Hello Every One,
Below I got an error when adding a monitor. Hope Somebody can help me.
SQL-ERR 'SQLSTATE[HY000]: General error: 1366 Incorrect integer value: '' for column 'V4LMultiBuffer' at row 1', statement was 'insert into Monitors set LinkedMonitors = '', Device = '/dev/video0', Channel = '0', Format = '255', Palette = '0', V4LMultiBuffer = '', V4LCapturesPerFrame = '1', Protocol = '', Host = '', Port = '80', Method = '', Options = '', Path = '', User = '', Pass = '', Colours = '3', Width = '320', Height = '240', Orientation = '0', Deinterlacing = '0', RTSPDescribe = '0', LabelFormat = '%N - %Y-%m-%d %H:%M:%S %z', LabelX = '0', LabelY = '0', LabelSize = '1', ImageBufferCount = '50', WarmupCount = '25', PreEventCount = '25', PostEventCount = '25', StreamReplayBuffer = '1000', AlarmFrameCount = '1', Controllable = '0', ControlId = '', ControlDevice = '', ControlAddress = '', AutoStopTimeout = '', TrackMotion = '0', TrackDelay = '', ReturnLocation = '-1', ReturnDelay = '', EventPrefix = 'Event-', SectionLength = '600', FrameSkip = '0', MotionFrameSkip = '0', AnalysisUpdateDelay = '0', FPSReportInterval = '1000', DefaultView = 'Events', DefaultRate = '100', DefaultScale = '100', WebColour = 'red', Exif = '0', SignalCheckColour = '#0000c0', Name = 'Monitor-1', ServerId = '', Type = 'Local', Function = 'Monitor', Enabled = '1', AnalysisFPS = '', MaxFPS = '', AlarmMaxFPS = '', RefBlendPerc = '6', AlarmRefBlendPerc = '6', Sequence = 1' /usr
Version: Zoneminder 1.29
OS : Unbuntu LTS 16.04
Philip
Error When Adding Monitor
Re: Error When Adding Monitor
Thanks, this fixed my similar problem. Now, for the newb, can someone explain *why* this fixed the problem? Be gentle...
http://johnemb.blogspot.com/2014/09/add ... modes.htmlalabamatoy wrote:Thanks, this fixed my similar problem. Now, for the newb, can someone explain *why* this fixed the problem? Be gentle...
Simple answer trying to insert empty string '' into int field, it used to warn but still do it, now it errors. You remove STRICT_TRANS_TABLE and it reverts to old behaviour. We have to fix insert to use NULL instead of '', we already committed a change.
