Create one video from multiple consecutive events
patpend
Post by patpend »
I need to save an hour's worth of events (about 50 individual events) to one video. Is there a one-step way to do this easily? Otherwise is the only option manually creating a video of each event and concatenating using some sort of video editing software?
mikb
Re: Create one video from multiple consecutive events
Post by mikb »
Not found a 1 step ZM solution, but ... I use this to join multiple .avi's (xvid/mp4 format) from Zoneminder ...
mencoder *.avi -ovc copy -of avi -force-avi-aspect 4:3 -o mergedclip.avi
Seems to join with no loss/errors/recoding, so works for me.
If they were mpeg files, you could get away with just using
cat *.mpg > mergedmpeg.mpg
Which is simple as it gets!
patpend
Post by patpend »
Thanks mikb. Looks like this will work for .mov files too, which is what I'm using (since mov file size is about 20% of mpeg).
