1.31.20 No Background Filters!
Alec
Post by Alec »
I am having trouble with my background filters. Both in .19 & .20
I just updated my test installation to .20 from Isaac's PPA. The background filters are all returning zero events (E.g. Purge when full, MSG, and the new Update DiskSpace??) according to the log . . . however, if I run them manually through the web interface, they return events . . .
I am running this on Ubuntu 16.04 with LAMP, fully updated as of 15 minutes ago. Am I the only one having this result? All of these filters worked in .18, but stopped working with .19, and now also in .20.
Thanks!
Alec
DFU
Eradicator
Re: 1.31.20 No Background Filters!
Post by Eradicator »
Same problem. I tried to off OPT_FAST_DELETE. In 2-3 hours will see was it helpful.
Also i tried to clean install 1.31.20 but encountered a db problem. In log: "Can't insert event: Unknown column 'Scheme' in 'field list'."
db/zm_create.sql hasn't column 'Scheme'
Please update to 1.31.23
Oh wait... I havn't actually published .23 yet. You can use the following line in /etc/apt/sources.list to get newer packages.
deb https://zmrepo.zoneminder.com/debian/storageareas xenial/
Ok .23 packages are up for xenial at least.
Eradicator
Now even can't add server...
SQL-ERR 'SQLSTATE[42S22]: Column not found: 1054 Unknown column 'zmstats.pl' in 'field list'', statement was 'INSERT INTO Servers set `Name` = 'test', `Hostname` = '10.0.2.64', `zmstats.pl` = '1', `zmaudit.pl` = '1', `zmtrigger.pl` = '1'' params:
Is anywhere zm_create.sql with right db scheme for clean install?
Eradicator wrote: Wed Jan 17, 2018 2:45 pm Now even can't add server...
Try this: mysql -u zmuser -p zm < /usr/share/zoneminder/db/zm_update-1.31.17.sql
I could not see events
Eradicator
bbunge wrote: Wed Jan 17, 2018 4:19 pm
Thx for answer but it wasn't helpful for me. Result was same, can't add server.
In addition i tried to dump db from main .18 server, restore dump on test server and update it. Still can't add server. :(
the .pl in the column names caused a problem. So I had to rename them to just zmaudit, zmstats, zmtrigger
Eradicator
iconnor wrote: Thu Jan 18, 2018 1:38 pm the .pl in the column names caused a problem. So I had to rename them to just zmaudit, zmstats, zmtrigger
Installed and configured successfully! Thank you!
P.S. Filters are working correctly.
