CPU usage 98% !
caseyj
CPU usage 98% !
Post by caseyj »
I install for testing zm on virtualbox (Lubuntu_14.04_with_Zoneminder_1.29.0 pre-configured).
All fine, then i install webmin and here i see : CPU usage 98% ! ...
Notice that I also try to disable all monitor and CPU still at 98% .... :?:
Re: CPU usage 98% !
My first thought was that your database has a problem. Then I saw you were using my Lubuntu setup. Wonder if it has something to do with you using s single core machine? Does the usage go down if you stop Zoneminder?
SteveGilvarry
Re: CPU usage 98% !
Post by SteveGilvarry »
Set monitors function from Monitor to None, I don't think changing a running zmc to disabled actually kills it, just stops it running on startup.
caseyj
Re: CPU usage 98% !
Post by caseyj »
Guys,
Today I check and got this : (I didnt do anything...)
CPU usage 1% user, 0% kernel, 0% IO, 99% idle
Maybe it was OS itself checked for something in its routine after fresh install...
I will stay tuned for it. Thanks for reply.
Pedulla
Re: CPU usage 98% !
Post by Pedulla »
I've seen this when the cameras (rtsp) are off line/disconnected/not there/or some problem.
If you don't have a max framerate set for each monitor/camera the system races as fast as it can.
I got mine up to 1236 fps once... cool... not...
Solution, set a max frame rate about 10% higher than you expect from your camera stream. If the camera's won't be online for a while, disable the monitor in function section of the offending monitor/camera.
Hope I didn't use too much ZM jargon.
caseyj
Re: CPU usage 98% !
Post by caseyj »
Might be this :D :D :D
