Continuous recording Event is not stop at Section length
marcolino7
Post by marcolino7 »
I have 6 camera configured in Mocord mode.
Sometime happen that Section length @600 seconds is not onored.
In this screenshoot there is an example:
2017-02-16 11_12_44-ZM - Events.jpg (29.27 KiB) Viewed 2856 times
as you can see, the event started @7.20 did not finished @7.30, but @7.43, and the event after it was shorter that Section length.
Why this?
Many Thanks
Marco
Production Zoneminder 1.31.4 Ubuntu 16.04 LTS on VmWare ESXi
6 Cameras FOSCAM FI8918W
OpenHab Integration
marcolino7
Re: Continuous recording Event is not stop at Section length
i keep situation monitored.
It seems that continous recording stop and restart, when a cam detect lots ov movement. I don't know if this is cause due camera fails due lot o data to be trasmitted or ZM fail to handler the data too.
Here is the logs for last occurence:
Feb 17 14:45:26 zoneminder zmdc[1367]: WAR [Can't find process with command of 'zmtrack.pl -m 11']
Feb 17 14:45:26 zoneminder zmdc[1367]: INF ['zma -m 11' sending stop to pid 18760 at 17/02/17 14:45:26]
Feb 17 14:45:26 zoneminder zma_m11[18760]: INF [Got signal 15 (Terminated), exiting]
Feb 17 14:45:26 zoneminder zma_m11[18760]: INF [IPCAM05-Sala-REC: 196173 - Closing event 23506, shutting down]
Feb 17 14:45:26 zoneminder zmdc[1367]: INF ['zma -m 11' exited normally]
Feb 17 14:45:26 zoneminder zmdc[1367]: INF ['zma -m 11' starting at 17/02/17 14:45:26, pid = 30668]
Feb 17 14:45:26 zoneminder zmdc[30668]: INF ['zma -m 11' started at 17/02/17 14:45:26]
Feb 17 14:45:27 zoneminder zma_m11[30668]: INF [In mode 5/1, warming up]
Feb 17 14:45:27 zoneminder zma_m11[30668]: INF [IPCAM05-Sala-REC: 026 - Opening new event 23511, section start]
OpenHab Integration
SteveGilvarry
Post by SteveGilvarry »
My record events all stop and start on 10 min intervals, sometimes the frame count varies by a few frames. I am thinking in your case the mocord option is keeping the event open, i.e. in this 5000 frame event you had 1000 alarm frames. It is only a theory I would need to check the code on mocord to confirm exactly. But try record only for a period and see if you get more consistent event lengths.
It could be some of the post event buffer settings causing alarms to merge into a single event.
