Console Screen Doesn't Update
geraldbrandt
Post by geraldbrandt »
Zoneminder 1.31.20
Ubuntu 16.04
FFMpeg 3
My system appears to be working fine... I get motion captures and can view the resulting video. However, when something is recorded, the console screen isn't updated with that data. The Hour column remains 0. I can click on the hour link, and will see the multiple motion captures their.
I do not have any storage areas defines yet, I'm still using the default storage.
This system was upgraded from 1.30.4 to 1.31.1 to 1.31.20
Is this a known issue? Is there some testing I can do to help resolve this?
Gerald
Re: Console Screen Doesn't Update
Confirmed same issue on a fresh install. Ubuntu 16.04-3 ZM 1.31.20
Edit: Actually I can see no events.
We are up to .22 now. Should fix this problem.
1.31.23 Storageareas
no events recorded or shown
error from log
Can't insert event: Unknown column 'Scheme' in 'field list'. sql was (INSERT INTO Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed, DefaultVideo, SaveJPEGs, Scheme ) values ( 1, 0, 'New Event', from_unixtime( 1516198812 ), 320, 240, 'Motion', 'Motion: All', 1, 1, 0, '', 3, '' ))
you will need to re-apply the .17 update.
mysql -u zmuser -p zm < /usr/share/zoneminder/db/zm_update-1.31.17.sql
iconnor wrote: Wed Jan 17, 2018 2:33 pm you will need to re-apply the .17 update.
OK, am seeing events now.
Corrected string: mysql -u zmuser -p zmpass < /usr/share/zoneminder/db/zm_update-1.31.17.sql
geraldbrandt
Just upgraded to .23 and it works. Thanks!
