API Commands Not Found - Ubuntu 16.04
macfloripa
Post by macfloripa »
I have ZM 1.29.0 with Ububtu 16.04 - fresh install. Got everything working and want to try out the API.
When I try the API commands as per the documentation I get command not found (after getting cookie information).
$ curl -b cookies.txt http://localhost/zm/api/monitors.json
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p>The requested URL /zm/api/monitors.json was not found on this server.</p>
<hr>
<address>Apache/2.4.18 (Ubuntu) Server at localhost Port 80</address>
</body></html>
This makes sense, because when I go to the api directory - this is what I see:
/usr/share/zoneminder/www/api$ ls -l
total 40
drwxr-xr-x 15 www-data www-data  4096 May 12 10:35 app
-rw-r--r--  1 www-data www-data   174 Feb  3 17:30 build.properties
-rw-r--r--  1 www-data www-data 10315 Feb  3 17:30 build.xml
-rw-r--r--  1 www-data www-data   837 Feb  3 17:30 composer.json
-rw-r--r--  1 www-data www-data  3252 Feb  3 17:30 CONTRIBUTING.md
-rw-r--r--  1 www-data www-data  1454 Feb  3 17:30 index.php
drwxr-xr-x  3 www-data www-data  4096 May  1 22:20 lib
-rw-r--r--  1 www-data www-data   437 Feb  3 17:30 README.md
It looks like the API commands were not installed with the package? Am I missing something?
Thanks in advance....
/usr/share/zoneminder/www$ ls -l
total 48
drwxr-xr-x 2 www-data www-data 4096 May  1 22:20 ajax
drwxr-xr-x 4 www-data www-data 4096 May  1 22:20 api
drwxr-xr-x 2 www-data www-data 4096 May  1 22:20 css
lrwxrwxrwx 1 www-data www-data   28 Apr  5 10:50 events -> /var/cache/zoneminder/events
drwxr-xr-x 2 www-data www-data 4096 May  1 22:20 graphics
lrwxrwxrwx 1 www-data www-data   28 Apr  5 10:50 images -> /var/cache/zoneminder/images
drwxr-xr-x 2 www-data www-data 4096 May  1 22:20 includes
-rw-r--r-- 1 www-data www-data 6435 Feb  3 17:30 index.php
drwxr-xr-x 2 www-data www-data 4096 May  1 22:20 js
drwxr-xr-x 2 www-data www-data 4096 May  1 22:20 lang
drwxr-xr-x 5 www-data www-data 4096 May  1 22:20 skins
lrwxrwxrwx 1 www-data www-data   28 May 12 10:13 sounds -> /var/cache/zoneminder/sounds
lrwxrwxrwx 1 www-data www-data   26 Apr  5 10:50 temp -> /var/cache/zoneminder/temp
drwxr-xr-x 3 www-data www-data 4096 May  1 22:20 tools
drwxr-xr-x 2 www-data www-data 4096 May  1 22:20 views
Re: API Commands Not Found - Ubuntu 16.04
What install document did you use?
bbunge wrote:What install document did you use?
Sorry, I should have said look here for instructions: https://wiki.zoneminder.com/Ubuntu_Serv ... e_easy_way
I just checked a Live DVD version and the API responded.
bb
macfloripa
I did use those instructions, yes. Strange.
Can someone tar up the /usr/share/zoneminder/www/api directory for me?
mrLitter
Post by mrLitter »
I got API working by picking out the following steps from https://wiki.zoneminder.com/Ubuntu_Serv ... e_easy_way
a2enmod rewrite
Fix Permissions
Fix to allow API to work
nano /etc/apache2/apache2.conf
Change None to All two places as shown below
<Directory /usr/share>
AllowOverride All
Require all granted
</Directory>
<Directory /var/www/>
AllowOverride All
Require all granted
</Directory>
Ctrl+o Enter to save
CTRL+x to exit
macfloripa
Thanks for the reply, mrLitter.
I redid what you suggested.
However, it seems that in my installation, the api commands were not included in the install.
I'll have to try a re-install, unless some kind soul will tar and zip up their api directory from an ubuntu machine and send it to me...
I just did a fresh install on Ubuntu 16.04 server using the WIKI instructions and the API was there.
bb
asker
Post by asker »
These are not api commands - if your apache configuration is not setup properly, it will not be found. I am very sure you did not follow all the instructions for setup. My suggestion is to follow the wiki instructions folks have posted ad pedem litterae
macfloripa wrote:Thanks for the reply, mrLitter.
Please read before posting:
ES docs
zmNinja docs
