POE Injector Block Install
Pedulla
Post by Pedulla »
https://drive.google.com/file/d/0B6Bh-v ... sp=sharing
This was early in the install, all blocks are full now :)
I like injectors over POE switches just to separate the points of failure. Backup power supplys are less costly than backup POE switches.
jerrynavarete
Re: POE Injector Block Install
Post by jerrynavarete »
What happens to your POE switch?
mikb
Post by mikb »
Mostly it provides power over ethernet, and it switches packets ...
Baylink
Post by Baylink »
Note that there are 24-port smart POE injectors available that mount in a single RU -- tell you which ports are powered, power draw, can bounce single ports remotely, and everything...
