Hi All,
Been busy installing ZoneMinder on my RPi3 as per these instructions: https://wiki.zoneminder.com/Raspbian. With a few modifications due to the fact that I use "stretch" I was able to install all necessary components.
But.... My RPi3 serves as a Domoticz server (port 2082 and 443) and has Pi-hole installed (port 80). I would really (really!) like to use another port for the web interface of ZoneMinder for instance 8080. I have searched this forum but cannot find a solution that works.
Anyone have a clue?
Looking forward!
Change port number web interface ZoneMinder
Greetz,
Sjonnie
Sjonnie
Re: Change port number web interface ZoneMinder
ZoneMinder uses apache. Just configure apache to listen on another port.
Thank you for your ultra swift reply.
Did some more searching based on your advice and stumbled upon this post: viewtopic.php?t=21721#p82527
Changed the port to 8080 in /etc/apache2/ports.conf and after a restart of apache2 the web interface as accessible from [internal ip]:8080/zm.
Thanks again!
Thanks again!
Greetz,
Sjonnie
Sjonnie
I just ran into this after a reboot, having installed pihole on a zm server yesterday. It worked. Until I rebooted. Don't know how.
Anyway, Apache hadn't started due to pihole grabbing port 80.
I opted to change /etc/lighttpd/lighttpd.conf to port 81, Seems to work fine.
