Hi there!
When i'm watching live stream from ZM via web browser, everytime i received message "Insufficent disk space" and stream video stopped.
What is this?
"df -h" command tells, disk space is good (see attachment)
Thanx.
insufficient disk space
- space.jpg (54.55 KiB) Viewed 3811 times
Re: insufficient disk space
You need to give us more info. Just guessing that you have Zoneminder installed on a desktop system and the error msg comes from your browser? Do you get the error when you view the stream from a remote pc?
I have no errors when viewing from web-browser or remote.
ZoneMinder installed on a HP ProLiant Server.
Viewing a monitor live generates temporary files in the directory defined by PATH_SWAP. The "default" location is /tmp. The system will create 999 files then start overwriting the earlier files. The size of the .jpg's is determined by the camera resolution. So, the higher the resolution the more space in PATH_SWAP you will need. If you have changed the PATH_SWAP to your tmpfs area you could run out of space faster even though writing to RAM is faster than writing to disk.
I am not saying this is your problem but it could be.
bb
bb
Thanx for an answer.
For a directory /tmp i reserved 5 Gb.
Everytime i see 78Mb load of this directory, not more.
What should i do?
/dev/md2 5,4G 78M 5,0G 2% /tmp
What should i do?
Reinstall your system and create a swap partition and a root "/" partition. Put all your directories and files in one partition. Performance wise you gain nothing by creating a bunch of partitions. Only problems when a partition runs out of space...Zenw1e wrote:Thanx for an answer.
Everytime i see 78Mb load of this directory, not more.Code: Select all
What should i do?
Ok, thanx, i will try
I noticed that when viewing live cameras on the computer on which the open web streaming quickly runs out of space on this hard drive, if you look TEMP folder, then they reach the 120 GB and above, because this is written and "not enough space", when i am cleared this temp files, cameras starting normally streaming.
