Upgrade fail on CentOS 6.8 1.29 - 1.30
basketcase
Post by basketcase » Mon Sep 19, 2016 1:49 am
Hi all,
I've been having trouble upgrading on Centos 6.8 from ZM 1.29 - 1.30.
So I've upgraded the standard way as I have many times before. This is with CentOS Base and the zmrepo enabled.
yum install zoneminder
Loaded plugins: fastestmirror, priorities, refresh-packagekit, security
Setting up Install Process
Loading mirror speeds from cached hostfile
 * base: mirror.aarnet.edu.au
 * zmrepo: 67.53.78.182
Resolving Dependencies
--> Running transaction check
---> Package zoneminder.x86_64 0:1.29.0-3.el6 will be updated
---> Package zoneminder.x86_64 0:1.30.0-3.el6 will be an update
--> Processing Dependency: perl(Sys::MemInfo) for package: zoneminder-1.30.0-3.el6.x86_64
--> Processing Dependency: perl(Sys::CPU) for package: zoneminder-1.30.0-3.el6.x86_64
--> Processing Dependency: perl(SOAP::WSDL::XSD::Typelib::Builtin::anySimpleType) for package: zoneminder-1.30.0-3.el6.x86_64
--> Processing Dependency: perl(SOAP::WSDL::XSD::Typelib::Builtin) for package: zoneminder-1.30.0-3.el6.x86_64
--> Processing Dependency: perl(SOAP::WSDL::Transport::HTTP) for package: zoneminder-1.30.0-3.el6.x86_64
--> Processing Dependency: perl(SOAP::WSDL::SOAP::Typelib::Fault11) for package: zoneminder-1.30.0-3.el6.x86_64
--> Processing Dependency: perl(SOAP::WSDL::Factory::Transport) for package: zoneminder-1.30.0-3.el6.x86_64
--> Processing Dependency: perl(SOAP::WSDL::Factory::Serializer) for package: zoneminder-1.30.0-3.el6.x86_64
--> Processing Dependency: perl(SOAP::WSDL::Factory::Deserializer) for package: zoneminder-1.30.0-3.el6.x86_64
--> Processing Dependency: perl(IO::Socket::Multicast) for package: zoneminder-1.30.0-3.el6.x86_64
--> Processing Dependency: perl(Digest::SHA) for package: zoneminder-1.30.0-3.el6.x86_64
--> Processing Dependency: perl(Data::UUID) for package: zoneminder-1.30.0-3.el6.x86_64
--> Processing Dependency: perl(Data::Dump) for package: zoneminder-1.30.0-3.el6.x86_64
--> Processing Dependency: perl(Class::Std::Fast::Storable) for package: zoneminder-1.30.0-3.el6.x86_64
--> Processing Dependency: perl(Class::Std::Fast) for package: zoneminder-1.30.0-3.el6.x86_64
---> Package perl-Class-Std-Fast.noarch 0:0.0.8-2.el6 will be installed
--> Processing Dependency: perl(Class::Std) for package: perl-Class-Std-Fast-0.0.8-2.el6.noarch
---> Package perl-Data-Dump.noarch 0:1.15-1.el6 will be installed
---> Package perl-Data-UUID.x86_64 0:1.219-3.el6 will be installed
---> Package perl-Digest-SHA.x86_64 1:5.47-141.el6_7.1 will be installed
---> Package perl-IO-Socket-Multicast.x86_64 0:1.12-1.el6 will be installed
--> Processing Dependency: perl(IO::Interface) >= 0.94 for package: perl-IO-Socket-Multicast-1.12-1.el6.x86_64
---> Package perl-SOAP-WSDL.noarch 0:3.003-1.el6 will be installed
--> Processing Dependency: perl(Template) >= 2.18 for package: perl-SOAP-WSDL-3.003-1.el6.noarch
--> Processing Dependency: perl(XML::Parser::Expat) for package: perl-SOAP-WSDL-3.003-1.el6.noarch
--> Processing Dependency: perl(Term::ReadKey) for package: perl-SOAP-WSDL-3.003-1.el6.noarch
--> Processing Dependency: perl(Class::Load) for package: perl-SOAP-WSDL-3.003-1.el6.noarch
--> Processing Dependency: perl(Apache2::RequestUtil) for package: perl-SOAP-WSDL-3.003-1.el6.noarch
--> Processing Dependency: perl(Apache2::RequestRec) for package: perl-SOAP-WSDL-3.003-1.el6.noarch
--> Processing Dependency: perl(Apache2::RequestIO) for package: perl-SOAP-WSDL-3.003-1.el6.noarch
--> Processing Dependency: perl(Apache2::Log) for package: perl-SOAP-WSDL-3.003-1.el6.noarch
--> Processing Dependency: perl(Apache2::Const) for package: perl-SOAP-WSDL-3.003-1.el6.noarch
--> Processing Dependency: perl(APR::Table) for package: perl-SOAP-WSDL-3.003-1.el6.noarch
---> Package perl-Sys-CPU.x86_64 0:0.51-7.el6 will be installed
---> Package perl-Sys-MemInfo.x86_64 0:0.91-5.el6 will be installed
---> Package mod_perl.x86_64 0:2.0.4-11.el6_5 will be installed
--> Processing Dependency: perl(BSD::Resource) for package: mod_perl-2.0.4-11.el6_5.x86_64
---> Package perl-Class-Load.noarch 0:0.10-1.el6 will be installed
--> Processing Dependency: perl(Try::Tiny) for package: perl-Class-Load-0.10-1.el6.noarch
--> Processing Dependency: perl(Package::Stash) for package: perl-Class-Load-0.10-1.el6.noarch
--> Processing Dependency: perl(Data::OptList) for package: perl-Class-Load-0.10-1.el6.noarch
---> Package perl-Class-Std.noarch 0:0.0.8-5.el6 will be installed
---> Package perl-IO-Interface.x86_64 0:1.05-15.el6 will be installed
---> Package perl-Template-Toolkit.x86_64 0:2.22-5.el6 will be installed
--> Processing Dependency: perl(Pod::POM) for package: perl-Template-Toolkit-2.22-5.el6.x86_64
--> Processing Dependency: perl(AppConfig) for package: perl-Template-Toolkit-2.22-5.el6.x86_64
---> Package perl-TermReadKey.x86_64 0:2.30-13.el6 will be installed
---> Package perl-XML-Parser.x86_64 0:2.36-7.el6 will be installed
---> Package perl-AppConfig.noarch 0:1.66-6.el6 will be installed
---> Package perl-BSD-Resource.x86_64 0:1.29.03-3.el6 will be installed
---> Package perl-Data-OptList.noarch 0:0.104-4.el6 will be installed
--> Processing Dependency: perl(Sub::Install) >= 0.92 for package: perl-Data-OptList-0.104-4.el6.noarch
--> Processing Dependency: perl(Params::Util) for package: perl-Data-OptList-0.104-4.el6.noarch
---> Package perl-Package-Stash.noarch 0:0.32-1.el6 will be installed
--> Processing Dependency: perl(Package::Stash::XS) >= 0.24 for package: perl-Package-Stash-0.32-1.el6.noarch
--> Processing Dependency: perl(Package::DeprecationManager) for package: perl-Package-Stash-0.32-1.el6.noarch
---> Package perl-Pod-POM.noarch 0:0.25-2.el6 will be installed
---> Package perl-Try-Tiny.noarch 0:0.11-4.el6 will be installed
---> Package perl-Params-Util.x86_64 0:1.00-3.el6 will be installed
---> Package perl-Sub-Install.noarch 0:0.925-6.el6 will be installed
--> Finished Dependency Resolution
Error: Package: perl-Package-Stash-0.32-1.el6.noarch (zmrepo)
           Requires: perl(Package::Stash::XS) >= 0.24
           Requires: perl(Package::DeprecationManager)
 You could try using --skip-broken to work around the problem
 You could try running: rpm -Va --nofiles --nodigest
I have actually navigated through the repo source and the files it wants are there:
example: perl-Package-Stash-0..> 2011-09-08 16:07 32K
I'm at a loss as to what I'm doing wrong...
Here I've disabled all other packages, get a different error:
 * zmrepo: zmrepo.mehvc.com
Error: Package: perl-SOAP-WSDL-3.003-1.el6.noarch (zmrepo)
           Requires: perl(Term::ReadKey)
           Requires: perl(XML::Parser::Expat)
Error: Package: zoneminder-1.30.0-3.el6.x86_64 (zmrepo)
           Requires: perl(Digest::SHA)
           Requires: perl(APR::Table)
           Requires: perl(Apache2::Const)
           Requires: perl(Apache2::RequestIO)
           Requires: perl(Apache2::Log)
Error: Package: perl-Class-Load-0.10-1.el6.noarch (zmrepo)
           Requires: perl(Data::OptList)
           Requires: perl(Template) >= 2.18
           Requires: perl(Apache2::RequestRec)
           Requires: perl(Apache2::RequestUtil)
Ideas much appreciated - it's probably something simple I'm missing
edit: That's CentOS 6.8 not 6.7
Cheers!
Dave
Re: Upgrade fail on CentOS 6.8 1.29 - 1.30
Post by knight-of-ni » Mon Sep 19, 2016 2:58 pm
Looks like I missed a couple of Perl dependencies of ZoneMinder's Perl dependencies. This has been fixed.
Try it again, but with your base repo enabled (never disable that).
The CentOS 6 repo does not receive the same amount of love as the CentOS 7 repo because I no longer use it in production nor do I directly develop on it.
Sorry for the inconvenience.
basketcase
Post by basketcase » Mon Sep 19, 2016 10:11 pm
Excellent works a perfect now.
Had to flip the resolution settings on a few 720p cams which I'd previously rotated left or right. I see the resolution height and width are now rotated automatically, fixed the corresponding zones.
Looks to have a good performance improvement too, load levels are down under normal operations.
You make a good point too, this old box is due an upgrade, I think I've run it since about 2012 24/7, thing just keeps on going! Only gets power cycled on major updates I've been waiting for something like the primary HDD to go to motivate me into action.
Thanks again.
