Vivotek FD61x1 bluescreen
bench
Post by bench »
Hello.
I have fresh install ubuntu 14.04.5 LTS and fresh install of Zoneminder v1.30.0.
I managed to get system working with new cameras, but i have problem with the old ones in my system.
Can`t get anything from Vivotek FD61x1, allready tried everything what i found on this forum.
I can get the picture from cam with http://user:pass@IP:PORT/cgi-bin/video.jpg
But in Zoneminder... all i have is bluescreen :(
Logs from zoneminder
2016-09-28 14:37:39.478400 zmc_m9 8632 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-09-28 14:37:39.471831 zmc_m9 8632 ERR Unable to read content zm_remote_camera_http.cpp 1040
2016-09-28 14:37:39.328902 zmc_m9 8632 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-09-28 14:37:39.322650 zmc_m9 8632 ERR Unable to read content zm_remote_camera_http.cpp 1040
Can`t get anything in user@zoneminder:/var/log/zm#
All errors that were in @zoneminder:/var/log/apache# are nov solved.
But still.
Thanks. BR
danielemod
Re: Vivotek FD61x1 bluescreen
Post by danielemod »
Identical error log problem with the very similar model Vivotec FD6122
linuxd0d0
Post by linuxd0d0 »
FD6122V gave me this issue
danielemod
My configuration Vivotek FD6122
In MONITOR
GENERAL
Server: None
Source Type Remote
Function: Monitor
Enabled: yes
Analysis FPS:
Maximum FPS: 5
Allarm Maximum FPS: 5
Reference Image Blend %ge: 6.25% (indor)
Alarm Reference Image Blend %ge: 6.25%
Triggers: None available
in MONITOR
SOURCE
Remote Host Path: /live.sdp
identical problem bluescreen :|
Sceenshots: https://drive.google.com/open?id=0B_did ... WZBdU1fSms
Other log message:
zmc_m1		9609	INF	Vivotec Dome FD6122: 10000 - Captu[/url]r[/img][/url]ing at 4.13 fps	zm_monitor.cpp	3125
Manual VivotekFS61: https://drive.google.com/open?id=0B_did ... nB1dHJGTzQ
Link Wiky ZM : https://wiki.zoneminder.com/index.php/Vivotek?#FD8134
Link Ubuntu Forum: http://forum.ubuntu-it.org/viewtopic.php?f=75&t=583395
Link askUbuntu: https://askubuntu.com/questions/500318/ ... zoneminder
Help me bluescreen!
bench
Post by bench »
Even try with the latest Ubuntu 16.x and with the latest CentOS...
It is the same problem!!
2018-03-04 10:23:44.436984 zmc_m9 VideoNS-1 26008 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2018-03-04 10:23:44.436561 zmc_m9 VideoNS-1 26008 ERR Unable to read content zm_remote_camera_http.cpp 1040
2018-03-04 10:23:44.356939 zmc_m9 VideoNS-1 26008 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2018-03-04 10:23:44.356502 zmc_m9 VideoNS-1 26008 ERR Unable to read content zm_remote_camera_http.cpp 1040
You have your method set to http instead of rtsp.
