night time
NewtoTheZone
night time
Post by NewtoTheZone »
Has anyone else had a problem when their cameras go into night mode of the image being all distorted. During the day its clear as I can expect with the low quality camera. But when it goes into night mode the image is all fuzzy, lines, scrambled up.
Any ideas?
Thanks All..
Re: night time
What camera are you using? I have Foscam and Vivotek cameras that work well at night.
bb
NewtoTheZone
Re: night time
I have analog connect to a capture card. The cameras worked ok on my cheap chinnees dvr unit, which makes me think it's the capture card.
I would probably get better results from up cameras.
Re: night time
If you do not tell us what you are using nobody can even begin to help you.
bb
mikb
Re: night time
Post by mikb »
... and if possible include a link to the "fuzzy lines scrambled" picture example as someone may recognise what the source of the fault is!
