can't stat '/tmp/zm'
alex_peri
Post by alex_peri »
Hi all,
I have installed Zoneminder v 1.30.4 on an Oracle VM VirtualBox running Debian.
Zoneminder installed correctly (as far as I could see) with no errors.
I have a Trendnet IP camera which I configured and is being monitored and I can see the live streaming.
In the log though I noticed a number of errors can't stat '/tmp/zm'
Please see image attached
Can you help?
Best,
A.
Re: can't stat '/tmp/zm'
Common problem with the Debian packages. The root cause is /tmp/zm is on private tmpfs folder. One process creates the files and folders but other processes can't read it, because it's private.
To fix, go to web portal and click Options-> Paths and change the swap path from /tmp/zm to /dev/shm.
alex_peri
Post by alex_peri »
Thanks, that worked!!!
cannca
Post by cannca »
hello, were you able to get live view on the trendnet?
I'm stuck in this error?
2018-01-07 19:13:01.788130 zmdc 683 INF 'zmc -m 1' crashed, signal 4 zmdc.pl
2018-01-07 19:12:59.066110 zmdc 1119 INF 'zmc -m 1' started at 18/01/07 18:12:59 zmdc.pl
2018-01-07 19:12:59.054270 zmdc 683 INF 'zmc -m 1' starting at 18/01/07 18:12:59, pid = 1119 zmdc.pl
2018-01-07 19:12:55.819920 zmwatch 739 INF Restarting capture daemon for Monitor-1, shared data not valid zmwatch.pl
2018-01-07 19:12:55.533920 zmwatch 739 ERR Memory map file '/tmp/zm/zm.mmap.1' does not exist. zmc might not be running. zmwatch.pl
Some help?
alex_peri
Post by alex_peri »
I have the same error 'zmc -m 1' crashed, signal 4 zmdc.p
but I can still see the video stream.
The Pan and tilt does not appear.
I notice that the camera works only in explorer and not in firefox so needs ActiveX
Pedulla
Post by Pedulla »
knight-of-ni wrote: Mon Jan 08, 2018 3:23 pm Common problem with the Debian packages. The root cause is /tmp/zm is on private tmpfs folder. One process creates the files and folders but other processes can't read it, because it's private.
OMG!
I'm posting this so just in case someone tries to do what I did, the key words might bring this up and save them the hassle.
I had the same issue with / filling or being too close to full to be comfortable so I thought I'd do a clever bind mount to a directory along side the event storage.... :/
I did a
sudo mount --bind /var/cache/zoneminder/tmp /tmp/zm
to test the theory and zoneminder started.
So I added the bind mount to /etc/fstab to make it automatic.
I'm such a dork. Just change the configuration option above.
Hah! Happy Zone'ing
