Frame rate in Raspberry 3
bugmenot
Post by bugmenot »
Let say i want to have little too much cameras with motion detection in Raspberry 3 so it makes framerate low.
Which one of these gives me better performance:
ZoneMinder
motionEyeOS
motionEye
Also are there any other serious ZoneMinder type of apps?
Re: Frame rate in Raspberry 3
bugmenot wrote:Let say i want to have little too much cameras with motion detection in Raspberry 3 so it makes framerate low.
ZoneMinder
motionEyeOS
motionEye
Do you seriously think anyone on this forum would recommend anything other than Zoneminder? As for me, I've not used anything else! The performance you get will depend on the camera settings. Low frame rate and resolution is best for the pi.
PacoLM
Post by PacoLM »
ZoneMinder
motionEyeOS
motionEye
Well, maybe Bugmenot could offer himself to do the tests and post the results...Have the need and ask somoene else to do it is kind of lazy, isn´t it? :shock:
Regards!
PacoLM
