Motion filter Email setup
rebootln
Post by rebootln »
Hey all - new to the board here
so i have everything working - it was pretty straight up setup
My issue is with email alerts
I would like to email all motion alerts as they happen - however filters are reloaded in interval and executed the same way ( in different interval)
so for this set up i have :
and cause = motion
and alarm frames < 50
and date = now
and time > 18:00 or time < 08:00
This works except that it matches many events every time it runs and emails them all over again
if i limit to first 5 events - no matter if there is 1 new of 20 new - either i will get 5 duplicates or i will miss 15 ...
so ... what is the proper way to do this ?
What am i missing ? :)
Thank you!
rebootln
Re: Motion filter Email setup
Post by rebootln »
so i made some progress on this - i hope this helps someone
Set the filter reload to 60 seconds
set the filter execution to 60 seconds
set the filter to get you events of -1 minute
the key is Greater then or equal to and NOT less then or equal to -
for whatever dumb reason i could not wrap my head around that until it became crystal clear - so i admit - i thought i was wrong but i was just mistaken :) LOL
Like i said - i hope it helps someone - as there was no responses to my question :)
this filter works for me and sends 1 email per event ->
Frames -> Greater than or equal to -> 1
and
Cause -> not equal to -> Signal #this prevents false alarm email because of a camera signal interruption. remove or create another filter to send email, if camera drops out and you want be notified with an email.
Date/Time -> Decending _> Limit to First= 1
HarryB
Post by HarryB »
How does the Frames >= 1 work? Where can I find definitions of the variables, like "Frames" and "Cause", including possible values?
kylegp
Post by kylegp »
HarryB wrote: Tue Jan 10, 2017 11:32 am How does the Frames >= 1 work? Where can I find definitions of the variables, like "Frames" and "Cause", including possible values?
I also want to know where the definitions of variables are. Can't find them anywhere.
DennisFaucher
Post by DennisFaucher »
Thanks for this. You saved me a bunch of time
