USB camera in ZoneMinder
laia0911
Post by laia0911 »
Please, does anyone help me how to set up USB cameras in ZoneMinder :?: :roll:
PacoLM
Re: USB camera in ZoneMinder
Post by PacoLM »
It will be really useful to search in the wiki or in the forum.
laia0911
Post by laia0911 »
I need tips on how to use USB cameras (WebCam) in ZoneMinder.
And, I'm not from Catalonia. I'm from Brazil.
Sorry, I'm using google translator to express myself in this forum.
you must use add monitor, pick "Local" go to the "Source" tab and select the correct settings. path will be like /dev/video0.
make sure the permissions are correct for www-data t see the camera. (add the user www-data to the group "video")
hope this helps.
laia0911
Post by laia0911 »
I am remotely accessing the server via PuTTY. So my question is how to configure these USB cameras remotely. It is possible? Or just local?
laia0911 wrote: Thu Jul 20, 2017 9:19 pm I am remotely accessing the server via PuTTY. So my question is how to configure these USB cameras remotely. It is possible? Or just local?
You did not say which version of Linux you are using. Here is a link to the WIKI :https://wiki.zoneminder.com/Helpful_use ... _resources
Once Zoneminder is installed and started you use the web console at http://server-ip/zm
One critical step for USB cameras is to add a user to the server:
Create a new user: adduser www-data video
uiguy
Post by uiguy »
I am getting the following error when trying to setup a local USB webcam
SQL-ERR 'SQLSTATE[HY000]: General error: 1366 Incorrect integer value: '' for column 'ServerId' at row 1', statement was 'insert into Monitors set LinkedMonitors = '', Name = 'Server', ServerId = '', Type = 'Local', Function = 'Monitor', Enabled = '1', RefBlendPerc = '6', AlarmRefBlendPerc = '6', AnalysisFPS = '', MaxFPS = '', AlarmMaxFPS = '', Protocol = '', Host = '', Port = '80', Options = '', Path = '', User = '', Pass = '', RTSPDescribe = '0', LabelFormat = '%N - %d/%m/%y %H:%M:%S', LabelX = '0', LabelY = '0', LabelSize = '1', ImageBufferCount = '50', WarmupCount = '25', PreEventCount = '25', PostEventCount = '25', StreamReplayBuffer = '1000', AlarmFrameCount = '1', EventPrefix = 'Event-', SectionLength = '600', FrameSkip = '0', MotionFrameSkip = '0', AnalysisUpdateDelay = '0', FPSReportInterval = '1000', DefaultView = 'Events', DefaultRate = '100', DefaultScale = '100', WebColour = 'red', Exif = '0', SignalCheckColour = '#0000c0', Device = '/dev/video0', Method = 'v4l2', Channel = '0', Format = '255', Palette = '1448695129', V4LMultiBuffer = '', V4LCapturesPerFrame = '1', Colours = '3', Width = '640', Height = '480', Orientation = '0', Deinterlacing = '0', Sequence = 18'
The camera is lcoated at /dev/video0
I am using Ubuntu 16.04. The camera is a Microsoft LifeCam HD-5001
Can anyone help?
