FYI that I had to manually install the libapache2-mod-php7.2, disable the 7.1 mod and enable the 7.2 for things to work out. I had some issues with my upgrade to 18.04, so not sure if this will apply to others but figured I'd post here in case it is helpful.
Hans
Known issues covered in the WIKI for Ubuntu upgrade area.
